vibration when wheels turned all the way at slow speed?? | FerrariChat
Discussion in '360/430' started by Race3, Feb 4, 2011.
  1. Race3
    Race3 Karting
    Nov 14, 2010
    144
    when at very slow speed, if making a very tight turn, the front wheels vibrate / shake. is that normal? it feels like what happens if you had a 4wd car, but this obviously isn't 4wd, so why does it happen?
    thanks.
  2. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,621
    South East
    Jimmie
    Not this one again - look up Ackerman on Wikipedia - or here.....
  3. Rifledriver
    36,756
    Bent fender lips.
    Very common on 360
  4. Mr Aryan
    Mr Aryan Karting
    Sep 23, 2008
    182
    Bahrain
    Mr Aryan
    i beleive he has a F430...
    I feel the same thing on my F430 spider... i just asked another F430 owner, he said it's normal...
    don't mind seeing Fchat comments...
  5. Piper
    Piper Two Time F1 World Champ
    25,371
    Northern Virginia
    Bob
    Yup.
  6. needspeed
    needspeed Formula Junior
    Oct 5, 2006
    579
    Middle of nowhere IA
    Steve
    I was wondering the same thing on my F430. I get the same feeling when my wheels are close to max lock. Seems no harm done but it feels uncomfortable when it does it......Steve
  7. Speedy2081
    Speedy2081 Formula Junior
    Feb 8, 2009
    477
    Westchester New York
    Joe C
    Happens on my 360 too. I was a little worried also.
  8. Robdownunder
    Robdownunder Formula Junior
    Feb 6, 2009
    580
    Australia
    Rob
    I was told it is the LSD doing that....as if it is in AWD on a hard surface and the wheels can't slip.
  9. Challengehauler
    Challengehauler Formula 3
    Jul 28, 2008
    1,315
    NE Connecticut
    DB
    E-diff
  10. Race3
    Race3 Karting
    Nov 14, 2010
    144
    yes, i have a 430 and appreciate that other people have wondered the same thing when wheels are fully turned.
    someone posted it's the e-diff, but i don't understand that. isn't the e-diff connected only to the rear wheels?
    It sounds like this is a normal feeling... i'm just curious why it's happening on the front wheels.
  11. 430man
    430man Formula Junior
    Jan 18, 2011
    489
    #11 430man, Feb 5, 2011
    This is caused because the inside tire has to turn in a tighter circle than the outer tire. (in a turn)
    The steering geometry is set to account for this but it is turned for regular driving, not max ratio turns. If you park the car with the wheel turned hard left you'll notice the left wheel points out at a greater angle than the right points in. (did that make sense?)
    The vibration you're experiencing is the tires slipping on the pavement as they turn at different steering ratios. (ie: they do not track properly at max deflection)
    While this might be a sign of a problem if it is excessive, it's probably normal.
    Try it in the rain and you'll probably notice it is decreased.
  12. Race3
    Race3 Karting
    Nov 14, 2010
    144
    thanks for the description. that makes sense, although i thought there is usually a front differential that negated this issue. also, why doesn't it happen with other, regular cars? thx.
  13. RobD
    RobD Formula 3
    Nov 10, 2003
    1,182
    In cold weather, my 430's tires skip sideways when turning sharply, too. It seems less severe after the tires warm up a bit. My other car does this, as well. It likely has something to do with a sports car's steering geometry and cold, hard summer tires.
  14. 430man
    Jan 18, 2011
    489
    #14 430man, Feb 5, 2011
    I might have phrased that poorly... It's not that they are skipping BECAUSE turning at different speeds.
    (As I understand it but not be explaining it right...) The steering ratio is non-linear. In other words, as you turn tighter, the inner wheel needs more deflection. -- But mechanical linkage can't do that perfectly. So at full deflection the wheels are not 'in sync' as well as they are at drive speeds. (I don't know the proper nouns for all this, sorry) So your tires are not tracking perfectly. Or that's how it was explained to me by a guy who does this for a living... although he'd probably chuckle at my tortured verbiage.
    A similar problem can be felt if you have old brittle tires. If you have this problem more in the cold and your tires are old, ya might replace them.
    I edited the post above. I said the wheels turned at different 'rates.' And I meant different 'steering rates' (ie ratios) not 'different speeds.' - Poor choice of word.
  15. SfefVan
    SfefVan Guest
    Nov 28, 2008
    1,370
    Switzerland
    Stef
    I had this very strongly with Pirelli tires. Now, I went for Michelin PS2 tires and in the same conditions, I almost didn't have this issue anymore, just very slightly. After changing the 4 springs, lowering the car and a serious realignment, this problem 100% disappeared :
    Left Max steering Left Wheel: +21°36' -> +29°00'
    Left Max steering Right: +20°57' -> +26°19'
    Right Max steering Left Wheel: +29°29' -> +26°41'
    Right Max steering Right Wheel: +32°48' -> +29°29'
    Stef
