Upgrading A/C and Radiator While I'm In There | Page 11 | FerrariChat
Discussion in '308/328' started by Ferraridoc, Oct 20, 2019.
  1. Ferraridoc
    Ferraridoc F1 World Champ
    Jun 20, 2012
    16,192
    Gold Coast, Aust.
    Patrick
  2. Ferraridoc
    Jun 20, 2012
    16,192
    Gold Coast, Aust.
    Patrick
  3. Ferraridoc
    Jun 20, 2012
    16,192
    Gold Coast, Aust.
    Patrick
  4. Ferraridoc
    Jun 20, 2012
    16,192
    Gold Coast, Aust.
    Patrick
  5. Ferraridoc
    Jun 20, 2012
    16,192
    Gold Coast, Aust.
    Patrick
    I needed to somehow provide cooling to the a/c fan controller. There are two holes in the centre vent plenum, which I normally block off. I wanted to plug a tube into one of them to direct cold air onto the circuit board, but it had to be a certain shape. Luckily, I never throw anything out, in case it might be useful one day. About 8 years ago, I replaced all the heater hoses, and had a few odd bits left over. One of them... fit... perfectly. Naturally, I told my wife...
    Sent from my SM-N920I using FerrariChat.com mobile app
  6. Ferraridoc
    Jun 20, 2012
    16,192
    Gold Coast, Aust.
    Patrick
    Saabguy and Milkshaker0007 like this.
  7. DMWC
    DMWC Formula 3
    Jan 23, 2013
    1,729
    Sydney Australia
    David C
    Pat - I am enjoying tracking your progress
    It’s put me off attempting anything like that on my car
    Back in the pre upgrade days, did your Air Conditioner Condenser drop a lot of condensate from your humid Gold Coast air onto the ground when you parked the car ?
    I am surprised how much moisture pools under my car after I am parked for a while on a humid Sydney day.
    Does this photo show a similar amount of condensate that your car generates ?
  8. Gizzi
    Gizzi F1 Veteran
    Dec 3, 2011
    5,183
    Brisbane, Australia
    Gezim
    That comes from the evaporator inside the car David. The condenser gets hot. The evaporator removes the moisture and cools the air. And yes, there is a LOT of water
    Crowndog likes this.
  9. Ferraridoc
    Jun 20, 2012
    16,192
    Gold Coast, Aust.
    Patrick
    Lots of heavy breathing in your car?
    About all I can think is your condensate drain might be partially blocked and water builds up in the housing. Have you ever had cold water drip onto your feet?
  10. Ferraridoc
    Jun 20, 2012
    16,192
    Gold Coast, Aust.
    Patrick
  11. DMWC
    DMWC Formula 3
    Jan 23, 2013
    1,729
    Sydney Australia
    David C
    Hi Gizem - that’s what the technical part of my brain is telling me but my eyes (admittedly in a poorly lit garage and with the car not elevated at all) show the water eminating from up near the condenser
    I assume the evaporator has a drain that must discharge in that location
  12. DMWC
    DMWC Formula 3
    Jan 23, 2013
    1,729
    Sydney Australia
    David C
    No water on my feet - yet
    Air blowing into the cabin is farkin cold - which is nice
    I still get very excited driving my car so the heavy breathing is all mine
  13. DMWC
    DMWC Formula 3
    Jan 23, 2013
    1,729
    Sydney Australia
    David C
    Sydney is quite humid at the moment - the fires will return soon and the humidity will disappear again
    Where does the condensate from the evaporate drain exit the car ?
    Is it up near the condenser ?
  14. Aircon
    Aircon Ten Time F1 World Champ
    100,524
    Melbourne, Australia
    Peter
    No.... Should be fairly much under the evaporator. You should be able to see the hose out the bottom of the car
  15. DMWC
    DMWC Formula 3
    Jan 23, 2013
    1,729
    Sydney Australia
    David C
    It’s definitely a by-product of the A/C system as it was not happening before I replaced the compressor and got the A/C system working
    The Instruction Book that I have lacks sufficient detail to see where the condensate discharges so I will need to get access underneath the car and see WTF is happening and where that hose is and whether the liquid that is pooling under the car is coming out of that hose
  16. Aircon
    100,524
    Peter
    Of course it is. It's probably doing more now because the Aircon is working so well.
    Just stick your head under the car. You'll see the hose sticking out unless someone has screwed with it
  17. Ferraridoc
    Jun 20, 2012
    16,192
    Gold Coast, Aust.
    Patrick
    You can see the hose in post 158. You can pretty much reach behind the front wheel and touch it
  18. Ferraridoc
    Jun 20, 2012
    16,192
    Gold Coast, Aust.
    Patrick
    I didn't think Aircon ever worked...
    Gizzi likes this.
  19. Aircon
    100,524
    Peter
    Hilarious....just hilarious.
    Accurate too.
  20. Aircon
    100,524
    Peter
    Where? I can't see it
  21. Ferraridoc
    Jun 20, 2012
    16,192
    Gold Coast, Aust.
    Patrick
  22. Ferraridoc
    Jun 20, 2012
    16,192
    Gold Coast, Aust.
    Patrick
    Milkshaker0007 likes this.
  23. Ferraridoc
    Jun 20, 2012
    16,192
    Gold Coast, Aust.
    Patrick
  24. Ferraridoc
    Jun 20, 2012
    16,192
    Gold Coast, Aust.
    Patrick
    So the bottom a/c pipe fitted OK, but the top pipe took a bit longer to make, as I was very specific about the dimensions. Finally got it yesterday, and... it looked way too big. Here it is next to the guide I made
  25. Aircon
    100,524
    Peter
    Yesterday......Friday traffic.....40 degrees Celcius.....a/c coping now problem. Car temps normal. Why have you wasted your time?
