Understanding Air fuel ratio sensors (wideband) | FerrariChat
Discussion in 'Technical Q&A' started by mjz, Jan 20, 2020.
  1. mjz
    mjz Karting
    Aug 3, 2007
    163
    Houston, Texas
    Michael
    This is a generic question regarding AF sensors.
    On my non-Ferrari two bank toyota daily driver, It has two AF sensors that report anywhere from 0 to 5 volts (nominal) when engine is running and at temperature. On one bank, a brand new sensor I installed a few weeks ago reports 3.3 volts rock steady. It varies at most from 3.1 v to 3.7 v.
    But on the other bank, the real time reading swings all over from a low of 1.2 to a high of 4.7. It averages around 3.3, but wonder if it is a faulty AF sensor? It is about 4 years old but only 10,000 or so miles. Car is 20 years old and just runs so I've kept it.
    Is this normal?
    Car idles fine, no DTC codes whatsoever, but there is a hesitation on hard acceleration off the line (no issue above 2,000 rpm). I run with Shell gasoline same as the Ferrari (nitro).
  2. Rifledriver
    34,031
    Austin TX
    Not normal but should not be causing your hesitation. During full throttle car reverts back to pre programmed fuel mapping and ignores whatever influence the O2 should have. O2 really only effects steady state running and can effect long term fuel trim but not really full throttle.
    Qavion likes this.
  3. Ianjoub
    Ianjoub Formula Junior
    Dec 22, 2019
    901
    Homosassa, FL USA
    Ian Joubert
    Swap them side to side and see what happens. You will know if it a sensor problem or giving you good info on a mechanical problem.
  4. mjz
    mjz Karting
    Aug 3, 2007
    163
    Houston, Texas
    Michael
    Good idea - only issue is getting to it (close to firewall, require a lift to get at it from underneath).
    I know the coilpak's and spark plugs are good ... which leaves 20 year old 100k fuel injectors. I wonder if one or more of them is sluggish/dirty) causing the hesitation and swinging AF sensor voltage. Fuel trim on this bank also swings quite a bit (+/- 10-15 %).
    I thought about a professional fuel injector cleaning, but read it's mostly hype. This car does sit around a lot and I did put red line through it with no change.
    I'm just guessing before I decide it's time to get rid of the car.
    (my wife can't imagine why I keep this thing (2000 lexus), but it just runs and looks great still (interior is mint)....that is...up til now.
  5. f355spider
    f355spider F1 World Champ
    17,939
    Injector cleaning does work. But who knows if that is related to your issue or not?
    This shop has a lot of good info on injector cleaning and their process.
    https://witchhunter.com/process2.php
