I've had the car now almost 17 years & I have never had a problem of this sort. The battery is a couple of years old but I've tested it and it's in good condition. For good measure I even put it on charge overnight to rule it out of the equation. The car has an immobiliser/alarm fitted. Here's the problem: 1. Put the immobiliser 'tag' in to disarm the immobiliser - all good 2. Switch on the ignition, pumps start whirring away - all good 3. Turn key to engage the starter motor and I get a clicking noise - not good I won't publish my dim-witted guesses as I suspect better suggestions will be provided. The only other point to note is that over the last few months the temperature gauge appears to have an intermittent short causing it to flick from the correct reading round the dial to the maximum temperature when the car goes over a bump. I have my voltmeter at the ready...
Andy, either your battery couldn't hold the chage even when charged overnight , means bad battery or you have loose or poor connection somewhere. Have you tried jump starting it?
Good idea - not sure how I am going to do that but it makes perfect sense. Thanks. I'm confident the battery is not the problem. Any ideas what the clicking sound would be? My thoughts were that is was the starter failing to engage?
Clicking sound is usually starter solenoid firing off, but not able to energize starter. Almost always a low battery issue or bad ground. Your "immobilizer" comment concerns me, because these did not have a factory alarm system. If the alarm system has gone bad, it could be inhibiting the start.
The clicking is likely the starter not getting enough power from the battery to engage. This sounds like a classic bad battery. I agree - easiest thing is to try and jump start it. If you still get clicking its most likely a bad ground or a bad starter motor. If jump starting isn't an option for some reason than A volt meter is cheap and you can use that to test the battery to see if it has enough charge. You could also pull the battery and take it to an auto parts shop to have tested. I'm still betting its a bad battery. If the battery is good, move on to ground wires and then starter motor.
You've probably already checked that the battery connectors are tight and free of corrosion, but if not then that's the first (and easiest) place to start.
After de-immobilising & turning the ign. key on, does the fuelpump start running/buzzing ? A fuel pump can/should also respond to a less charged battery. Without pump it's probably the immobiliser ?!
Thanks all. A push start is a tad tricky due to lack of bodies & manoeuvring the car out of the garage would be a p.i.t.a. This weekend I'll check the battery connections & get the battery tested. When I put a voltmeter across the terminals it returned 12.7 volts which to my mind is spot on.
Hi Andy, check the feed to the starter. Just jack the car up from the drivers side then block it so it's safe (never rely on the jack) Then find the starter solenoid wire (White I think) (it's red on mine) anyway its the positive wire to the solenoid, get your meter set to volts and connect positive probe to the solenoid positive and ground the negative probe one the meter to the engine. Then get a friend to go for a start and see what voltage you get.... If it's anything over 10 volts ish, then you have a starter problem and anything under and you have an earth or alarm or a connection at the battery or the battery switch cut off etc etc fault to find. All the best Bell
Hi Andy, happy new year. Sounds like it's the starter sticking on its bushes, and not enough power to turn it over. Remember the old trick of giving the starter a tap with a hammer. If it was more easy to get to I would say put a direct positive supply to the starter. Mine use to do this occasionally when not been used for a while. In the end I replaced it with a high torque lightweight starter. It's a pig if a job to take off as original is very heavy. Good luck
Happy New Year to you too, Gavin. The fact that it's a pig of a job suggests to me that this will be the eventual outcome Saying that, the main problem with my ignition last year was the sheathing on wire rotting away after 30+ years. This is probably the same issue with my temperature gauge. And I wouldn't rule out the same problem on the starter. I don't plan on getting the car back on the road before Easter so plenty of time... (read that as June by which time this thread will be 5 pages long)
Do the headlights look bright? What does your voltmeter say the battery voltage is with the headlights on? A battery can show good voltage just sitting there but have no power to do any work.
