turbocharger upgrade with roller bearings | FerrariChat
Discussion in '308/328' started by Albert-LP, Aug 21, 2015.
  1. Albert-LP
    Albert-LP F1 Veteran
    8,002
    around Modena, Italy
    Alberto Mantovani
    An insane idea is growing up in my (stupid) brain: I would like to do an "experiment" by in installing a modded turbocharger: the modify would be removing the standard bearings (that are bushing working with oil pressure) and installing roller bearings, that have much less drag at low speed. That would reduce the lag of that "primitive" 208 turbo (the not intercooled one). Here it is a recomended mod for old turbo cars , but I didn't do nor tested anything like that.
    I have to say that is a thing I would do just in one car and during an engine overhaul that is scheduled this winter. It's just an idea and at the end maybe I won't do it, but is there anyone here that already did that upgrade on a road car (not necessary a Ferrari, of course) and noticed some improvement in the turbo lag?
    Thank you very much
    ciao
  2. sburke
    sburke Formula 3
    Dec 21, 2010
    1,273
    Lake Norman, NC
    Good luck with that.........
    Snag a ball bearing turbo with updated aero and a good map for your application, and be done.
  3. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,054
    Dumpster Fire #31
    SMG
    turbo lag is a function of compressor efficiency and integral to the volute design and impeller trim. I.e. bearings are not going to solve it. The turbo's of that era were not anywhere near the efficiency of what is available today, coupled with the fact that more then likely it was designed for high RPM and peak power the turbo would be 'bigger' then needed and lag is a result.
    The lag comes from the time it takes the engine to create enough exhaust pressure to spin the turbo and pump compressed intake air into the engine and is longest when the engine is in a low-rpm, low-load cruising situation.
    If you’re wondering why somebody doesn’t make a turbo that makes full boost from idle on up to redline, there’s a very simple answer for that: like all engine parts, a turbo has to be matched to a specific rpm range to function correctly. A turbo that’s small enough to make a significant amount of boost under low-rpm situations would overspeed and possibly explode as soon as full throttle was hit. The opposite is also true—a turbocharger that makes the most peak power will make virtually no boost until well into the engine’s powerband. Most turbo setups are a compromise between these two scenarios.
  4. Martin308GTB
    Martin308GTB F1 Rookie
    Jan 22, 2003
    4,252
    Black Forest Germany
    Martin N.
    Alberto,
    no experiences with turbocharger upgrades, but with high speed bearing applications.
    Like you probably know, the high revs like on a turbocharger turbine wheel are the main lifetime limiting factor of ball or roller bearings. One of the reason for preferring friction bearings. Make a lifespan calculation and you will be amazed.
    I once developed a bearing design for an application with similar revs. We doubled the ball bearing in pressing a small roller bearing into the inner race of the bigger outer bearing. This means a relative movement, or better said, a partition of the rim speeds.
    Of course it depends on how much space you have for something similar.
    Maybe needle roller bearings could find enough space.
    Have fun designing
    Martin
  5. Martin308GTB
    Jan 22, 2003
    4,252
    Martin N.
    Smg,
    what do you think about less friction of roller bearings vs. slide bearings on high speed applications. Somehow high revving japanese motorcycle or tiny ultra-high revving car engines with roller-bearing crankshafts come to my mind.
    Best Regards
    Martin
  6. andyww
    andyww F1 Rookie
    Feb 7, 2011
    2,775
    London
    I dont think you would eliminate lag in the 208 as the design is a massive compromise.
    A V8 should always have 2 turbos but they piped the front manifold around into the rear with a simple T piece before the turbo.
  7. Albert-LP
    8,002
    Alberto Mantovani
    #7 Albert-LP, Aug 21, 2015
    Thank you Both, SMG and Martin. That is a mod I won't do my myself, of course, but here many tuners cand do it by machining and modifying the turbocharger. Of course durability will reduce a lot, but who cares, I don't drive my cars more than once a month (or two) and just for small trip so that is not a problem. Actual Maserati Ghibli and Quattroporte 3.0 V6 Diesel have a ball/roller bearing turbocharger (yes!), so it means it reduces a lot the drag/friction and the turbo lag at low RPM.
