430 - Valve Cover Gasket Replacement Cost | FerrariChat
430 Valve Cover Gasket Replacement Cost
Discussion in '360/430' started by fga4, Apr 24, 2019.
  1. fga4
    fga4 Karting
    Jan 2, 2017
    119
    SF Bay Area
    Jerry Cellilo
    Took my 2008 F430 in for the annual and mechanic noted a very light leak on each rear left of both valve covers. I let it go because I can drive 100 miles and I'll see maybe a drop or two. The Mechanic told me the repair was an all day job which in this area is around $220-240 US an hour at most of the shops. It does look like a lot of labor. I note there are additives that can stop leaks like Bar's Leak Seal Repair but is that advisable?
  2. Skidkid
    Skidkid F1 Veteran
    8,762
    Campbell, CA
    John Zornes
    Coupe or Spider? Big difference in the effort
  3. E55amg9965
    E55amg9965 Karting
    Jun 13, 2012
    98
    South Florida
    Joe
    I wouldn't use any stop leaks additives to your car,ether deal with a small leak or fix it.Those products cause me harm then good.
  4. JoeTSI
    JoeTSI Formula 3
    1,433
    Huntsville, AL
    Joe K.
    Did you ask if they were torqued to spec? Also, it is advisable to change the cam seals as well when doing the VC seals, so that is where the majority of labor goes. At least with regards to the 360.
  5. RedNeck
    RedNeck F1 World Champ
    10,011
    The CSA
    Me
    I could be wrong, but I don't think the 430 has separate cam seals like the 360...but in the 360, the cam seals are right there in the open, why would the majority of labor be there?
  6. Bob in Texas
    Bob in Texas F1 Rookie
    Apr 23, 2012
    2,667
    Just East of Weird
    Bob
    Definitely a big job. Mine were leaking/weeping and I had the dealer put new gaskets on. IIRC it was $1900, all but $200 was labor
    Sent from my iPad using Tapatalk Pro
  7. Zed82
    Zed82 Formula Junior
    Sep 28, 2017
    490
    Sweden
    About 8h of labor.
  8. CarAholic
    CarAholic Formula Junior
    May 10, 2016
    514
    I know my Indy only charged for 5 hours of labor for mine and the labor rate was about half what you posted.
  9. Skidkid
    Skidkid F1 Veteran
    8,762
    Campbell, CA
    John Zornes
    His rates are right for our area.
  10. fga4
    fga4 Karting
    Jan 2, 2017
    119
    SF Bay Area
    Jerry Cellilo
    #10 fga4, Apr 25, 2019
    Thanks all for the tips. Yeah, will stay away from additives. It is a coupe and I will figure 2 grand. Will do it with next oil change but watch it til then. I always pop the engine bay up to help cool it down so easy enough to check. Bolts are tight to spec.
  11. whatheheck
    whatheheck F1 Rookie
    Mar 27, 2006
    4,138
    Seattle, Wa
    Dan L.
    Its a common issue for F430's...............
    Mine was replaced by previous owner 4 years ago and he paid $2K.
    4 years later (2 months ago) it's seeping again...............
    Im not aware of any better aftermarket gasket seller.
    There's a post here somewhere that another member recommended adding a gasket sealant.
    I plan to do replacement myself sometime later this year.
    Same as yours, very minor leak.
    Just watch out for the minor oil leaking out as it can get into the Variator Solenoid Control Valve connectors.
    When that happens the variators will send a faulty reading to the ECU and a check engine light will pop up with a fault code P0024
    Dan
  12. Motob
    Motob Formula 3
    Nov 11, 2003
    2,239
    Frederick, Maryland
    Brian Brown
    It is actually the variator solenoid valves themselves that leak. The oil is pumped out up through the wiring of a defective solenoid and into the connectors, were it leaks out externally and causes poor electrical connections/faults.
    Zed82, Red 27 and whatheheck like this.
  13. whatheheck
    Mar 27, 2006
    4,138
    Seattle, Wa
    Dan L.
    Ah, got it. Now I know.
    Thanks for the great info!
    Dan
    Sent from my SM-G955U using Tapatalk
