Hello all, Just received a new set of SS EX valves and ran into a new problem. The manual calls for a minimum valve stem dia. of 7.96mm and the new valves measure 7.91. Has anyone else run into this situation? I have e-mailed Superformance and I am waiting for a reply. I'll never make RA at this rate, not enough time to obtain new valve guides. Maybe next year!!!@%@%
Hello Tom, After reading your next question I can only tell you that you need to replace your valve guides, because you add an extra 0.05 mm clearance. When you order the new valve guides at Superformance you can have them replaced and the exact clearance can be made to the new valves. If you don't do it this way you will have excessive oil burning and you risk your valves getting burned. The new valve guides from Superformance can be installed by an engine repair shop and the valve seats have to be cut again. When this work is done your engine will run like clockwork again after adjusting the valve clearance. Succes
Bronze guides have been pretty much the de facto performance guides for many years. I assume (hope), though I do not know, that a Ferrari engine would come from the factory with bronze valve guides. Bronze guides can run half the clearance of cast iron guides. So while an engine with cast guides would normally run an intake valve clearance of from .001 to .003", the bronze guide replacements could use from as low as .0005 to maybe .002" at max. We generally used clearances of .001 to .0015 for intakes and about a half a thou more for exhausts. Large clearanced engines, which some people like to build, are often referred to "loose" engines. Folks claim that they make more power out of the box that way but it's just a license to burn oil. IMHO "loose engines" is just another term for sloppy engine building. Of course the "slop" inherent in factory engine building/clearance tolerances up until fairly recently was the reason that one new engine might burn a quart of oil in 6-700 miles and another new engine burn the same amount in 2000 miles.
Thanks for those replies. Would that still be manganese broze? Just curious, as a friend used to export many tonnes of the stuff every month.
There are a bunch of different bonze guide formulations, Phospher bronze was probably the most common and it was used a lot to "sleeve" worn iron integral valve guides. Manganese-bronze was another common bronze guide material. Manganese-silicon-aluminum- bronze guides were considered to be the best by many engine builders as of a couple of years ago. That, like everything else, may have changed. Note, I said "was" in my reply because I know what was what with this when I was doing it but I quit in '06 and don't want to speak as if what was true then is true now - I don't know.
Thanks to all, I think this project will be the one to teach me patience! I should have a full set of shims by the time the heads get back on.
As it turns out the spec. in the manual was not correct. I am told that is NO surprise! Anyway the stem dia. of the new valves is the same as the original at 7.91 and not the 7.96 as listed. Thanks all!
Are you dropping the valves with the shop? I'd certainly advice to test-fit the new valves in the exisitng guides before permanently fitting it all.
Per what Jack said - you absolutely need to check the valve to guide clearance and further, I suggest you do NOT put new valves in old guides. I know people do it all the time but it's not the proper way to do things on an engine that isn't going to be "refreshed" regularly (like a competition engine). I don't know if you are trying to do this yourself but if so, I do not recommend it. Take the heads to a shop, have new guides installed and the valves/seats machined properly. This is a very critical area both for engine breathing and oil control. Minor flaws in setup will have a noticeable affect on potential power and oil use. If you do this yourself - and certainly people do - unless you have the EXPENSIVE equipment necessary, you can only provide a single-angle valve seat. This is not efficient and even in the 60's a 3-angle valve job was common for performance engines being reworked. 5 angle valve jobs were common for performance engines as of a couple of years ago but the actual application for the engine will dictate the optimum type of seating. A good multi-angle valve job will essentially add several tenths of an inch of valve lift without actually changing the geometry of the valve train. This is "free" HP. It's free in the sense that no performance parts are required with associated reliability issues.
