The fluid stops flowing out in the feed hose, and through the banjo bolt. The system is now totally closed off inside the shock. Relatively incompressable, the fluid brings the upwardly moving wheel to a pretty quick stop. The pressure rises inside the shock at a terrifically fast rate, perhaps reaching 4,500 pounds per square inch, in fractions of a second, as the wheel stops. If the pressure in the shock is 4,500 PSI, the pressure on the little piece of plastic over the small hole is quite small. Only 146 PSI. (4,500 PSI x 0.032 inch square = 146 PSI) However, the pressure is probably enough to rupture the aluminum shock tube. The hole forms, and pressure is released. In the explosive rush of the fluid out the new hole, the bit of plastic, propelled by the pressure in the system, is blown out the new hole. The outgoing fluid coats the right rear tire, and the driving gets "interesting." Thanks for tuning in, folks ! Image Unavailable, Please Login
All that drama resulting from a tiny little bit of degraded rubbery plastic. Sheesh! Glad you've got things sorted now. All the best, Andrew.
I think also the point not to be missed is that the root cause could be the wrong fluid added to the power steering / hydraulic suspension at some point. That was why I was so careful to flush the system, and to put ONLY the recomended SHELL DONAX TA in when I finished............ Image Unavailable, Please Login
I'm not sure that I am with you on the plugged banjo bolt. I thought the function of the extra fluid tanks and pumps was to adjust the ride height only. In most shocks, the shock is sealed, and the fluid moves within this sealed system through shims and ports in the valve on the bottom of the piston shaft. If the compression stack was not flowing fluid, I would see that as a big problem. The autopsy photos of those shims looked to be in fine shape.
It may be that this is not the ultimate cause, but is a contributing cause to an over-pressure situation.
I may be mistaken, but I thought the "accumulator" function was aslo to accomodate for an "overpressure" situation within the shock body.
I agree. Your thinking has been pretty clear, all along on this. I can only think that, for whatever reason, the "bump" was more than the washers were able to pass at that moment, and that the pressure "spiked" between the piston and the banjo. With the "saving grace" of the accumulator and backflow system denied, the shock body ruptured. You are, and have been, offering great comments. I remain open to suggestions.
Fred: I attended your line of thinking while I was at lunch. I wonder now if the "plastic band" disintegrated, moved to the bottom area of the shock, and then was "sucked up" to the piston area, where it obscured the ports through the piston, during the "heavy compression.". Same effect. Wrong diagnosis on my part.......
Well, maybe I am not mistaken, after all. That is, I was mistaken about mistaken….. There is no air inside this shock (or, there was none when I opened it up) a) The shock body has an inside diameter of 46mm. b) The shock shaft has an outside diameter of 22mm. c) The travel of the shaft is about 120mm. d) The inside volume of the traveled portion of the shock body, without the shaft, is about 200cc. e) The same length of shock shaft displaces a volume of about 45cc. f) The volume of fluid inside the shock body, at full compression, and outside the shock shaft is 200cc - 45cc = 155cc. g) If the shaft is all the way "up", (extended),than assume there is 200cc of volume of fluid inside the shock body. h) If the wheel is to rise, than the shock body must rise. i) If the shock shaft remains attached to the car, than the shaft must enter more deeply into the shock body. j) If the shaft enters the shock body by some amount, the volume available for fluid must be decreased by the same amount as the volume of the shaft entering k) If the captured fluid is not compressible, than it must be displaced. l) Where does it go ? m) If the "banjo" is open, the fluid may compress the "accumulater," and /or re-enter the supply system. n) If the "banjo" is closed, than the fluid cannot escape. o) The pressure will rise - in sort of a square wave function - until something fails. p) Such, as in this case, the shock body. Image Unavailable, Please Login
In the referenced post there are 2 pdfs explaining the operation. It looks like the shock here functions like a remote reservoir shock on one of your bikes. The shock is filled with fluid, and the accumulator acts as the reservoir. Like a bike shock, the accumulator has a diaphragm in it to separate the oil and nitrogen. unlike a bike shock, the pump in the car refills the accumulator to raise and lower the car. There is also a blow off valve somewhere in the system to prevent over pressure. If the blow off valve were to fail in the closed position, or the diagram in the accumulator fail, you could have the hydraulic lock that appears to have blown out the wall of the shock. What are the accumulators made out of? Do they look stronger than the aluminum shock body?
