TR Replacement Fog Light Lens. Plastic? | FerrariChat
Discussion in 'Boxers/TR/M' started by xplodee, Dec 24, 2018.
  1. xplodee
    xplodee Formula 3
    Jan 3, 2017
    1,105
    Allentown, PA
    Tim
    What are everyone’s thoughts on these plastic replacement fog light lenses? One of mine is cracked and as we know, these fog lights are nearly impossible to find and could just crack again anyway.
    http://www.squadranuvolari.com/ferrari-products.htm
    T
  2. raysur
    raysur Formula Junior
    604
    So. Cal.
    Jeff
    I had a horrible experience with that company.
    The turn signals, I received, weren't even the correct dimensions. They had no reflective paint and arrived chipped (they shoved them in a USPS flat rate box to save money). He is super quick to take your money and you won't hear from him if you have issues. PayPal protected that transaction. He eventually contacted me only to make it seem this was my fault his parts were too long and didn't fit.
    Natkingcolebasket69 likes this.
  3. xplodee
    xplodee Formula 3
    Jan 3, 2017
    1,105
    Allentown, PA
    Tim
    Ugh. I was worried about that.
    So do we have any other options?
  4. EZORED
    EZORED Formula 3
    1,029
    Scottsdale, AZ
    Dennis
    I had a big rock chip in my fog light. There was just a pin hole on the outside and a big chip on the inside of the lens. I repaired with a windshield glass repair kit. 1. took light out and removed the bulbs. Cleaned the inside with air. 3. Laid the unit lens side down on work bench. 4. filled hold left by missing chip on the inside with resin, places a piece of plastic film that comes with the kit on top if the resin (this flattens out the resin and makes it match the curve of the inside of the fog light)Try to get enough resin to fill but not over fill the chip. 5. carefully set in sunlight (lens side down) in sunlight and let cure. 6. Remove plastic film. 7. Once cured do a standard lens repair on the out side. I think you will be happy with the results. I can not detect unless I get down on my knees and look very close.
  5. xplodee
    xplodee Formula 3
    Jan 3, 2017
    1,105
    Allentown, PA
    Tim
    Interesting suggestion, I’ll give it a shot but I believe mine is a bit too far gone. If I can repair it then I’ll be very relieved!
  6. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    No experience with that company whatsoever but after reviewing the website, they are using urethane casting technology to reproduce parts. That's a process we plan to get into down the road. It's my understanding that fantastic results can be achieved but the creation of the mold can be very time consuming.
  7. xplodee
    xplodee Formula 3
    Jan 3, 2017
    1,105
    Allentown, PA
    Tim
    Nothing hard about urethane casting. If thats what they're doing then their prices are based on market demand and not hard costs. Id rather pay for an original then a repot from an RTV mold.
    Its a useful way of doing things and has its place, just not for me on this part. Especially with a complaint in the books on fitment.
  8. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    I'm not suggesting it's hard, I'm suggesting it's time consuming which is costly. I've seen parts cast that are of fantastic quality.
  9. xplodee
    xplodee Formula 3
    Jan 3, 2017
    1,105
    Allentown, PA
    Tim
    Didnt intend to come across argumentative. I do it at work regularly. Its not time consuming either.
    All this said, its a perfect solution for many parts. For example, the little black plastic storage bins on the doors and in the center console were clearly cast from molds over leather patterns, you can see the original pattern’s stitching in the final part and if you look at the undersides they are complete with air pockets.
    But as a result of being cast urethane (or similar RTV material), they are also very brittle and prone to failure. For a fog light it just might not be the best solution. I assume its poured with acrylic casting resin.
  10. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    So how long would it take to make the tool?
  11. xplodee
    xplodee Formula 3
    Jan 3, 2017
    1,105
    Allentown, PA
    Tim
    For a fog light? Two hours max? Its not a tool, its a mold that you pour, theres no machining. You determine your parting lines, build an appropriate box from wood (we have wood mold frames that are re-used), position the part within the mold and pour to the parting line.
    Once that’s cured you pour the top half of the mold. Separate the halves, remove the pattern and its done.
    Ideally you want vacuum to prep the molding compounds to eliminate air bubbles. I’m not sure if acrylic should be cast under pressure? Thats just an added expense but not hard either.
    Fwiw I’m in the manufacturing business and focus on new product development as a career. I often print molds for the same purpose, theres a million ways to skin a cat and many of them are perfectly acceptable for these old car parts.
    Check out Smooth On or Polytek. We use Polytek products.
  12. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Yes, I know it's a "Mold" but often molds are referred to as a "tool" ;)
    IMHO, 2 hours to produce that mold seems very quick. I'm a super detailed guy so my work takes me time. I also own a engineering and manufacturing business so I have a lot of experience with many different processes.
  13. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    As a side note, a 3D printed part won't touch the quality of one cast. I'm sure you already know that, just posting for others.
