Using diesel oil...will it damage my catalytic conv? | FerrariChat
Discussion in '308/328' started by Tifosi2011, Aug 25, 2011.
  1. Tifosi2011
    Tifosi2011 Formula Junior
    Apr 3, 2011
    307
    Burnaby, BC Canada
    If I were to use Shell Rotella diesel oil, would it damage my catalytic converter in my 85 308 QV? The weight I'm considering is 15W-50. Thanks for everyone's input.
  2. doug_porsche
    doug_porsche Karting
    Dec 6, 2009
    147
    Trying 2 find myself
    Doug
    Long term, it will not help the cat, but will not kill it in a well maintained car.
    The Diesel oil is higher in zppd, which is harder on cats.
    This does not mean it will kill the cat, like say using leaded fuel would, but its not ideal.
    Older cars, I know more about air cooled Porsche 911's than I do 308's, do need zppd. Zppd is good for flat tappet cam shafts, so it is a necessary evil.
    Hopefully someone can tell you if the 308's need it.
  3. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,825
    Mike 996
    Yes, it will damage the cat. How quickly will depend on the zinc/phos in the oil and the amount of blowby in the engine. If you have to add oil fairly frequently then you can expect cat life to be much shorter. There are a lot of studies re the ZDDP issue. MY PERSONAL CONCLUSION, after reading a lot of data data from oil companies and car/engine manufacturers is that any oil with more than 800PPM of zinc/phos is adequate. Many "normal" oils have that. For example, Mobil 1 0W40, which I now use, contains 1100PPM.
    My advice is to do the research and do whatever you are comfortable with. But DON"T use data from somebody trying to sell you an additive - like ZDDP - as part of your decision. Unless you are knowledgeable in oil formulation, leave the additives on the shelf; let the oil engineers blend the oil. If you are convinced that you need the levels of some of the racing oils - around 1800PPM - then I would use them and just replace the cat as needed or remove it for normal operation and replace it when emission inspection is required.
    FWIW - the oil you are talking about is much heavier than Ferrari's recommendation, which, as of the mid/late '90s, was 5W40 for all V8 engines, regardless of year.
  4. Peter
    Peter F1 Veteran
    Dec 21, 2000
    6,440
    B.C., Canada
    John, have you applied and received your Collector Plates? If so, you do realise you will have gone through Aircare once, so after that, if the cats have suffered, it's not much for you to worry about.
    If you're wearing regular plates, then you'll have to go to Aircare every year and that may affect it.
  5. Tifosi2011
    Apr 3, 2011
    307
    Burnaby, BC Canada
    Hello Peter. Yes, I have received my collector plates. I understand that I don't have to go through aircare anymore. I was just concerned that if ever I were to sell my vehicle, I wanted to be able to tell the new owner that the catalytic converter is still in great shape. When I purchased the car, the previous owner had just replaced the cat. I just did not want to harm it in any way, or at least expedite the process.
  6. Peter
    Peter F1 Veteran
    Dec 21, 2000
    6,440
    B.C., Canada
    If the car is not consuming massive amounts of oil (which, basically ends up going through the exhaust system as vapour), then the cats should last.
  7. MNExotics
    MNExotics F1 Rookie
    2,631
    Good Thunder
    Ben Gruenzner
    What's a catalytic converter?