    Thank you very much SMG for your writing, but the early 208 turbo problem is not a bad designed turbocharger, it's the ignition and injection system that is something like a preistoric animal if compared to the actual ignition and injection systems. The Ignition and injection cannot measure the inlet air pressure nor its temperature, so the lag is very big when the engine is cold. The reason is that if the title of air mixture is not correct (too rich), you will have low exhaust gas pressure so very low RPM at the turbocharger. The result is a completely lack of power when the engine is cold. The intercooled 208 doesn't have this problem as it has a more intelligent ingnition and injection system (with inlet air temperature and pressure sensors). That's like the Formula 1 story at the beginning of eighties: the Renault turbo has a stupid injection syestem that generates an enormous lag:1981 Ferrari 126CK instead had a three parameters injection and the lag was the half, being able to overtake the NA cars also from the starting grid, while the Renault turbo lost positions due to its very big lag.
    The first 208 turbo is like the 1980 Renault F1 engine, the 208 turbo intercooler is like the Ferrari 126 CK F1 engine: this is just one example to show the differences between the two cars if someone here saw those F1 races in those years.
    So, as it's almost impossibile to modify the injection system, a roller bearing turbocharger could help a lot a first model 208 turbo to reduce teh lag a low RPM and when cold.
    ciao
  8. Albert-LP
    8,002
    Alberto Mantovani
    No, that's not true: the 208 turbo Intercooler works very well with a very good boost at 3000 RPM and also when cold. And my actual Mercedes V6 3.0 diesel has a single turbocharger too, but no lag and no problems.
    ciao
  9. Todd308TR
    Todd308TR F1 World Champ
    Nov 25, 2010
    11,071
    LA
    Todd
    If you are going to change the turbo, then put the most sophisticated turbo you can and measure the difference.
  10. Martin308GTB
    Jan 22, 2003
    4,252
    Martin N.
    Alberto,
    do not compare apples with oranges. On your Mercedes you have a slow revving Diesel engine with high low rev torque designed 'from zero' for turbocharger appliction.
    On the Ferrari 208 you have small high revving low torque engine on which they grafted a turbocharger much later. I agree with Andy. That's a massive compromise.
    Best Regards
    Martin
    BTW; I love technical disputes :)
  11. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,054
    Dumpster Fire #31
    SMG
    Funny you ask :D at the moment I'm designing a scavenge pump housing for helical spur gears. Normally the oil pressure pump side can be used to feed the galleries and that tends to solve the issue in a relatively simple way, provided that the oil doesn't cavitate, aerate or run low. Sheer is also a concern.
    I've looked at PTFE, PTFE impregnated bronze, graphite 66 nylon etc.. while also using the pressure side of the scavange to feed the galleries for a quasi splash lubrication. needle bearings are the other choice and I'm leaning towards that approach.
    For loads that don't experience tangential or perpendicular to the axis shock a roller bearing is better suited. Thermal considerations are next, turbos are HOT and the frictional induced heat in the bearing poses a problem for most bearings, ceramic bearings are a good choice esp in turbo housings. Oil film bearing has been the std but requires proper clearance, flow pressure etc.. and of course sheer is always a problem esp with shared engine oil.
    surface drag is present in oil film bearings as the Ra of the two surfaces are usually very small. depending on clearance gap and the differential velocity of the two surfaces and the viscosity of the oil, drag vs sheer become the balance point.
    of course this is only a light dusting of a very complex and intensive subject. :D
  12. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,054
    Dumpster Fire #31
    SMG
    Turbo lag is a function of pressure deltas.
    I was not implying that the 208 turbo was poorly designed at all. As mentioned it's a compromise, pumping efficiency, flame kernal spread, intake and exhaust port length, etc.. all mean that an engine designer has to pick a 'narrow band' of the full rpm range that is desired for the most power. Technology and engineering as come a loooooooooong way since the 1980's and the useful rpm window has been increased.