Turn on the headlights, then try to start. If the headlights go really dim while starting, then it is most probably the battery feed (battery, battery ground wiring). If the headlights don't change, then it's either the large supply wire from the battery to the starter, or the wire terminal or solenoid switch. Continue by giving the solenoid a tap with the hammer, as recommended by Gavin. If that does not help you need to get access to the startet to check the wiring and probably disassemble the solenoid for cleaning. Good luck, Adrian
The car is playing with me... Went out to the garage this afternoon, having to decided to take the route suggested by Adrian. Ignition on, headlamps popped up and switched on. Turned key and the bloody thing coughed, spluttered and started with all the enthusiasm of a car that hasn't fired up in 3 months. After 5 minutes she was revving sweetly and all was well in the world. I put the voltmeter across the battery whilst she was running; 13.98 volts which is good (correct me if I'm wrong). Are we going to put this down to a stuck starter solenoid? Should I just walk away and hope it doesn't happen again?
Solenoid or dead/weak spot on the starter. I'd bet on the latter. My 308 does this on occasion. A couple of attempts gets the starter past the weak spot and then it starts fine.
Hi John, dead/weak spot on the starter, can you explain? I can understand the solenoid getting stuck and not engaging the starter motor - i.e. because there is not enough power (weak battery) or because it's simply got stuck (and needs a tap with a hammer to jar it into life) or it's being temperamental (reference my car). But once the starter is engaged and there is enough power, either the starter motor works or doesn't? In my experience it's worn out brushes that need replacing in a failed electric motor.
If you have eliminated the battery, which seems to be the case, the cause would be only just enough voltage is getting to the solenoid when its energised owing to a voltage drop in the current path to it. This could be a corroded connector, bad contact in the ignition switch or a bad relay contact in the immobilizer. If the voltage is going missing in the circuit the solenoid might not engage properly sometimes, and this problem usually is worse when the starter is hot in these cases. The check that Bell mentioned above is the proper way to confirm this if it does happen again. Also is the immobilizer installed correctly using soldered joints and not those dreadful 3M crimp connectors. If the latter, remove it or re-install using soldered joints.
Thanks very much Andy. Is it possible that the solenoid simply got stuck? I had numerous tales recounted to me about striking the solenoid with a hammer, it all frees up again and works fine thereafter (not a perfect solution as it shouldn't have got stuck in the first place but...) Saying that I have no doubt that my wiring is shot to pieces, it's the original 35 year old wiring. I'll check out the immobilizer, that was installed 15 years ago when I bought the car and has never been touched since... I try starting the car up again in a few weeks and see what happens then.
#1 culprit for all "going nowhere" electrical issues I've had in the cars I've owned. Whilst they are the last to get installed, they are so often the first to fail due to shoddy workmanship & materials. If the quick hammer bash doesn't work first, I'd weed out the immobiliser.
First the solenoid. It's just a switch that connects the battery to the starter motor windings. They typically fail because the contacts are making a high current connection and over time the contacts can become pitted and don't conduct as well. So when you turn the ignition switch the solenoid closes but due to the poor contact insufficient current passes throw and the starter motor doesn't have sufficient torque to turn the engine. Turning the ignition on and off a few time may result in finally making sufficient contact for the starter motor to do its job. Second, weak spot on starter. As you probably know, a typical starter motor has many segments (windings) to the armature. Current is supplied to each segment, one at a time as the armature rotates, through the contact of the brushes to the communicator. One of these segments can become weak due, for example, poor contact between the brushes and that segment's contacts on the communicator. If the starter happen to stop so the brushes are in contact with that bad segment, the next time you try to start the engine the starter will, again, not have sufficient torque to turn over the engine. If the segment is bad the starter may not rotate at all. If you try to start the engine repeatedly with the contact to a weak serment each time the starter may rotate a little until contact is finally established with the next good segment and the engine will turn over.
Thanks John - that makes good sense. I was thinking that there are only typically 3 copper windings but of course the armature can have many segments and each of these could cause a dead spot that you refer to.
Anyone know of an alternate for a 1978 308gtb ignition switch, FER18001 (Alfa Romeo, eg). The Ferrari price has increased almost a factor of 10 for this part which is pretty ridiculous.
