touch up paint for red wrinkle paint on intake manifold cover | FerrariChat
Discussion in '360/430' started by jpk, Mar 22, 2013.
  1. jpk
    jpk Formula Junior
    I have some small chips, a few milimeters in size (looks like rock chips), on my 360 red intake manifold. Does anyone know a good source for color matched touch up paint to fill in these chips? I don't think they are large enough to warrant having the whole piece refinished at a body shop.
  2. Zcobra1
    Zcobra1 Formula 3
    1,242
    So Cal
    Bert
    Same here. I did a search on this site, and no real leads for a match......
    Mine are 1/4 of an inch, 2 of them, so having a batch of matching paint made up seems like
    overkill.
  3. Chiaroman
    Chiaroman Formula 3
    1,677
    New Jersey
    I have a few chips in the same area that bug me.
    I wonder due to the high heat is it powder coated???
    Do we need special heat resistant paint???
    Will a touch up look "acceptable" then turn ugly when it gets hot???
    Maybe it's best to leave it as is.
  4. KILOCHARLIE
    KILOCHARLIE Formula Junior
    Oct 14, 2012
    321
    Cardiff, UK
    KC
    Would like to know this also please if anyone has any advice? The paint has flaked off around the lettering of the ferrari logo so would be nice to touch this up.
    Would like to spend a day buffing my engine compartment at the same time. Does anyone have any tips on what to use or more importantly what not to use? Degreasers etc?
  5. jpk
    jpk Formula Junior
    Since I didn't get any better advice, I just tried touching the red paint on the air intake plenums myself. I just ordered a small bottle of Rossa Corsa touch up paint from an online touch up paint supplier I found at random. I just entered the paint code for Rossa Corsa. I then applied the touch up to the chips on my plenum. Since my chips are really small, this worked fine. I'm not sure if Rossa Corsa is exactly the same color as the red paint on the 360 air intake, but it sure is close! I had two tiny chips, less than 1mm, that were easy to fill with paint and are now invisible. Before they looked like white flecks. I had one larger chip that was maybe the size of a pea. I filled it in and up close I can see where the touch up is because the texture is not consistent. But at a distance it doesn't stand out and that's good enough for the $15 this fix up cost me!
  6. Newark_Ferrari
    Jun 16, 2005
    13
    Nottinghamshire, UK
    Dave
    If it helps i touched up mine around the 'ferrari' areas the other week.
    I used normal smooth red Hammerite and then hand mixed in a tiny part of smooth black Hammerite until i got the red just the right shade. I went right up to the top of the letters then when dry sanded the red off the top of the letters using a flat block of wood and 400 grit wet/dry to reveal the silver aluminium again.
    Been fine with hot engine temperatures for me so far.
    Dave
  7. SoftwareDrone
    SoftwareDrone F1 Veteran
    Sponsor Owner Rossa Subscribed
    Jan 19, 2004
    7,780
    San Jose, California
    I have been trying to figure out an answer to this dilemma for over a year as I too have a couple of very small "rock chip" like blemishes on my intake.
  8. Kevin Rev'n
    Kevin Rev'n Two Time F1 World Champ
    Nov 29, 2009
    24,322
    Honolulu
    Kevin
  9. Skidkid
    Skidkid F1 Veteran
    9,474
    Campbell, CA
    John Zornes
    Someone on here did this repair maybe a year ago. They posted a thread on the process and paint that they used. I don't remember the thread name but maybe I will have time to search some this afternoon.
  10. jpk
    jpk Formula Junior
    The threads I was able to find on FerrariChat were on some older model forums (512/TR, I believe) where folks have completely refinished the redhead. The finishes didn't quite have the same texture as the original wrinkle. And these were parts that needed to be completely repainted instead of just touch ups.