    Lets get back to the lag issue though. a non-inter-cooled turbo engine will suffer from lag over an inter-cooled one. Air density is the main reason, coupled with the engine management trying to reduce the risk of detonation in the non-inter-cooled engine by timing retardation and extra fuel for cooling it becomes apparent the engine will not be as responsive and that in turn adds to the lag issue already in play with a small engine and large turbo.
    Your best option is to upgrade the turbo to a modern unit that is far more efficient and sized properly to the engine, anything else is a waste of time and money. If the concern is originality of factory OEM parts, then leave it be as modifying the turbo will only lead to more problems that need to be fixed down the road. I'm sure you're aware of the impeller RPM in a turbo, modifying the bearing the bore for such a high-speed shaft is not a simple thing, I can only imagine the setup and jigging required for a machinist to attempt that.
  13. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,054
    Dumpster Fire #31
    SMG
    Depends really, most times on small engines the single turbo will outperform the twin setup. Since trying to balance both banks independently would be a nightmare the intake plenum is shared and as a result the two turbos end up being like a single massive turbo. The trick is finding two small turbos that will work over the engine rpm range and still provide the right amount of air volume at specific pressure without being either too small or too large. So far for the 308 engine that's a tough one as there are loads of single units that are perfect for the displacement of these engines. Helps that there are lots of Japanese 3L engines with turbo's :D
  14. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,677
    Lake Villa IL
    Agreed.
    In my experience going from journal bearing to ball bearing (on the exact same turbo) has a -very- slight improvement in part throttle transients. Zero gain under WOT. (as far as response time).
    Not sure what the compression ratio is but if it's like any other turbo engine from that era it's not enough.
  15. Albert-LP
    8,002
    Alberto Mantovani
    #15 Albert-LP, Aug 22, 2015
    I'm talking of this.
    Trasformazione turbocompressore Ferrari 208 turbo su cuscinetti su vostro KKK o IHI - Protoxide
    Consider that when the oil temperature goes up the car works well, so in my opinion if I take out the oil friction loss I will improve a lot this problem. I don't need a 2015 car, I just want to improve the cold engine working.
    I would like to do it just on the not intercooled 208, as the intercooled one works very well with a lot of power also when cold.
    It would be an invisible modify, as you don't see anything from the outside.
    ciao
  16. Basal Skull
    Basal Skull Formula Junior
    Oct 26, 2010
    427
    Vancouver BC
    I think you just need to have your turbo's rebuilt with 'zero clearance'. Essentially the turbos are built and broken in so that the compressor wheels have zero clearance with the housing, improving efficiency and decreasing lag. Common upgrade in Porsche turbos (mine included). (just google 'zero clearance turbos)
  17. andyww
    andyww F1 Rookie
    Feb 7, 2011
    2,775
    London
    Yes indeed, the shared plenum approach would not work, there would need to be a separate plenum for each bank.
    So, separate plenums, 2 turbos, you would need to make the engine longitudinal because the front bank turbo would have no space.
    Result: 288 GTO.
  18. Albert-LP
    8,002
    Alberto Mantovani
    Thanks!
    ciao
  19. Albert-LP
    8,002
    Alberto Mantovani
    Thank you very much, Basal Skull: I'm very intersted into that reduced clearance compressor impeller. I read a lot about that. Here below some ineteresting links.
    Zero Clearance Turbo's - Rennlist Discussion Forums
    Ultimate Motorwerks - Zero Clearance Turbos
    And I have to say thank also to INTMD8: your experience made me search for some info on that and the result is this in the link here below, a forged and machined compressor impeller. It's in Italian, but with pictures, so you can understand what the improvement is: very big.
    http://www.saito.it/wp-content/uploads/2014/10/Le_giranti_realizzate_da_barra_forgiata.pdf
    I do not know very much about turbochargers, but I just discovered there is a big world there and they did a lot of improvement during years.