I agree, I agree----------------------but-------------------------- I admit that the word practical does not apply to a Fcar but to get real the car has 27K on the clock and the only trouble I had when I purchased it was a terrible idle. I find that the guide to valve clearance could be a little tighter but the practical side of me says I will not regularly redline the motor or leave bits of the over-priced TRXs on the pavement so after lightly lapping the new SS valves to check the seating I will put the motor back in and spend my time bounching the sodium valves off the floor to see if they will break!!! This way I may get back on the road before the snow hits! Cheers
Reading back through one of your posts, this engine at a mere 27K miles, had low compression in one cylinder, hence the terrible idle. Although replacing the exhaust valves (worn and sodium, I presume), will solve the problem at hand, how will this fix the problem, long term? Valve to guide clearances are typically.0009-.0019" on a 2-valve. With unknown guide clearances...and likely tapered bores, your "valve job" likely will be very short lived, as the valve is going to be flopping around inside the guide. Other the higher than normal oil consumption and accelerated valve seat wear, which will result in doing this job all over again far sooner than you really should have to, what's the "upside", other than you'll get the car back on the road sooner versus later? I'll agree with you that practical doesn't apply to an "Fcar", but why not just spend a tiny bit of extra time and money...and do it right the first time, so that you can enjoy the car the way they were meant to be driven? Mike996, in his earlier posts, give some great, solid advice on how to properly do this job. I don't think there's an engine builder in the world who would disagree with what he's saying! Best, David
No disagreement what-so-ever! I would suppose it's my preference to drive it rather than look at it. When I get 10K more on the clock and I am not happy with how it runs then ,in my way of thinking, it will be time to blueprint the engine but I seriously doubt that will be the case since the biggest problem with mine was the previous owner/owners. In closing, I doubt that this engine left the factory with a .0015" stem to guide clearance. Thanks for taking the time to respond. The Winer
You're welcome...and sadly, more than a few motors (that I've seen) have left the factory with "loosey-goosey" valves. Sometimes you just have to whip out the old yardstick to measure the valve slop...LOL!!! Good luck with your car! David
The seal shown by Ricambi for use on the 328 looks like a modern, good quality seal. As long as the seal is something like that - a positive seal that firmly attaches to the guide as opposed to an "umbrella seal," it is about as good as you can get. As a side note, in engines that used umbrella seals originally, the guides have to be machined to accept the positive seals. http://www.ricambiamerica.com/product_info.php?products_id=199328
Yes, there is... It may look like quality seal, but it's not!!! This is the same old crap that has been in the engine kits for years. As I recall, it's the very old Perfect Circle T9010 seal. The ideal seals for these cars are what's used on a BMW M5 and certain VW models, depending on if your engine uses a 7 or 8mm valve. These stem seals are made with viton, typically green in color...and do a far between job of controlling oil, particularly as the engine ages since the "sealing" part has a bit of "give" to it, versus the rigid telfon seal. David
Thanks, David That's what I was recalling, I guess, the BMW alternate... There ya go, lostbowl, that'll help some....and use those NGK BP5ES flamethrowers....you'll be golden. Alan
........and send me one of those valves you drop on the floor, JRV's not around, to school me, anymore.....
David, good info! I was just looking at the style of seal - a positive seal - when I made the comment. I wasn't thinking at all about the material itself.
Mike, It does look like a great seal...but, a) The fittment is way too tight on the valve stem b) Over time, they get brittle c) I've seen too many of them break apart and end up in the oil pan d) As the guide wears, the seal "hole" tends to elongate...giving up oil control The "softer", more resilient Viton seal doesn't look as purdy, but sure is more functional... Best, David
The seal info is good, but needs its' own thread. I was under the impression we were talking about exhaust valves? Wrong side of the head!
Probably I just mentioned it, as he is that point of disassembly and the valve guide discussion brought it to mind......
Thanks again for the good info--------------------- the valve stem seal info is good stuff! On what I hope to be the end of this "tale of two valves" I would pass this on to other newbies----------------- I have read allot about these sodium filled valves and I had to try a few things for Shi---s and giggles. First off we are talking about a car with 27K on the clock (82 308) and I believe the miles to be accurate because of wear indicators on the rest of the chassis. I agree with changing out the valves just because but I did drop the valves on the shoppe floor one at a time and nothing happened-----then all at once (several times) then I started throwing them down, one at a time and then all at once. several times. After scaring the concrete many times with no adverse reaction I put one in a vice and slightly tapped it and finally it broke and then another broke and then one broke in two pieces. My point is there was not a consistant breaking point. If I had it to do over again would I? Knowing what I do now it is doubtful that I would have changed them out but the added piece of mind is worth something. While waiting for parts I cleaned everything up and wrinkle painted the cam and belt covers and came to the conclusion that VHT wrinkle is pretty good and Plastic Coat wrinkle is crap! They are both touchy to work with but the VHT yields much better results. Point of interest------ try and spray the surfaces that are on a horizontal plane indexing the part so you can lay the paint on very heavy without sagging. This takes time but I also find that after many successive coats it becomes neccessary to scuff and repaint if the wrinkle does not happen so taking the time to spray only in the horizontal position yields superior results. Waiting for more shims------------------- Tom
