430 - Trick to removing Upper Steering Column Cover? | FerrariChat
430 Trick to removing Upper Steering Column Cover?
Discussion in '360/430' started by MKTViper, Jan 23, 2020.
  1. MKTViper
    MKTViper Karting
    205
    Swan Point MD
    I decided to tackle the sticky plastic issue on my steering cover. Got the 5 screws removed, and separated the bottom from the top without a problem.
    However, while the upper trim cover is loose, it won't come out. It seems the leather piece is "stuck" or binding somewhere behind where I can't get to it. Is that attached somehow?
    I so have the wheel as far down as it will go, but I also read on a few other posts there are a couple screws to loosen that'll allow the steering column to drop even further...is that the trick?
    Any thoughts? As usual, I thought this would be a piece of cake...
    Thanks,
  2. imahorse
    imahorse F1 Rookie
    2,765
    WI
    Dustin
    IIRC this video details how.
    Flyingbrick242 likes this.
  3. MKTViper
    MKTViper Karting
    205
    Swan Point MD
  4. RossoC360
    RossoC360 Formula Junior
    Jun 20, 2008
    475
    Buffalo NY
    Jason
    There is a strap that limits the column tilt function that can be loosened in order to allow the column to drop further to aid in the removal (additional clearance) of the top clam shell, the strap is a solid bar of aluminum on the drivers side of the column with two 8mm bolts, remove the front and loosen the rear.
  5. RossoC360
    Jun 20, 2008
    475
    Buffalo NY
    Jason
    I just realized that you were asking about a 430 not a 360, I cannot confirm that they are the same.
  6. MKTViper
    MKTViper Karting
    205
    Swan Point MD
    The same procedure may apply though. The parts look nearly identical.
    I'll check for the strap when I get home.
    Sent from my SM-G950U using FerrariChat.com mobile app
  7. ItalGerBrit
    ItalGerBrit Formula Junior
    Mar 15, 2016
    817
    S La
    I had the same problem with my 360 and had to remove both bolts and the strap to completely drop the steering column. There are two plastic extensions that still get hung up so it is a fiddling sort of thing to manipulate the shroud out. I broke those studs before completely removing the strap. Epoxy fixed the studs.
  8. MKTViper
    MKTViper Karting
    205
    Swan Point MD
    I ended up detaching the leather trim... it was just glued on. It took some maneuvering, but got it out.
    Stripped both halves down and repainted with Duplicolor black plastic paint.
