TR Fuse box relay bypass | FerrariChat
Discussion in 'Boxers/TR/M' started by ago car nut, Oct 2, 2017.
  1. ago car nut
    ago car nut F1 Veteran
    5,462
    Madison Ohio
    David A.
    This is my solution to the hi current fuse box relay bypass. The fusebox in my 1987 TR is in very good condition, no brown or melted white plastic connectors (north eastern car)! I took a piece of ABS plastic and mounted 6 relays and fuse block . The heavy red wire goes to battery feed, black wire to ground in fuse box. Replace the 6 fuses in the original fuse block with 3 amp fuses. Cut and splice the wires from the white connectors to the trigger wire on the the new relay terminal block (86 white). Blue wires terminals from switched relay 30 in this case to output (same as original relay). Red from new battery fused feed 87. Black wire 85 ground. Yellow wire 87a 5th pin on fuel pump ground. The terminal block on right goes back to the device from spliced white connector. The fuses in the new fuse block are the same as before: fuel pumps 15amp, the other 4 are 20amp, as original.
    New relays and fuses are: LH fuel pump, RH fuel pump, RH rad. fan, LH rad. fan, A/C blower(inside), A/C condenser fan. Northern car, my oil radiator fans never come on. This array fits nicely in the well with the A/C drier next to the fuse box. It can be removed easily for service. White connectors: K, pin-33 A/C bower brown/brown wire. J con. pin-41 left radiator fan/ blue black wire, J con. pin-44 right rad. fan/ blue wire. Y connector pin-63 right fuel pump/ beige wire, Y con.pin-64 left fuel pump/ beige/ black wire. C connector on right side pin-19 A/C condenser fan green wire. I also ran a black copper wire from the engine ground strap on cradle up to fuse box ground, and on to negative on/off switch next to battery. Just continue a good ground from engine. Image Unavailable, Please Login
    MisterT, turbo-joe and Melvok like this.
  2. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,395
    romano schwabel
    well done
    on the photo I can not see exactly:
    the 6 red wires from the fuse box are 1.5 or 2.5 mm²? 1.5 seems me to small
    the 1 red wire from orignal to your fuses is 4mm² or 6mm², last would be better
    the blue wires are going to the fans/pumps and so on? so also 2.5 mm²
    the white wires have plus for switching on/off the relais? then 1.5 mm is ok
  3. ago car nut
    5,462
    Madison Ohio
    David A.
    The wires are 16 gage 1.5mm. and are short run. good for 25 amps, more than the fuse is capable. relay setup is rated at 30/40 amps. Wires from right terminal block will be 14 gage 30 amp.
  4. turbo-joe
    Apr 6, 2008
    9,395
    romano schwabel
    what you understand under: the wires are 16 gage 1,5 mm? what means gage here? I know a pressure gage
    bosch says for continious working:
    1,5 mm² 16 A
    2,5 mm² 25 A
    your wires are very short, but I would use more mm²
  5. Steve Magnusson
    26,504
    turbo-joe likes this.
  6. turbo-joe
    Apr 6, 2008
    9,395
    romano schwabel
    #6 turbo-joe, Oct 2, 2017
    thank you steve
    this is complicated for me, because I have to count from US size to euro size, but I understand now what is gage :) but why not gauge?
    so gage 16 is then 1,31 mm² and gage 15 then 1,65 mm², so only good for 16 A and not for 25A? or do I have a couting mistake?
  7. Steve Magnusson
    26,504
    It can be spelled either way in English (gage or gauge or just ga for shorthand). Yes, comparing the cross-sectional area is the right way to convert between AWG and the metric gauges (although they don't match up exactly). While 15ga exists in the AWG standards, trying to get that would be very difficult as usually only the even wire gauges are readily available in that range (...20, 18, 16, 14, 12...). As far as the current capacity, that's a bit of a black art dependent on wire length and the heat transfer situation. As this reference suggests:
    https://www.powerstream.com/Wire_Size.htm
    typical ratings are very conservative. On the plus side, those runs are very short and not in a bundle, but I might have opted for 14 ga for maybe the AC stuff (my recollection is that is the AC is highest current fuse, but I may be wrong about that). Things like the fuel pumps and cooling fans really only draw ~10A even though their fuses are much larger (i.e., the fuse really only protects against a dead short situation - otherwise they would blow on motor start-up).
    Otus, turbo-joe and Melvok like this.
