360 - Valve cover nut access | FerrariChat
360 Valve cover nut access
Discussion in '360/430' started by 78bonanza, Dec 14, 2019.
  1. 78bonanza
    78bonanza Formula Junior
    Apr 1, 2018
    331
    Jim Cear
    I’m trying to access the top row of valve cover nuts to insure they are at the correct torque( approx 7.5 ft/lbs) .
    How is the black plastic ignition wire cover removed to gain access? I’ve search here and in the shop manual without success .
    Thank you
  2. timwu12
    timwu12 Formula Junior
    919
    TX
    That’s the electrical lead for the fuel injectors and each of them have a spring clip that you need to push in from underneath the bar.
    It’s a pain to get all 4 clips pushed in and lifted off the fuel injectors but patiently work at it and you’ll get it off
  3. 78bonanza
    Apr 1, 2018
    331
    Jim Cear
    Thanks . The whole injection assembly popped out enough to check the valve cover torques
