TR/512TR Rear Grill Union P/N 61490900 NLA | FerrariChat
Discussion in 'Boxers/TR/M' started by xplodee, Jun 4, 2019.
  1. xplodee
    xplodee Formula 3
    Jan 3, 2017
    1,101
    Allentown, PA
    Tim
    Hi All-
    Anyone suffering from sagging rear grill on their TR or 512TR should check to see if their rear grill union is broken (the plastic part that holds the two grill halves together and bolts them to the car, also holds the Cavalino emblem). Mine was.
    I modeled and 3D printed some parts that allow me to repair the damage done in the past as this part is completely NLA from Ferrari and my quick search of used parts dealers suggested its going to be hard to find.
    Take a look:
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    c4b4the04 likes this.
  2. xplodee
    xplodee Formula 3
    Jan 3, 2017
    1,101
    Allentown, PA
    Tim
    Side shot better showing how it was repaired:
  3. rpissm
    rpissm Formula 3
    Aug 11, 2013
    1,620
    Salt Lake City, UT
    Joe
    Wow, looks cool. How does the plastic hold up to the heat?
    Sent from my Moto Z2 Play using Tapatalk
  4. xplodee
    xplodee Formula 3
    Jan 3, 2017
    1,101
    Allentown, PA
    Tim
    Time will tell. If it doesn't work out from ABS, I will SLA print it using a resin that can handle 150deg C
  5. c4b4the04
    c4b4the04 Formula Junior
    384
    Northern Virginia
    Cassidy
    Nice job. I have a carbon fiber printer if you need. I could print a set for you too. Comes out very nicely and ready for paint if you didn't like the grey finish. Excellent to see others engineer parts for these cars.
    If you think this stuff doesn't attract new members, think again! One of the ONLY things that help bring me comfort when I started looking for a TR was THIS group.
    Cassidy
    sidewalk and xplodee like this.
  6. xplodee
    xplodee Formula 3
    Jan 3, 2017
    1,101
    Allentown, PA
    Tim
    I’m happy to see another engineer on the board! As the parts become obsolete, it will become our job to create the new ones. This kind of thing is one of my favorite hobbies.
    The parts worked and fit perfectly (after second revision). The ABS seems fine after 20mi or so. I don’t expect any problems because its pretty insulated from the muffler by a few inches of air. I opted not to fill, sand and paint it but that would be a nice touch for obvious reasons despite it not being visible.
    c4b4the04, turbo-joe and blkdiablo33 like this.
  7. c4b4the04
    384
    Northern Virginia
    Cassidy
    The part looks great. Belissimo. I am flying to FL tomorrow evening for my PPI on a TR. With any luck at all, I'll have a Euro spec car to tinker with later this month...!
    xplodee likes this.
  8. SPEED WORKS
    SPEED WORKS Rookie
    Apr 25, 2007
    32
    Orlando, FL
    Bill Fulkrod
    Hello,
    Any chance I can get you to print a carbon fiber one for me? If so, how much?
  9. SPEED WORKS
    SPEED WORKS Rookie
    Apr 25, 2007
    32
    Orlando, FL
    Bill Fulkrod
    Any chance I could get you to print one for me?
  10. Petrolforge
    Petrolforge Rookie
    May 25, 2021
    9
    Petrolforge
    We 3D modelled this support using an original as example, If you need them we can print them in ABS like black resin
  11. Rifledriver
    34,097
    Austin TX
    It needs to be a material with a high heat resistance. Many of those were destroyed by cat overheats. Even without being overheated they get distorted brittle etc over time from the exhaust heat. I would run off a number of them and spread the word they are available. Depending on the price I'd consider throwing a couple on the shelf. That area gets so hot the nylon in the nylock nuts holding in the subframe routinely melts out of the nut. I regularly service cars where they are damaged but still supporting the bars and since they are not available by themselves for a rational price I just blow it off.
  12. Petrolforge
    Petrolforge Rookie
    May 25, 2021
    9
    Petrolforge
    We have a high temp resin to test, should do great up to 250°C.
  13. SPEED WORKS
    SPEED WORKS Rookie
    Apr 25, 2007
    32
    Orlando, FL
    Bill Fulkrod
    Can I get you to print 2 for me?
    Petrolforge likes this.
  14. awatkins
    awatkins Formula Junior
    Apr 10, 2005
    396
    SFO Peninsula
    Alan Watkins
    "It needs to be a material with a high heat resistance."
    Like aluminum or steel? Or is it requirement that it be 3D printed?
  15. Petrolforge
    Petrolforge Rookie
    May 25, 2021
    9
    Petrolforge
    I have sent you a private message!
  16. Karlus
    Karlus Rookie
    Oct 25, 2020
    7
    Karlus Kimball
    Would be great if you could post some images of the finished part! Count me interested too
  17. Petrolforge
    Petrolforge Rookie
    May 25, 2021
    9
    Petrolforge
    Will do as soon as they’re ready!
  18. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,116
    Mel
    Well done !!
    3-D printing, who would have thought that ... :)
  19. Petrolforge
    Petrolforge Rookie
    May 25, 2021
    9
    Petrolforge
    First prints in basic resin to check measurements are done and perfect, now going to print the right materials
  20. Karlus
    Karlus Rookie
    Oct 25, 2020
    7
    Karlus Kimball
    pics? Also, what did you use to "scan" the original piece into your 3d program?
    looking forward to seeing what you have
  21. Petrolforge
    Petrolforge Rookie
    May 25, 2021
    9
    Petrolforge
    Sorry for the bad picture, this is what I have right now, we adjusted the design as we noticed it was 2mm too tall and next week we should have it ready in the right material
    xplodee likes this.
  22. Karlus
    Karlus Rookie
    Oct 25, 2020
    7
    Karlus Kimball
    Sweet. How much you going to charge for these? I would like to be added to the list
  23. Petrolforge
    Petrolforge Rookie
    May 25, 2021
    9
    Petrolforge
  24. xplodee
    xplodee Formula 3
    Jan 3, 2017
    1,101
    Allentown, PA
    Tim
    Well done!!
  25. Petrolforge
    Petrolforge Rookie
    May 25, 2021
    9
    Petrolforge
    Thanks!
    If anyone has some ideas we are open to new projects!
