Upgrading the Ferrari California T Sound System with Aftermarket Components | FerrariChat
Discussion in 'California/Portofino/Roma' started by XSpeed, May 25, 2019.
  1. XSpeed
    XSpeed Formula Junior
    Jan 6, 2019
    408
    SX
    Hi Everyone,
    I have the premium sound and I'm not happy with it like many of you, so I'll upgrade it with aftermarket speakers/amps. I wanted to get your opinion whether the setup below could work or there are additional things I'd need to consider.
    I don't have a budget limit. My concern is more about whether I should make any changes in the car which are not reversible, at the same time if the difference between option A and B is very significant, I can choose A.
    I found the existing California T setup information here: https://www.atd-sportscars.com/ferrari/california/t/parts/audio-speaker-system-0141.html
    I'll have them installed by a professional company, which will also do the sound deadening. Right now I just want to decide on the parts and which option I should take.
    I have two options:
    A - Upgrading the sound system completely
    B - Upgrading existing speakers only
    A - Upgrading the California T sound system completely:
    This is the setup I thought about. Do you think it makes sense?
    Speakers:
    5 x Tweeters Focal Utopia M TBM ( 2x door, 1x front center, 2x near rear speakers)
    3 x Front midrange Focal Utopia M 3.5WM
    2 x Door midbass Focal Utopia M 8WM
    2 x Rear - Focal Utopia M 6WM
    1 x Subwoofer Focal Utopia M SUB10WM
    Amps/DSP:
    1 x DSP Mosconi/Gladen 8to12 Aerospace
    1 x Amplifier for tweeters and midrange Mosconi/Gladen Zero 4
    1 x Amplifier for midbass and rearfill Mosconi/Gladen Zero 4
    1 x Woofer Mosconi/Gladen Zero 3
    B - Upgrading existing speakers only:
    Just replacing the existing premium audio speakers (current ones are from JBL I suppose) with the following. Do you think that'd work? Would switching to these speakers be easy without major changes - just replacing them? Would these work without an amp upgrade? Would it be possible to add a DSP to this system and still use the stock amp?
    2 x Rear Focal Utopia M 6WM
    Thanks a lot for your valuable feedback.
  2. Rule12b
    Rule12b Karting
    Jun 4, 2018
    102
    Richard
    Where are you located? I would visit an absolutely top shop (like La Jolla Audio in San Diego) because they may have specific experience with the Cali T. If you are going to change out the speakers, you may as well upgrade your power, not necessarily more power (probably though), but better, cleaner and better. This is especially true if cost is not really a factor. You aren't adding much labor if you are changing out the head unit and speakers already.
  3. TooHot
    TooHot Rookie
    Apr 15, 2007
    29
    Florida
    Gene Lorenzetti
    Can u tell me where i can find out how to remove radio on california t
  4. Il Co-Pilota
    Il Co-Pilota F1 Veteran
    May 29, 2019
    6,023
    Hopefully some place nice.
    A.B
    First off. The Gladen stuff is okay, but absolutely ridiculously priced in the US. It's not a high end brand and here in its native Europe, it is priced much more reasonably. If you want to use high quality amps, either Zapco or Brax is a good choice.
    Unless your installer is willing to spend a lot of time figuring out placement etc. of those tweeters, don't go with the Focals. Yes, they are very nice, but they are also extremely sensitive to placement. Not sure why that is, but many Sound Q competition guys have actually given up on them after fighting overly bright spots and issues with reflections for months. They are not a good choice for stock location installations.
    If you want to go high end on the speakers, go with the Dynaudio Esotar line. They integrate well, and are in the ears of some of us, superior to the Utopia stuff.
    If you go this route, you need to run the system fully active with something like the Audiocontrol DM810, Zapco Gen 5 DSP or Audison Bit One. You need to be able to time align the drivers to your seating position. If you don't, there's no point in throwing that much money at the system.
    If you want to keep it more simple, and not upgrade the electronics, the Dynaudio Esotec line is a great choice. It will accept an input that is less than stellar, but still put out a very nice and smooth sonic image. The weakest point of that "upgraded" "JBL" system is those low budget drivers. They are utter China garbage and has zero to do with the JBL Pro stuff of the 70's and 80's.
    A nice middle ground would be an active system that uses the Dynaudio Esotec drivers with the Audiocontrol D-6.1200 amps. While budget is unlimited, you have to consider what works well in your installation. Simply throwing the most expensive components at it won't give you the best result. As long as you use the stock headunit and stock locations, there's a chance that the most expensive speakers with the highest resolution could cause more issues than a lower level setup. Don't get me wrong, the Dynaudio Esotec is by no means free or cheap. It is just not stratospherically priced like the Esotar and Utopia M. They are still very nice components and more than capable of fulfilling the needs of most critical listeners.
    So, for option A. I'd do this
    5 x Dynaudio Esotar 110 highs
    3 x Dynaudio Esotar 430 mids
    2 x Dynaudio Esotar 650 lows for front
    2 x Dynaudio Esotar 650 lows for rear (not sure why you would want these though)
    1 x Focal SUB10WM
    Amps
    2 x Zapco Z-150.6AP for components
    1 x Zapco Z-KD.II for sub
    DSP
    Zapco HDSP-Z16 V AD-16
    Option B.
    5 x Dynaudio Esotec MD130 highs
    3 x Dynausio Esotec MD142 mids
    2 x Dynaudio Esotec MD172 lows for front
    2 x Dynaudio Esotec MD162GT Lows for rear
    Option C.
    Same as B, but with the addition of the Focal sub and the following DSP amps.
    Audiocontrol D-6.1200 x 2 for components
    Audiocontrol LC-1.800 x for sub
    As long as you don't change the head unit, I'm a fan of option C. The Audiocontrol stuff works so well for integrating with OE systems, and the stock head unit is a bit of a bottleneck.
    mikey k, whatheheck and XSpeed like this.
