Varley Red Top Racing Battery | FerrariChat
Discussion in 'Technical Q&A' started by ExcelsiorZ, May 31, 2007.
  1. ExcelsiorZ
    ExcelsiorZ Formula 3
    1,267
    Beverly Hills
    Does anyone have experience with these batteries? They are super lightweight (e.g., just 6-9Kg depending on size) and said to be the best batteries out there. Pricey though.
    According to their website:
    Main Benefits
    Aircraft derived technology
    Excellent high discharge performance
    No topping up or maintenance is required
    Sealed construction - no electrolyte leakage (even if outer case is damaged)
    Lightweight
    Can be fitted upright or on their side
    Can be stored up to 24 months before use, from full state of charge
    Applications include:-
    Rally Cars
    Classic Cars
    Microlite Aircraft
    Robotics
    FAQs
    For Sealed Lead Acid, Pure Lead and AGM Batteries.
    Can I fit my battery on its side?
    YES - The battery can be installed in any orientation (although inverted is not recommended)
    How can small batteries give as much power
    as large conventional batteries?
    Sealed lead acid batteries from DMS technologies are designed using pure lead tin technology, developed for aviation use with thin lead plates to give low internal resistance and exceptional high rate performance.
    Should I discharge my battery with a bulb to
    Reduce Memory Effect?
    NO. Pure lead technology does not suffer from Memory Effect and may be damaged by this action. Pure lead batteries should not be left in a discharged state but recharged ASAP.
    Will the battery leak acid if it is broken?
    NO- the electrolyte is contained within an absorbent separator inside the battery.
    Do I need to top the battery up with distilled
    water?
    NO- no access is available into the battery and maintenance is not required with this technology.
    What are the common causes of battery failure? Incorrect charging, over discharge and wrong application.
    Can the batteries be used in extreme temperature
    conditions?
    YES. Some of the battery technologies can be installed in temperatures ranging from -65°C to + 80°C
    What determines the life of a battery?
    The life of the battery in a cyclic application is generally determined by temperature, depth of discharge and rate of discharge. For float applications the life is determined by ambient temperature, number of discharges and charge level.
    Are the batteries safe to be transported
    by air?
    Most of our battery technologies are declared non-hazardous for air transportation, however, there are some exceptions.
    Can the batteries be fitted into hermetically
    sealed enclosures?
    Batteries must not be recharged in sealed enclosures as this can cause an extreme hazard. It is possible however, to fit a vent which can eliminate this limitation.
    Can DMS offer designs in different battery
    technologies?
    Yes, DMS has years of experience with different battery technologies and offers advice on design.
    What is the difference between AGM and Gel
    technologies?
    An AGM battery is constructed using Absorbent Glass Mat between the lead positive and negative plates in which the liquid electrolyte is suspended, thus producing a battery with no free acid.
    A gel battery is more similar to a conventional battery however it has a gel added to the electrolyte to limit its movement.
    What is the difference between float and
    cyclic applications?
    A float application is typically where the battery is constantly on charge with the occasional discharge ie. UPS and telecommunications.
    A cyclic application is where the battery is discharged and recharged (one cycle) on a regular basis.
  2. enjoythemusic
    enjoythemusic F1 World Champ
    Apr 20, 2002
    10,676
    Worldwide
    Steven
    i use the Enersys PC680 in the 308GTS QV, works fine, saves weight, very durable.
  3. ExcelsiorZ
    1,267
    Beverly Hills
    Thanks, I'll ring them tomorrow. I wonder if it's the same construction.
  4. AMA328
    AMA328 F1 Rookie
    Nov 12, 2002
    2,518
    ABQ-67me68-OKC :)
    prices on these ?$?
