360 - Trunk Strap Replacement | FerrariChat
360 Trunk Strap Replacement
Discussion in '360/430' started by Rjoselaw, May 24, 2020.
  1. Rjoselaw
    Rjoselaw Karting
    Mar 10, 2019
    115
    Southlake, Texas
    Raj J
    Easy and effective weekend (or quarantine) project. Like so many, my fake leather straps in the trunk were trashed. So, I ordered the replacement straps from Two Redbirds Leather in Austin (https://www.tworedbirds.com/ferrari-accessories) and commenced to spend this afternoon installing the new straps. Overall, the project is about a 3/10 and all you need is basic knowledge to replace it but I cannot understand why Ferrari decided the trunk panels needed 250 bolts to hold them down. Complete overkill! Here are my before an after pics (I do not have the OEM inflator so I put my owners manuals/pouch in its place)
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    colorfull, mb5, docf and 2 others like this.
  2. Bob in Texas
    Bob in Texas F1 Rookie
    Apr 23, 2012
    2,721
    Just East of Weird
    Bob
    Much better!
    Sent from my iPad using Tapatalk Pro
  3. Fixjets777
    Fixjets777 Karting
    Oct 16, 2016
    96
    Treasure Coast, Florida
    Jeff
    I also used Two Redbirds to make a set of replacement straps for my F430 toolkit. He makes a good product at a reasonable price.
  4. guidwire
    guidwire Rookie
    Aug 19, 2013
    12
    Granite Bay
    Derek
    Wow! Thanks for posting! Are the straps held down by screws or rivets?
  5. Fixjets777
    Fixjets777 Karting
    Oct 16, 2016
    96
    Jeff
    Original fasteners are rivets. I also used rivets when installing my new straps. But Two Redbirds provides Chicago screws(two piece) as an alternative.
  6. guidwire
    guidwire Rookie
    Aug 19, 2013
    12
    Granite Bay
    Derek
    Thanks. Looks like I will have to learn a new skill!
  7. Rjoselaw
    Rjoselaw Karting
    Mar 10, 2019
    115
    Southlake, Texas
    Raj J
    I ended up using #8 brass bolts and nuts. I did not have a riveter.
  8. shifter
    shifter Formula Junior
    Apr 8, 2004
    625
    Danville, Ca
    Joe
    Do the straps go up like that from the factory? In my F430 they are opposite. Just curious.
  9. Rjoselaw
    Rjoselaw Karting
    Mar 10, 2019
    115
    Southlake, Texas
    Raj J
    Apparently on my 360 that is the way it came. Maybe 430 is just the opposite. Good observation
  10. SCKOMS
    SCKOMS F1 Rookie
    3,900
    Lake County, IL
    Spiro
    If one uses rivets to attach the new straps does the trunk liner have to be removed? Can one drill out the old rivets and that pop the new straps in place using the same holes?
    Sent from my Galaxy
  11. shifter
    Apr 8, 2004
    625
    Danville, Ca
    Joe
    There are metal supporting brackets on the outside of the liner, so to do it right, yes you would need to remove the liner.
  12. Rjoselaw
    Rjoselaw Karting
    Mar 10, 2019
    115
    Southlake, Texas
    Raj J
    Also, you have to remove the floor panel to replace the strap that is attached to it. It is actually riveted to the metal floor. So, you will have to drill out the rivets and then remove the floor panel. But, to remove the floor panel, you have to remove all the other panels. At least that is what I had to do.
  13. SCKOMS
    SCKOMS F1 Rookie
    3,900
    Lake County, IL
    Spiro
    I was actually referring to the straps on the side of the trunk (passenger side).
    Sent from my Galaxy
  14. SCKOMS
    SCKOMS F1 Rookie
    3,900
    Lake County, IL
    Spiro
    Can you drill out and replace one rivet at a time?
    Sent from my Galaxy
  15. shifter
    Apr 8, 2004
    625
    Danville, Ca
    Joe
    I suppose you could, the backing plate may twist out of location, it may not.
    Removing the tub is really easy, several screws. Takes a few minutes.
  16. guidwire
    guidwire Rookie
    Aug 19, 2013
    12
    Granite Bay
    Derek
    Any recommendations on which rivet gun to buy?
  17. shifter
    Apr 8, 2004
    625
    Danville, Ca
    Joe
    I use a Tekton 6555
    guidwire likes this.
  18. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,378
    Santa Clarita, CA
    I replaced all my straps. The local shoe store made me new ones out of dog leashes he had for sale. They came out great. Just get any pop rivet gun from Amazon that has a variety of pop rivets with it.
    You will definitely need to pull out the panels to do it right. The backing plates will bend out of the way when you try to drill the old rivet out. You also are taking a chance that the drill will slip and you drill into whatever is behind the panels.
    If you need advise on this, PM me. I just did mine 2 months ago.
  19. SCKOMS
    SCKOMS F1 Rookie
    3,900
    Lake County, IL
    Spiro
    Sent from my Galaxy
  20. velocegiallo
    velocegiallo Karting
    101
    California
    I also used Two Redbirds. I have the spare tire option so I had extra straps. The replacements were perfect, using original hardware that I sent him.
  21. 2008F430
    2008F430 Karting
    Apr 30, 2020
    106
    St Augustine
    Hawaii Brit likes this.
  22. 2008F430
    2008F430 Karting
    Apr 30, 2020
    106
    St Augustine
  23. velocegiallo
    101
    California
    Ditto for me.
  24. Ray Smith
    Ray Smith Formula Junior
    May 17, 2020
    851
    Costa Mesa, CA
    Raymond Smith
    Yes, you can drill out the rivets. If you don't use rivets to reinstall you run the risk of poking holes in the vapor barrier.
    There are brass plates behind the trunk liner for the pop rivets to attach to so it's best to remove the liner so you can recover the brass plates for reuse.
    I did both, my tire inflation kit straps (2) and the toolkit strap on my F430. Use the old straps as templates for making the new ones and reuse the hardware. You can buy high quality belt leather, pop rivets, and a rivet gun for less than new NOS OEM belts. You'll need two tools to install the rivets on the buckle-end of the straps. If interested, PM me and I'll send you photos of the tools and a source with prices.
    Ray
  25. Ray Smith
    May 17, 2020
    851
    Costa Mesa, CA
    Raymond Smith
    Here is the finished job.
    Ray
