TPMS recommendation | FerrariChat
TPMS recommendation
Discussion in 'California/Portofino/Roma' started by dinoart, Aug 27, 2020.
  1. dinoart
    dinoart Formula Junior
    789
    Westminster CA
    David
    I recently acquired a 2011 California. I am thinking of getting an extra set of Portofino wheels from a private party. However this set of wheels don't come with TPMS. Can anyone recommend any particular TPMS ? Aftermarket TPMS (under $200 vs. OEM $900) are ok or stay away from them? Thank you in advance for any recommendations.
    David
  2. Wheels1
    Wheels1 F1 Rookie
    Oct 23, 2007
    3,575
    Grant
    Hi David
    I am sure this is not always the case, but I just did the same thing with new wheels and tyres, the tyre depo said they had ones that would work for £300 so they programed them to be the same but they did not work, I spent 2 nights driving around trying to get them to be accepted by the car, I ended up buying ones from Ferrari for £406 so not too much difference, 1/2 a mile down the road and they were working.
    Try to get OEM ones would be my advise, ask for best discount price they can do. I think they gave me 25% off.
  3. Stercrazy
    Stercrazy Karting
    Sep 29, 2017
    115
    NC and FL
    Paul Winchester
    I bought 4 sensors a year ago from Amazon for $80. mine were failing I think because of age, new ones paired up with no problem.
    Copied from my invoice:
    1 of: MOBILETRON 4-Pack 433MHz TPMS Tire Pressure Monitoring System Sensors (Clamp-in) Pre-Programmed for Audi/BMW/Mini/Porsche | OE Replacement | TX-S003-4
    Sold by: MORE SENSOR
    Il Co-Pilota likes this.
  4. Il Co-Pilota
    Il Co-Pilota F1 Veteran
    May 29, 2019
    6,023
    Hopefully some place nice.
    A.B
    It is worth noting that US cars use a 315 mhz sensor.
    These,work with both 315 and 433 mhz systems, so should work no problem. More often than not, sensors simply fail to connect because they are not frequency matched.
    TP.S sensors are really simple devices and Ferrari OE sensors are nothing special - just overpriced.
    https://www.carid.com/smart-sensor/pro-programmable-multi-protocol-tpms-sensor-mpn-17-43042.html
  5. dinoart
    789
    Westminster CA
    David
    Thank you for all the comments. I must choose the right ones because it's costly to remove and replace sensors ($20 x4 or more) for labor alone and lugging the wheels to the shop.
  6. Dicecal
    Dicecal Formula 3
    1,844
    Phoenix, AZ
    Rob
  7. dinoart
    789
    Westminster CA
    David
    STERCRAZY
    The $81 Amazon TPMS worked! No more than 3 minutes the tire icon error message disappeared on the TFT screen. I m glad I went this route since my mechanic quoted me $900 for the OEM. Thanks stercrazy.
  8. dinoart
    789
    Westminster CA
    David
    Forgot the quote
  9. testtest1234
    testtest1234 Rookie
    Sep 8, 2021
    22
    Stupid quesstion on this thread...bought a 2010 cali that does not have TPMS on it. If I just get the sensors can a mechanic get it up and running to show on the display or you had to have ordered the TPMS option originally?
  10. bb2thdr
    bb2thdr Formula Junior
    Dec 23, 2021
    318
    Scott Bialik
    The TPMS system requires the Ferrari TPMS ECU. It send the signals via CANBUS to the display which then interprets the signals. So in the bare minimum you would need to get the ferrari TPMS ecu to integrate. You may need to also update the speedometer can bus interpreter too. So if you want it on the ferrari display, have the dealer do it. The tire sensors are the cheap and easy part.
  11. testtest1234
    testtest1234 Rookie
    Sep 8, 2021
    22
    Got it and thanks. Checked with the dealer and seems sadly that part to do this on the display is not for sale anymore so looks like a 3rd party device for me now is only option.
  12. bb2thdr
    Dec 23, 2021
    318
    Scott Bialik
    you may be able to source the parts on eBay. There are plenty of wrecked californias. so you need the TPMS Sensor ECU with Bracket,the TPMS receiver sensors, the tire sensors, or aftermarket tire sensors, and to be safe buy a speedometer and speedometer can bus decoder. Even if you dont need the last 2, buying from eBay will still be cheaper.
    Then go to a ferrari mechanic and have him install
  13. testtest1234
    testtest1234 Rookie
    Sep 8, 2021
    22
    Assuming even if I get all the parts in the image below it still would NOT work to show on the display as still need to get the speedometer/can bus decoder which has the TPMS UI installed in it right?
  14. bb2thdr
    Dec 23, 2021
    318
    Scott Bialik
    If the speedometer canbus decoder is the same part number with and without the TPMS, then it has it in it already, same goes for speedometer. Ferrari has a small production line and they often make changes along the line as the models develop. Research on scuderia autoparts should have the part numbers, and may even have the parts you need.
  15. testtest1234
    testtest1234 Rookie
    Sep 8, 2021
    22
    Amazing and thank you so much!
