Transmission oil change question | FerrariChat
Discussion in 'Mondial' started by JLF, Aug 17, 2019.
  1. JLF
    JLF Formula 3
    1,645
    Is it acceptable to fill the trans through the dipstick hole so I don’t have to remove the air box and stuff?
  2. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,835
    Isle of man- uk
    Does the trans have a dip stick as i dont recall one- is it not a level plug. 5 years since my mondial
  3. JLF
    JLF Formula 3
    1,645
    Level plug? Yea I think, is that a plug with a small metal ruler attached to it?
    It’s towards back left of transmission, pretty easy to just reach under and unscrew. And I bought one of those Motive power fillers to pump the oil in.
  4. fatbillybob
    Aug 10, 2002
    26,349
    socal
  5. BillyD
    BillyD Formula 3
    1,776
    Pacific Northwest
    Bill
    I've had a 77 308 AND now an 83 Mondial qv and no dipstick on transmission on mine.
  6. JLF
    JLF Formula 3
    1,645
    Yes to the refill method?
  7. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    I'm pretty sure JLF is talking about the t.
    From the Owner's Manual:
  8. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,835
    Isle of man- uk
    I just used to use a clear plastic hose into the level plug and then bring the end up into the engine bay and put a plastic funnel in the end of it.
    I see the dipstick on the diagram but i sure never saw or used it.
  9. JLF
    JLF Formula 3
    1,645
    Ok thanks for the responses guys.
  10. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,835
    Isle of man- uk
    Remember that the gears on the clutch housing are part of the gear box oil if i remember correctly
  11. JLF
    JLF Formula 3
    1,645
  12. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
  13. JLF
    JLF Formula 3
    1,645
    Ok, but not for the T correct?
  14. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    Correct. See post #7.
  15. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,835
    Isle of man- uk
    When you look at these diagrams you can see why i used to fill my 3.2 via a clear plastic hose and a funnel from the engine bay- made a simple job of it.
  16. JLF
    JLF Formula 3
    1,645
    Well that was a friggin disaster. The elbow pipe on the Motive power filler that goes into the filler hole in transmission came off twice while filling and poured all over my garage floor. That thing is not built very well. Took more time to clean everything up than it would have been to remove the air box. Oh well, fresh fluid in gearbox and happily there was virtually no fuzz on the magnetic drain plug.
  17. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,835
    Isle of man- uk
    Keep it simple, buy a bit of plastic hose and a funnel
  18. belfry
    belfry Formula Junior
    May 14, 2015
    394
    Robert Batt
    I did this on my 1990 T. It was very straightforward to remove the airbox and fill the gearbox from the top, via the gearbox oil filler.
    I had previously tried to use the gearbox oil dipstick hole, but it was very slow and messy.
  19. JLF
    JLF Formula 3
    1,645
    Yea last time I did it that way but was looking for something “simple” like Mike said. Hence the Motive power filler. I guess had the tube not become unattached it would have been good.
