TR Engine out service | Page 3 | FerrariChat
Discussion in 'Boxers/TR/M' started by ria, Feb 8, 2018.
  1. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    8,932
    romano schwabel
    good luck - it is no magic to do this all - and if you have problems you may ask here and get the right answers to go on
  2. ria
    ria Formula Junior
    Nov 2, 2003
    732
    ohio
    phill
    thanks joe
  3. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    do yourself a favor - get a two post lift.
    a scissor is adequate
    floor jacks suck
    a four post won’t work
    cheers,
    Vincenzo
    PS: you need a cross beam floor jack (harbor freight) to keep from breaking the rear window
  4. ago car nut
    ago car nut F1 Veteran
    5,267
    Madison Ohio
    David A.
  5. ago car nut
    5,267
    Madison Ohio
    David A.
    Or do a search here and someone came up with a square tubing rear lifter. floor jack in center lift rear cradle and slip in two jack stands. Made from 2" tubing.
  6. ria
    ria Formula Junior
    Nov 2, 2003
    732
    ohio
    phill
    i have a maxjax 2 post lift as my garage ceiling is not high enough for a full 2 post lift i think the maxjax will work and i do not have to worry about the window breaking .
    vincenzo likes this.
  7. versamil
    versamil Formula 3
    1,158
    Gaston, Oregon
    Brian Healy
    "a four post won’t work"
    cheers,
    Vincenzo
    I'm doing the first engine out service my 1990 Testarossa has had. YES I'm quite sure the timing belts are original. The car had a service at five thousand miles, and then a bare minimum service at 14,000 miles. So I'm doing the service on a four post lift. I've got most of the parts off , rear wheels have been removed, and I have Machinery skates under both jack points of the body. I'm going to just roll the entire car to the rear of the four post lift, until my skates are at the end of the runways. I'll have complete access to the entire engine. Is there something I'm missing about four post lifts? I have two 9000 pound Challenger lifts in my shop. I know I'll have a lot more weight on one end, but I'm sure that shouldn't be a problem.The jacking points on each side of the car are behind the engine subframe, so I should have adequate clearance. The car is supported the same way it would be with a two post lift.
    Since I'm doing a major service, I decided to take off the air dam from under the front bumper. Pretty easy to get off. The ONE nut to the left of the AC condenser, was hard to reach, but by half way raising the headlight, removing the bezel and the bulb, I could reach right down and get to the nut. The other side of the car is easy with the battery removed. Probably didn't spend an hour total, and this is the first time I've ever removed it. Ferrari MADE it easy to remove with the slotted mounts.
  8. Gialllo uno
    Gialllo uno Formula Junior
    Jul 5, 2014
    342
    Reisterstown, Maryland
    Mark
    Brian, I know this is an old post, but was wondering how it went with the 4 post lift. I have a 4 post lift also and it is great for somethings and not so great for others. I have entertained the thought of also doing the major myself, but just don't know if I am up for it. I thought I saw a thread in the past about how to do the engine out with a 4 post. Thanks Mark
  9. raysur
    raysur Formula Junior
    565
    So. Cal.
    Jeff
    I have a four post and did my major with it. It was a huge help. I will buy another four post for my new house.
  10. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    Jeff - how did you drop the engine with a 4-post? Did you previously post a thread on that?
    A 4-post is much easier on 4” typical household garage concrete slab. Without a reinforced 6” slab, I would not trust a 2-post lift.
  11. raysur
    565
    So. Cal.
    Jeff
    It was just a post. I'll find it.
  12. raysur
    565
    So. Cal.
    Jeff
    vincenzo and turbo-joe like this.
  13. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    12,662
    San Carlos, CA
    Mitchell Le
    Four post works on testarossa. I could not do it in my garage because of space limitations due to how the lift is mounted in the garage. But, with enough space around the 4 post lift, it's very doable.
  14. turbo-joe
    Apr 6, 2008
    8,932
    romano schwabel
    important is the space behind the lift. so where the back from the car is
