Trailer load/unload WO tow vehicle attached? | FerrariChat
Discussion in 'Tracking & Driver Education' started by staatsof, Sep 5, 2013.
  1. staatsof
    95,282
    Fuggetaboutitland
    Bob
    I've never tries this but I have a reason to want to be able to do this and wondered if this is even a good idea. Usually my 24FT lead sled old enclosed trailer is attached to my tow vehicle whenever I load or unload a car. This car weighs 3000lb and I'd be driving it in and out as opposed to using the winch though that might be possible too.
    So I was thinking of putting piece of 4x4 under the rear edge frame and raising the front until they appear to have a good amount of weight on them. I think backing it off is not an issue but I'm worried about driving onto the ramp when I reload the car.
    Has anyone here done this?
    I also thought about getting a pair of these as well?
    Ultra-Fab Chock and Lock Wheel Stabilizers for Tandem-Axle Trailers and RVs - Qty 2 Ultra-Fab Products Wheel Chocks UF21-001070
  2. GuyIncognito
    98,978
    those wheel chocks are nice! a friend has them on his ~40 foot gooseneck and the trailer might as well be cemented in.
    to your question, I've put my 911 on the trailer without the tow vehicle attached and it worked, no major issues; I don't know how much, if any, the tongue jack moved. but I didn't like doing it, it seemed like an unnecessary risk to me.
  3. staatsof
    95,282
    Fuggetaboutitland
    Bob
    Thanks Charles. What kind of trailer do you have (size type)?
  4. GuyIncognito
    98,978
    it's a 20 foot enclosed (insulated) Pace, so it's fairly heavy for its size...that might help when loading without being attached.
  5. staatsof
    95,282
    Fuggetaboutitland
    Bob
    Yeah mine's heavy too, 3,800 lbs empty with a 7K limit.
    Did you support the rear edge of the trailer to prevent a tip up or just go for it?
  6. GuyIncognito
    98,978
    nah, I just went for it (although I did have a set of race ramps under the trailer ramp, but that's to clear the splitter and not to protect/support the trailer)
  7. staatsof
    95,282
    Fuggetaboutitland
    Bob
  8. ilconservatore
    ilconservatore F1 Veteran
    May 18, 2009
    8,369
    Cincinnati Ohio
    At least you're doing putting some thought into it with chocks and stabilizers, but I would avoid it. maybe the larger door/ramp on enclosed trailers makes them more stable when loading though. I've tried it with open car trailers and its like jumping on a skateboard.
    Also very easy for the trailer jack to collapse if the tongue pushes forward a bit. Its just a hollow tube after all.
    Thanks for the wheel chock suggestion - just bought a pair!
    Oh, and I'll leave this right here LOL.
    [ame=http://www.youtube.com/watch?v=3c4Z8MNmlA8]Two Trailer Loading Fails - YouTube[/ame]
  9. GuyIncognito
    98,978
    superb :)
    that was my big fear, the trailer jack collapsing or bending in on itself. although from that video maybe I've just added to my list of fears :eek:
  10. Pro Stock
    Pro Stock Karting
    Jul 5, 2008
    154
    Toronto, Canada.
    Ron V.
    I do it all the time. Make sure the Wheels are chocked front AND back on the trailer. I jack the front of my trailer up to get my car in. 1 5/8" ground clearance on the front of my car makes it impossible to load without un-hooking the tow vehicle.
    If the Trailer tires are chocked properly then you should have no issues whatsoever. I have even had the winch stop and rock the trailer.
    I have never had any problems.
    Get BIG wheel chocks.
    Ron
  11. staatsof
    95,282
    Fuggetaboutitland
    Bob
    I didn't have time to get the intra-tire expanding wheel locks but I just used my one big wheel chock along with the 4 plastic ones I already had and raised the front with some 2x4 blocking under the rear lip and it worked like a champ the trailer didn't even budge at all according to my wife who was nervously observing.
  12. Entropy
    Entropy Formula 3
    Jul 10, 2008
    2,149
    I've used to do this often - I found several keys to success (and safety)
    1) I used massive rubber wheel chocks all around
    2) I had installed rear stabilizer jacks (swing-down type). This basically puts the rear of the trailer on a stable platform
    3) only loaded a proportionally lightweight car (eg. my 2800lb Porsche in a 24' Cargo Express)
    4) use the winch - slowly
    Stabilizer jacks are now required equipment for me with trailers
    I have actually driven the car in, but hd to be careful about loading the weight and did it only as a test...
    I saw a guy at VIR one night drive his new 997 Turbo into a 22 foot featherlite....trailer did a wheelie, started rolling until the rear lip smashed itself into the VIR paddock dirt.
  13. staatsof
    95,282
    Fuggetaboutitland
    Bob
    Essentially I did all of that except for using the winch. It worked just fine with zero movement. I think the intra-tire wedges would probably be the most secure form of chocking the trailer though, better than chocks which can move.
    I like the idea of swing down scissor jacks.
    Even so it was stable as can be. My trailer is no featherlight @ 3,800 lbs. :)
  14. Astrong16103
    Astrong16103 Rookie
    Mar 13, 2013
    13
    Detroit, MI
    I had an added concern about the low clearance of the F430. So have been using a setup that is two birds with one stone; stabilize trailer and lower rear of trailer. Sounds odd, but this is super stable for me with a Yukon and 26' car hauler;
    1) Back rear truck tires up onto regular car ramps that you keep in the trailer.
    2) Set the parking brake
    3) Use some dunnage (wood) to allow your elevated hitch post to take some load off the truck and add stability to tongue
    4) Yes, use wheel chocks
    5) Am using 65" (I believe) Race Ramps. Super light, grippy and well made.
    6) Winch it in, or just use that clutch gently
    Piece of cake
