TRX wheel alloy? | FerrariChat
TRX wheel alloy?
Discussion in '365 GT4 2+2/400/412' started by It's Ross, Mar 4, 2020.
  1. It's Ross
    It's Ross Formula 3
    Jul 30, 2007
    2,028
    Barrington, Ill. USA
    Ross
    A wheel re-finisher recommended by the local F dealer has refused to do my wheels stating they are cast magnesium and will burst into flames during their process, apparently powder coating. I explained that even if they are magnesium they would need to be nigh on 900*f to ignite.
    Mine have some paint peeling, the metal beneath doesn't look like magnesium which I'd expect to be very dark if exposed. And they seem way too heavy.
    Does anyone know what the alloy really is?
    Also, still looking for correct paint color as it seems I'll be doing this myself.
  2. Steve Magnusson
    26,932
    Ferrari calls them "light alloy" in their documentation. Based on the weights that have been posted here, they seem to be ~30% Magnesium and ~70% Aluminum. Still a very special, and untypical, material, but, to be technically ticky-tack, not a Magnesium alloy. If you can measure a weight and a volume (easiest done by submerging it in water and measuring how much water it displaces), you can do your own calculation of overall density and then estimate the ratio of Mg content to Al content.
  3. BigTex
    79,406
    Houston, Texas
    Bubba
    Well, they are right and wrong....they certainly wont ignite, but The Wisdom is that even the 400 degrees for powder coating is too hot, off gassing, embrittlement, or something.
    So back to painting, but there's pitfalls.
    Leave the Factory primers, repair damage with Zinc Chromate, and the modern paints are a real rabbit hole as far as color formula.
    I am just going to BEG my long time Body Shop to color match them, even though their mantra is:
    "We don't do wheels"....
    There's wheels services that offer "Refinish at $175 each", but that's on a modern alloy and I would wager they are powder coating.
    I have never found a rattle can color that came close to the OEM Ferrari, although the Mercedes silver is pretty close.
    Not a match tho…..
  4. BigTex
    79,406
    Houston, Texas
    Bubba
    "Paint peeling" is unfortunately a sign that someone may have already repainted them and got the primer wrong....Zinc Chromate is a pale green, it's at the bottom of the OEM layers...
  5. samsaprunoff
    samsaprunoff F1 Rookie
    4,475
    Edmonton, AB Canada
    Sam Saprunoff
    Tojo likes this.
  6. Tojo
    Tojo Formula Junior
    Apr 12, 2002
    499
    Tim
    Boeing uses that pale green zinc chromate on everything. If it's been mixed and prepared properly it's a real son of a bxxx to get off especially using an off the shelf paint stripper. The stuff we use at work is really nasty and very bad for the environment. I'd recommend a going to a professional bead blasting shop who uses Plastic Bead for stripping as glass bead or coarse grit will eat right into the top layer of plating
    Sent from my SM-G935F using FerrariChat.com mobile app
