VHT Engine Enamel | FerrariChat
VHT Engine Enamel
Discussion in 'Technical Q&A' started by Dr Kananga, Apr 23, 2012.
  1. Dr Kananga
    Dr Kananga Formula 3
    Apr 20, 2011
    1,222
    Los Angeles, CA
    Buonapart I. Gallia
    Anyone use this stuff?
    http://ecx.images-amazon.com/images/I/41yTnEIXOyL._SL500_AA300_.jpg
    I just sprayed my expansion tank and I am getting near perfect, glass-like finish, on most of the tank and random grey/dull areas. I hit it again and I get new glass-like finish with new grey/dull areas.
    Am I missing something?
    Doing something wrong?
    Thanks!!!
  2. Mowgli
    Mowgli Formula Junior
    Feb 28, 2009
    435
    Bristol, CT
    I used the pink VHT on a race motor I built for my Mirage. Never ran the car so it did not cure properly. But when I sprayed it on, I remember a fairly glossey application. Maybe you did not prep the surface properly?
  3. Ferris Bueller
    Ferris Bueller Formula 3
    Mar 23, 2004
    1,863
    New Jersey
    Dominic
    do you know the humidity level when you are spraying?
    If you apply in weather with high humidity you will get the results you have described
  4. Dr Kananga
    Apr 20, 2011
    1,222
    Los Angeles, CA
    Buonapart I. Gallia
    Low humidity.
    Also--
    On the last spray, I brought it inside immediately which has near zero humidity.
    Confusing me...
    Sent from my iPhone
    (which probably means I'm sitting at my car confused)
  5. Dr Kananga
    Apr 20, 2011
    1,222
    Los Angeles, CA
    Buonapart I. Gallia
    Bare metal sand.
    Primer.
    Sand.
    Couple light coats of VHT, which dried glossy.
    Heavy coat to finish. This is where the problems started.
    I don't think curing it will change the finish.
    Not sure what to do at this point.
    Sent from my iPhone
  6. Dr Kananga
    Apr 20, 2011
    1,222
    Los Angeles, CA
    Buonapart I. Gallia
    OK--
    Did another coat completely indoors (make shift paint booth) and it came out perfectly.
    Humidity was LOW today, but I guess not low enough.
    I suppose this was the fix....?
    Thanks for the input.
