Tow Hook Thread | Page 3 | FerrariChat
Tow Hook Thread
Discussion in '458 Italia/488/F8' started by Need4Spd, Jun 24, 2017.
  1. Carnab
    Carnab Rookie
    Feb 14, 2010
    42
    Arizona
    Carl
    Used wd40 and a jack handle for leverage on the hook. Cleaning threads out helps a bunch. Use a toothbrush or circular bristle brush. It will be smooth once a few threads link in.
    Carnab
    SECRET likes this.
  2. MrJason
    MrJason Rookie
    Jul 23, 2020
    25
  3. rickm360
    rickm360 Rookie
    11
    Calgary, Alberta and Phoenix, AZ
    Rick Matthews
    An old thread but I believe the problem is not shavings in the threads but primer/paint and you just have to either chase the threads with a 16mm Tap or use the provided tow eye and lots of wd40 or something similar and progressively clean out the threads - use a 1ft. x 3/4” piece of dowel to give yourself some leverage. Full seating occurs at 21 - 22 full rotations (whether with the factory eye or the HE one) (mark one edge with a marker so you can count) - until then you ain’t “home”. Ricambi reviews all the tow eyes so you get the right one for your vehicle. The same eye is used on the 360, 430, 458 and 488 just out of interest - the M16 x 1.5.
    Need4Spd likes this.
  4. Snapshift
    Snapshift Formula Junior
    744
    Centralia IL
    Lyle D. Pahnke
    I have a 16mm x1.5 tap if anyone needs to borrow it. PM me for details. i used this to completely chase the threads clean and then protected them with anti seize and a rubber stopper. If for any reason the car becomes disabled, you are lost without a tow hook,
