twin turbo or ecu upgrade for 458 | FerrariChat
Discussion in '458 Italia/488/F8' started by 458italia2014, Oct 16, 2013.
  1. 458italia2014
    458italia2014 Formula 3
    Aug 3, 2013
    1,048
    I am wondering who has either got an ecu upgrade for more horsepower or has gone and twin turboed their, say by underground? I am curious what people have to say about how their cars changed and their experiences, both positive and negative. Thanks!
  2. Evan.Fiorentino
    Evan.Fiorentino F1 Rookie
    Aug 23, 2005
    2,854
    South East Florida
    Evan
    #2 Evan.Fiorentino, Oct 16, 2013
    Fabspeed has been able to make verified (both by us, and independently) results of huge power increases from an exhaust and tune. I sent you an PM :)
  3. RossoDiamante
    RossoDiamante Karting
    Jun 3, 2013
    214
    Mid-Atlantic, US
    That is an impressive looking graph. As a non-technical type person, the common wisdom that I've heard is that reducing exhaust backpressure with free-flow cats and mufflers (or straight pipes) can reliably increase high-RPM horsepower, but at the expense of low-RPM torque. I don't see this tradeoff evident in these graphs. Is there something I'm missing? This looks like having your cake and eating it too.
  4. Cuonuct
    Cuonuct Karting
    Sep 18, 2013
    192
    Heffner Perfornace twin turbo is probably the best, most reliable one you can get. It boosts the cars performance to the outstanding 700hp
    Heffner Performance
    If you're located in the USA that's probably your best bet.
    I think the package includes a new exhaust system, too. ;)
  5. 458trofeo
    458trofeo F1 Rookie
    Feb 4, 2013
    4,426
    City of Angels
    101 aki
    fill her up with 100 octane and you'll get 500hp at the wheels :)
  6. kverges
    kverges F1 Rookie
    Nov 18, 2003
    3,179
    Dallas
    Keith Verges
    450 hp stock seems awfully low to me and while I am a big believer in modest power gains from exhaust and tune, I find it hard to believe that the engineers in Maranello did such a crappy job in designing the exhaust system and tuning the car that they left 87 rwhp on the table. That's over 20% more power at 8000 rpm.
    I was expecting more like 485 rwhp stock and 510 or so modified.
  7. RBK
    RBK F1 Rookie
    Jul 27, 2006
    3,105
    Calif and Nev
    Bob
    Please send same dyno comparison. Never seen that happen. Best
  8. radix
    radix Karting
    Dec 2, 2010
    234
    Hey, we got 90Hp/60ft-lbs out of an exh+tune....
  9. DK308
    DK308 F1 Rookie
    Aug 13, 2013
    2,738
    Europe, way north.
    AB
    I don't think the 450 is neither off or bad, I think it has to do with the drivetrain. The SLS which develops the same power, dynos about the same rwhp. The dyno sheets and a few dyno sessions I've seen with SLS cars, have dynoed around 450 too. Mercedes are usually not "lying" when advertising chp. They use SAE J1349 correction as most others do, it's pretty much the international standerd. Don't forget that dyno room enviroments and dynos vary as well. It's pretty much impossible to say, before someone puts an engine on a dyno. What should be considered, is the difference measured on the same dyno. I've never seen any manufacture mention what the parasitic loss on the DCT's are, but an AMG guy I spoke to back in the spring, said that he'd calculate a loss of 19-21% through the entire SLS drivetrain, which is very similar to the 458 drivetrain.
    I'm no expert, just my o2's.
    +1
    I've seen cars remapped for high octane fuel, but that's the only case of increase in power due to running high octane.
    50 hp extra makes no sense from upping the octane on an n/a engine. The 458 is set up for 95 RON (91AKI) octane. Octane has nothing to do with the amount of energy available from the fuel. You need higher density for that. And 100 RON will burn slower than 95 RON, hence possibly not utilize all the fuel and just spit it into the exhaust, creating pops burbles, and possibly soot. Unless Ferrari set the engine up for high 100 RON fuel, the sensors can pretty much only make the energy go down, if the fuel is inadequate. To my knowledge, knock sensors will retard ignition timing and o2 sensors will restrict fuel delivery. both resulting in a possible power loss, and in some cases better fuel economy.
    Without any experienc with them, it looks like Fabspeed has a nice package for the 458. I'd personally much rather do that, than the turbos, but hey, that's me.
    Good luck with it.
  10. Ky1e
    Ky1e Formula 3
    Mar 4, 2011
    1,252
    FL
    Here we go again...
  11. Noblesse Oblige
    Noblesse Oblige F1 Veteran
    Nov 7, 2011
    6,114
    Three Places
  12. Woppum
    Woppum Formula Junior
    Dec 24, 2010
    677
    I'd love to believe there were big gains to be had from a map and set of pipes but simply don't. I've tried if before with other high strung n/a cars . Some 'feel' faster due to throttle mapping but really are not and others I actually think have made the car slower. Not worth it.
  13. Noblesse Oblige
    Nov 7, 2011
    6,114
    Three Places
    Yes, it is very hard to get meaningful gains from a high specific output N/A engine. After all one is starting here with 127 hp per liter. Reduced back pressure from high flow cats or test pipes might give incremental gains when coupled with a remap, but at huge dollars per additional horsepower. These measures also tend to reduce low speed torque, possibly affecting driveability.
  14. RBK
    RBK F1 Rookie
    Jul 27, 2006
    3,105
    Calif and Nev
    Bob
    Not just adding 100 octane though. "Tuning" is a bottomless pit depending on who is doing it and if only ecu or more. I was responding to adding a different octane. Best