  14. xplodee
    xplodee Formula 3
    Jan 3, 2017
    1,105
    Allentown, PA
    Tim
    To me a tool refers to something which was machined. Calling a mold that was poured a tool just doesnt strike me as appropriate lingo. That said who cares, we’re on the same page.
    Agreed! Its easy. I’ve seen your StickyRx business, you provide a great service to the community.
    A poured mold over an original part will produce a perfect copy. But if the original part was injection molded or cast from metal, glass, or other, it will also result in an inferior copy in terms of strength and some other material properties.
    My favorite method for reproducing a part that was originally injection molded is to model the part, then make an injection mold and mold it again. Urethane casting isnt ideal but works in a pinch.
    What parts are you working to reproduce? If they were originally cast like many TR parts then I think youre going to provide another great product.
  15. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    In the injection mold business, the mold is 99% of the time called a tool, but it's machined. Anyway, we beat this enough :)
    I agree with you completely as we just had an injection mold made for 430/599 switches we are reproducing but it was a simple part so the mold was affordable. I would estimate a mold for this part to cost $25,000-50,000. That's why people use urethane casting to low quantity reproductions.
    We will be getting into the technology for no specific part(s) yet. We are just running into more and more obsolete parts that need to be reproduced.
  16. xplodee
    xplodee Formula 3
    Jan 3, 2017
    1,105
    Allentown, PA
    Tim
    Thats exacrlt what I said. An injection mold is a tool. An RTV mold is not, imo ;)
    The glass lens, if manufactured in plastic via injection molding, is a simple part. No side cores, standard pull tool. The hardest part of the mold would be the polished finish for optical transparency. But given the ultra low volume of this part I would still spec an aluminum mold, or if the mold maker would prefer steel then so be it. $10-15k. The part would be molded from polycarbonate.
    I see TR guys constantly worrying about what color their bolts are, so to me if one is going to reproduce a rare part then it should be done from the same manufacturing method as the original. In my mind the lens should be reproduced in glass. Unfortunately I have zero experience casting/molding glass so I have no idea how expensive the tooling would be.
    I get a sense that theres some dick swinging going on here and I’m just as much to blame. Feel free to PM if you want to talk further about new product development, its my passion.
  17. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    I'm not swinging anything, just posting my experience of nearly 30 years. Man, I'm getting old. :)
    Yes, polycarbonate for sure. So we agree on that ;)
  18. xplodee
    xplodee Formula 3
    Jan 3, 2017
    1,105
    Allentown, PA
    Tim
    You already admitted to having no experience with the process. I’ve designed and manufactured hundreds of parts currently in production from dozens of materials and make a business of low volume part reproductions and prototypes. Please just drop it. I’m trying to be respectful and give you advice. This is my thread too
  19. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Correct, no direct experience with urethane casting. I've just been reading about it, watching videos and discussing with other professionals about it for the last year. One of them, the head of GM's development group.
    I do have plenty of experience in design, CNC machining, dies and a substantial injection mold knowledge but I've never personally made an injection mold.
    I believe its imperative to learn about all manufacturing methods due to the businesses I'm in.
    xplodee likes this.
  20. xplodee
    xplodee Formula 3
    Jan 3, 2017
    1,105
    Allentown, PA
    Tim
    Thats awesome, I have tons of respect for you and what you do.
  21. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Thank you. And I do for you and all others in manufacturing and associated fields.
    xplodee likes this.
  22. 302Tim
    302Tim Formula 3
    Jul 2, 2011
    1,182
    Northern California
    Tim
    I have a lens that is beyond repair and have been searching for an OEM (Carello) assembly for over a year now. The plastic reproductions I have seen in person are somewhat milky/translucent--not 100% clear like a glass lens. For me (and at the price they are asking) that's a show stopper so I keep driving with my broken lens until I find a good replacement.
    I've been contacted by a member (Carlo, screen name "StartedFromThe Bottom") who has been extremely helpful--he has RH US market OEM glass lenses on hand and just located a LH lens for me (you can't have it, I've been searching for over a year!!). If you need a US RH lens he had several earlier this year. He also has other market lenses in stock (the glass pattern differs between markets). His site is www.ferrariparts.eu
  23. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Tim, that is actually Carlos's dad's site. So help me learn - original are glass not plastic?
  24. 302Tim
    302Tim Formula 3
    Jul 2, 2011
    1,182
    Northern California
    Tim
    Thanks for the clarification Dave--and I see I even mis-typed his name above (left the "s" off Carlos--sorry Carlos!). Yes, on the Testarossa the fog light lens was originally glass (don't know about 512TR or F512m) and not meant to be removed (like the turn signal lens) although you can separate it from the housing by cutting through the adhesive caulk (though haven't tried yet).
    Dave rocks likes this.
  25. EZORED
    EZORED Formula 3
    1,029
    Scottsdale, AZ
    Dennis
    How big is the hole on the outside of the lense? Mine was the size of a pencil lead.