    For me, the simplest thing was to just get some touch up paint and fill in the chips. Only thing that might have been better than just ordering a standard mix of Rossa Corsa body paint would have been to get a shop to mix up an exact color match. But I didn't know if it would make economic sense for someone local to mix 1/2 oz of paint for me. For those with small chips (the size of rock chips), I think you can get away with what I did. If your chips are larger, then I would guess a full refinish is what is necessary since I didn't hear of any suggestions for how you can touch up a wrinkle paint finish.
  11. Chiaroman
    Chiaroman Formula 3
    1,677
    New Jersey
    I am confused...is this wrinkle paint or powder coating???
  12. jpk
    jpk Formula Junior
    You could be right, the original application could be a powder coat.
  13. Elviz
    Elviz Rookie
    Oct 3, 2012
    1
    Oslo, Norway
    Odd Goderstad
  14. djantlive
    djantlive Formula 3
    Jun 30, 2005
    1,015
    it's crackled paint. not powder coated.
  15. greekgorilla
    greekgorilla Rookie
    Mar 13, 2013
    38
    Danville, Calif
    John Kikes
    I just had Frank at FZ Restoration in Livermore look at mine and he has done them before. The same red, the same wrinkle look. he is located in Livermore Calif. If interested here is the number. 925-294-5666. He just finished my F430 after someone keyed the passenger side and you can't tell the difference. Looks new. Very happy. Also re did my power coated wheels. Just a FYI from a newbie. Gorilla
  16. Monteman
    Monteman Formula 3
    2,342
    Santa Barbara, CA
    Monte
    It's been a couple of years since that last update on this thread but it doesn't look like anyone has found a good color match. Has anyone found the right color to match the air intake plenum cover? Worst case is we can redo them at the major this fall but I hate to wait hat long.
  17. TheGeeMan
    TheGeeMan Formula Junior
    Nov 5, 2003
    275
    Montreal , Canada
    Eddy
  18. Labman
    Labman F1 Rookie
    3,799
    Long Island, NY
    Steve
    Problem is that Maranello painted these plenums/intakes over bare metal and they all will chip off eventually. My 308 plenum was in bad shape so I had the whole thing stripped and refinished. My 430 also had some of the paint come off around the SF shield. I touched that up with that VHT red wrinkle paint but it is a bit too red. I don't know of any other touch up that is an exact color match. I wish there was one. Maybe it has to be custom matched.
  19. 360+Volt=Prius
    360+Volt=Prius Formula 3
    1,762
    Western Mass
    Raimondo
    Been down this road. I tried the can wrinkle paint- too orange, and wrong texture. I ended up removing the plenum and I had it powder coated. Less textured than stock but I think more refined looking and it's vastly more durable. Looks fantastic and cost <100 bucks.
    I did talk to Frank Zucchini and he may be willing to mix up touch up paint for u. I thought I would be able to touch up mine, but after I sent some pics 1/2 " chip, and a couple of smaller chips here and there missing Frank recommend complete repaint. I just decided to powder coat. Frank seems to really know what he is doing and is a really nice guy. Btw He hold me the plenum the same color as the body which I found surprising .
    Frank Zucchi Restoration Inc
    6421 Southfront Rd Unit A
    Livermore CA 94551
    925-294-5666
  20. FerrariCognoscenti
    FerrariCognoscenti Formula 3
    Jan 19, 2021
    2,429
    East Coast
    Any updates on what you guys used?
  21. duskybird
    duskybird F1 World Champ
    12,527
    29 Electoral Votes
    Bill B.
    Actually, yes I found a powder coat company in Ft. Lauderdale that did a fantastic match.
    http://bio-coatings.com/
  22. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,065
    Josh @jtcarprojects
    Powder is the best way. Prismatic powder has a allmost perfect match. The vht can stuff works good but does not match good for the oem look of the ferrari. The right way is to remove and powder coat it. Most of the new stuff is all expoxy and will take the heat.
  23. Jb-Slow
    Jb-Slow Karting
    May 11, 2020
    203