  8. turbo-joe
    Apr 6, 2008
    9,395
    romano schwabel
    in europe ( don´t know in great britain? ) for automotive and also for house installation it is usual:
    1 mm², 1,5 mm², 2,5 mm², 4 mm², 6 mm², 10 mm², then of course bigger and smaller sizes.
    the AWG sizes are hardly to get here
    https://www.powerstream.com/Wire_Size.htm shoes only conductor diameter, not the cross sectional area as we are used here.
    nevertheless I would replace on this very well done fusebox then the 1 red main wire where there comes all the power for all fans and pumps by a 6 mm² or AWG 10, just now it looks like only AWG 12 ( 3,31 mm² ) and that is definitely to small for all
    Melvok likes this.
  9. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,243
    Mel
    Hi David, good example of creativity imo !
    Well done; saves you a lot of thouble later.
    More ownesr should either get the "Helms" version or do so as you did.
    Please show us when you are (really) fitting the board :D
  10. ago car nut
    5,462
    Madison Ohio
    David A.
    Mel, the TR is not running now because waiting on back ordered 2nd gear! I will post when finished.
  11. Melvok
    Jul 25, 2008
    14,243
    Mel
    Owwww ... yes I remember ....
    Any idea wher to get one; when you will have the set (I hope you get a pair/set) ?
  12. ago car nut
    5,462
    Madison Ohio
    David A.
    Promised to receive 2nd gear set in two weeks.
  13. Melvok
    Jul 25, 2008
    14,243
    Mel
    I hope so for you David.
    Please make some photo's from old and new ones, wear etc ... the reason why you exchanged them ...
    We all can learn from this :D
  14. ago car nut
    5,462
    Madison Ohio
    David A.
    Mel, my 1st and 2nd gear look like this. My opinion and others believe improper heat treat? I intend to do a complete write up on this forum: rebuilding gearbox and installing Newman diff. when I get the new parts.
    P.S. Far from my 1st gearbox rebuild.
    Dave
    vincenzo likes this.
  15. tommydogs
    tommydogs Karting
    Nov 9, 2016
    137
    Los Angeles, CA
    Tommy Robinson
    Dave, this looks wonderful and you're really inspiring me to do something very similar with my car! My one question about your construction technique is, do you know the melting point of the ABS that everything is being mounted to? I know my fuel pump relays (and maybe the other relays, too) tend to get very hot.
  16. ago car nut
    5,462
    Madison Ohio
    David A.
    Tommy, melting point of ABS is 400deg F.
  17. tommydogs
    tommydogs Karting
    Nov 9, 2016
    137
    Los Angeles, CA
    Tommy Robinson
    OK, that seems fairly high. What is the highest temp the heatsink around a relay will get to -- or maybe more importantly, what is the highest temp the heatsink around an IMPROPERLY FUNCTIONING relay can get to?
  18. Melvok
    Jul 25, 2008
    14,243
    Mel
    #18 Melvok, Oct 7, 2017
    It is wear ... and nothing else imo .... guess what happens if one teath breaks ....
  19. ago car nut
    5,462
    Madison Ohio
    David A.
    Mel,
    I show soon when one took breaks! My back ordered gear promised to me next week.
  20. ago car nut
    5,462
    Madison Ohio
    David A.
    Tommy,
    There is no heat sink around original fuse box or David Helmes fuse box repair. I don't think relay heat is an issue? The problem seems to be the undersize white connector clips. Get hot and ruin the fuse box?
  21. tommydogs
    tommydogs Karting
    Nov 9, 2016
    137
    Los Angeles, CA
    Tommy Robinson
    Well, my relays, at least fuel pump relays get pretty hot. Even when the cars is just idling for 5 - 10 minutes, touching them for 2 full seconds is hard to do because they're so hot. Maybe that's because my relays are (going) bad. They could be almost literally "burning up". I'm ordering new relays to put on a board like you (Dave) created above, but maybe before I put them on the new board, I'll just replace the existing (original factory-installed) relays and see how they do temperature-wise.
    On another note, I'm no electrical engineer, but I would contend that the metal casings on the relays act as heatsinks, so that's what I'm referring to instead of a traditional heatsink like we find on the ignition coil modules.
  22. turbo-joe
    Apr 6, 2008
    9,395
    romano schwabel
    you may try an other relais for the fuel pums with the same parts number and check if those also will get so warm. if so then th eproblem is not the relais ( or this relais also in not ok ), and if this relais has normal temperature then you know the other is going wrong
  23. Melvok
    Jul 25, 2008
    14,243
    Mel
    Many problems with the relais were published her since a long time.
    Try "Search" function to find these valuable threads ...
  24. Melvok
    Jul 25, 2008
    14,243
    Mel
    Almost a year ago David ... can I find a thread anywhere with your gearbox (gb) story ?
  25. ago car nut
    5,462
    Madison Ohio
    David A.
