355 - Torque on Belt Tensioners | FerrariChat
355 Torque on Belt Tensioners
Discussion in '348/355' started by Giallo Modena, Mar 2, 2021.
  1. Giallo Modena
    Giallo Modena Rookie
    Apr 7, 2015
    45
    Minnesota
    K
    I am doing a belt change on my Ferrari F355. Does anyone know the torque spec on the F355 hydraulic tensioners? I replaced mine which were original but when I took it off it had been tightened. Quite tight not loose at all and I thought that part was supposed to move.
  2. Beetle
    Beetle Formula Junior
    Apr 10, 2013
    776
    They shouldnt move only the bearing holder should pivot smoothly.
  3. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,674
    San Carlos, CA
    Mitchell Le
    25 Nm for the M8 bolts holding the tensioner body
    50Nm for the larger bolt holding the bearing.
  4. krazykarguy
    krazykarguy Formula Junior
    Apr 17, 2014
    732
    Fort Mill, SC
    Matt
    The arm on which the tensioner bearing is attached should move freely on it's bushing. At our last major, one of these arms was nearly stuck solid, the other moved easily. Remove these arms, and check for corrosion in the arm pivot.
  5. Giallo Modena
    Apr 7, 2015
    45
    Minnesota
    K
    Got it!