From post # 80 Just an additional information about the system: The pump is of the twin type, one part used for the power steering at a max pressure of 100 bar and the other part is feeding the rear leveling system at a max of 200 bar. The actual pressure in the shocks may raise in peaks up to 140 bar, then the release valve should open up. Also see the PDF in post #87
Correct. I took a look at the portions of the service manual quoted in post #87, and found this: “The pressure in the principle gallery increases up to a maximum of about 120 bar, over which a safety ball valve will open NOTE: for brief instants in particular load conditions it could reach as much as 140 bar.” This should indicate that once 140 bar (about 2,000 pounds) the safety valve opens and relieves excess pressure. Therefore, if the sudden rise in pressure in the shock from my "bump" exceeded 140 bar, than the valve should open, and the extra pressure bled back "upstream" into the system. I have to assume that the bump I hit was foreseeable by Ferrari, and that the system was designed to accommodate just such a "bump." Since the accumulators are designed to also mitigate "spikes" in the shock system, they should also accept pressure from the "bump." In the Ferrari 456 shock system, both accumulators seem to be in the same system, so sudden pressure rises in one shock should transmit hydraulic pressure rises from one shock to both accumulators, and to the other shock. My assumption is that with this much “reserve” in the hydraulic system, there would have been no “explosion” if the pressure “spike could have been evenly transmitted throughout the system. I find it hard to believe that both accumulators, the safety valve, and the other shock could have malfunctioned in a way that would allow the right shock to "explode" without apparent damage to any other part of the system. However, the little piece of plastic now makes better sense.
Been almost a month now, and the car continues to provide much pleasure driving. Found, as recommended on another thread, that the "driving experience" is enhanced leaving the transmission in 3rd while in town. Car now has TUBI mufflers, and a much more satisfying sound, especially between 2,000 and 3,000 rpm. Had to take a trip to Europe, and the schedule worked out exactly wrong ! Arrived in Nice shortly after Monaco GP race, thus missing the expected "Ferrari parade." Went up to Geneva for a meeting at the Large Hadron Collider. Couldn't get any work done, since the French power system had a "total shutdown" that stopped everything. The CERN brass were giving everybody the day off. The LHC uses 10 Megawatts at full chat, and that's a big draw ! Went through Switzerland and down into Italy. Had to be back yesterday, and so also missed the MotoGP race at Mugello. Saw exactly NO Ferrari in France and Switzerland. Got all the way from Como to the Italian Rivera before I spotted a 360 in one of the frequent tunnels. The approaching sound tipped me off as to what was coming. Also was passed in a tunnel by my first personal sighting of the new 458. Nice sounds. Chatted briefly with a 360 owner at Cap Ferrat. Only 3 Ferrari loads of Mazarati. Lots of Aston Martins. One 1958 Edsel, and one early Chrysler 300 "letter Car," both in Switzerland. My rented diesel Ford econobox did not excite, but got great mileage...
What a shocking thread. It dampened my enthusiasm for 456's briefly, but my admiration for the car sprung back in no time.
I was having trouble with some of the same thoughts..... Then, I figured that any car can have improper-maintainance problems. Once I committed to do the repairs in the right way, and (more importantly) thinking I had the problem figured out so that it would not re-appear, I was much more happy with the car and the process. After all, it's just a car. Not nuclear science......
Been about a month now, and I have been able to drive the car with no problems, and increasing confidence. Checked the PS fluid, and found it (cold) below the dip stick, and added about 1/4 liter, which made it a little too full. Realised that (palm to forehead here) that I probably should have checked the level "hot." Good excuse to drive the car a little hard, which I did. Back in the garage, used an all-metal (think auto-zone) turkey baster to draw the level down to the "just right" mark. I am assuming that, with no apparent leaks, that the slight low-level finding was the result of getting all the "disolved" air out of the system. Good as new ? Hope so ! (Before-low) Image Unavailable, Please Login
OK: Finally got a chance to take it out for a test, and here's the "film at 11:00." Turn up the volume........ http://www.youtube.com/watch?v=tU-EPRHuwg4
For those of you who have gotten this far: Car has been running for 18 more months, and has no running problems of any kind. Suspension is perfect ! NO fluid loss ! Since this started, I aquired another 456 (Yes, I know - slow learner...) but a 6-speed. AND, from Fchat's own SF, a BEAUTIFUL TDF Blue / tan 575M F-1. The 456 6-speed - in a deal just concluded - will be race-prepared in a shop for running in Nevada open-road racing. http://www.sscc.us/ I have a driver, who is a previous overall winner in one of the Nevada open-road races. HMmmmmm........ Now we need a navigator...... Reccomendations ? Cheers, Scott
After tons's of 456 rebuilds I found something recently I've never seen before and it definitely is the cause for your shock to explode: Piston band seal worked loose moving below the shock piston and was cut by the shock piston into three pieces; two remained on the shock piston, one migrated to the lower end of the shock, putting it in position to block fluid flow. This unit did not fail; yours did due to hydraulic lock. If you did not replace the internal seals in the shock that didn't fail I strongly suggest you do so. Likely fatigue contributed to the piston seal failure. As Inspector Clouseau would say (in French accent), "case solved!" FYI, "scored" chrome shock rods displaying no measurable wear, this is typical; it's microscopic changes to color and surface that do not affect the sealing capability of the shock rod. It is interesting but no cause for concern. Best, Rob
