Transmission/differential warning light | FerrariChat
Discussion in 'California/Portofino/Roma' started by Jonathan Gross, Jun 29, 2021.
  1. Jonathan Gross
    Jonathan Gross Karting
    Feb 11, 2020
    75
    Jonathan Gross
    This warning light came on in my 2017 Cali T today when I started the car after a few hours in the parking lot. After driving for 15 minutes, the light went off. Has anyone has this experience? And what to do? My warranty expires soon.
    Sent from my Ferrari iPhone
  2. lucasines
    lucasines Karting
    Apr 22, 2016
    127
    Paris
    Gilles
    Only one time on 17 Cali T in 3 years + when I started, stop and restarted, it was ok, never again. Can happen during start sequencing.
  3. CONAL MARWAH
    CONAL MARWAH Rookie
    Jul 18, 2020
    15
    Conal M.
    Hey Jonathan - I can't see the image if you posted one but I recently got a exclamation with a gear around it warning light in my 2016 cali t and the reverse button wasn't working properly. Did you experience something similar? The weird thing about my car is that it only happens on days when it's over 100 degrees outside. Wondering if it's similar to what you experienced.
  4. bb2thdr
    bb2thdr Formula Junior
    Dec 23, 2021
    318
    Scott Bialik
    Probably a low voltage issue when starting. If subsequent starts dont replicate it, then you are most likely fine.
  5. rajabf
    rajabf Rookie
    Jun 8, 2022
    10
    Rajabf
    Greetings
    I have had a similar issue on my Cali turns out the buttons are sticky and they would stick causing the malfunction light, once i traced the issue a couple of presses on the buttons seemed to cure the issue, and i now keep my eyes on it.