    Coming back to my not intercooled 208 turbo, after what I read on tech sites, I think that a very well tuned turbocharger (forged compressor impeller, reduced compressor impeller clearance, perfect impeller balancing) could improve a lot my old first model 208 turbo, but not much in the cold start working. My opinion is that with such a stupid FI system and ignition, It would work bad in the same way until he reaches the correct working temperature.
    In any case, just to talk: Basal Skull, do you know who and where could do a zero clearance adjustment to the KKK K26 turbocharger I have on my 208?
    Thank you (both) very much
    ciao
  20. Basal Skull
    Oct 26, 2010
    427
    Vancouver BC
    Kevin at ultimate motorwerks does the work (web site link you posted above - if you can't reach him though the web site contact, let me know and I can pm his phone number). I believe most of us on the 993 turbo and 996 turbo forums who have had turbos rebuilt have had this process by him. He essentially asks you how you want to use your car and your hp goals and will build you turbos and ecu to take advantage of the turbos. I've had k16 rebuilt as k16/24 hybrids (with the zero clearance) on my stock 993 twin turbo engine and in my current modified andial motor have I believe k24/26 hybrids. He is busy and sometimes takes longer than promised for the turn around but worth the wait.
  21. jessup
    jessup Formula Junior
    Apr 26, 2014
    403
    Santa Clara CA USA
    Jessup
    #21 jessup, Aug 22, 2015
    Garrett claims up to 15% faster spool speed using ball bearings. It also holds the shaft end play and run out to a tighter tolerance which allows tighter clearance in compressor and turbine.
  22. Basal Skull
    Oct 26, 2010
    427
    Vancouver BC
    Whatever you end up doing, get dyno results before and after so you can document exactly the result (and post here)!
  23. morcal
    morcal Formula Junior
    388
    Turin,Italy
    Cal
    Alberto,
    the most reliable/ cost effective way to improve transient response of your K26 for the 208 is to get first a brand new turbo. The guys who were supposed to implant a bearing cartridge to replace the original bearings should be able and capable to measure the clearance between impeller and compressor housing as well between turbine wheel and turbine housing. Then they would have to set the clearances a bit tighter , nearby to diesel specs. You will notice a clear improvment in the acceleration, assuming every bit of the fuel injection system is on spec.
    This trick was common practice for assembling performance turbochargers at the time when no zero clearances or plasma coating or BB were industrially available. Consider all racing turbochargers of the 70-80's were assembled as hybrids with compressor side mutuated from commercial diesel engines ( big size to achieve high air flow ) and turbine side from gasoline pass car engines ( small size /low inertia to get quick response), however with "diesel" clearance setting. As last step the complete rotor should be re-balanced .You cannot do the trick on current K26 because I assume is well used and the turbine side parts may be distorted/cracked because of the exhausts temperature. Of course you cannot expect a 100.000 km turbo life but for your Sunday tours around Modena would be just fine .
  24. 2281GT
    2281GT Formula 3
    Oct 9, 2006
    1,134
    Germany
    Markus
  25. Albert-LP
    8,002
    Alberto Mantovani
    I own 4 turbocharged 208: Two are still brand new with 8 and 15 k Miles, one has 40 k Miles but I do not want to touch it. The only one that (maybe) I will modify is an high mileage car that has been restored just in the body: I will rebuild the engine. The turbocharger was rebuilt 2 k miles ago, so maybe it's still good. When I will have it open on the desk I will check it and will decide what to do. That car will be my "driver" ( the other two are garage queens so I do not want to drive them) so I can do some attempt. Everything depends on how big the rebuilding of the engine will be: If I will fond there is a cracked crankshaft and a collapsed cranckase of course I won't put other money in turbocharger upgrades or something like that. Otherwise if the engine problems are lower with usual valves, heads and bushings, I will have some money to waste in this attempt.
    Thank you all for the very useful info and tips.
    Ciao
