V12 Lusso - Lowering and Spacers... Help Please | FerrariChat
Discussion in 'FF/Lusso' started by BrntRubber, Mar 1, 2020.
  1. BrntRubber
    BrntRubber Karting
    Feb 18, 2020
    88
    Farris Alnaqeeb
    So my new Lusso has every key option I could want with the exception of suspension lift. I posted about not having this option and it didn’t seem to be a big deal on the car.
    Attached are pics which show the car sitting quite high. I don’t know how much travel is available on the oem coil overs but I intend to lower her a bit (springs needed?) and potentially fit some spacers.
    Any advice? I also don’t want to be bottoming her out all the time.
    Here she is
  2. gilly6993
    gilly6993 Formula 3
    Aug 20, 2009
    2,478
    Longmeadow, MA
    Eric
    Depending on your roads it may or may not be an issue.....
    Il Co-Pilota likes this.
  3. uhn2000
    uhn2000 Formula 3
    Oct 15, 2011
    2,109
    Toronto
    Joe
    Lower the beast .5 inches and you can put spacers on it as well, 15mm in rear and 10mm in the front :)
  4. Bmill
    Bmill Karting
    190
    California/Minnesota
    Brad
    Question.. do you need to do an alignment if you just lower on the Oen coil overs?
  5. uhn2000
    uhn2000 Formula 3
    Oct 15, 2011
    2,109
    Toronto
    Joe
    No idea bud. Sorry.
  6. Gh21631
    Gh21631 F1 Veteran
    8,336
    East
    yes, you should always do an alignment if you change anything with the suspension.
    Bmill likes this.
