Top 10 things to do with JB Weld | FerrariChat
Discussion in 'Technical Q&A' started by fatbillybob, Jul 20, 2006.
  1. fatbillybob
    Aug 10, 2002
    28,530
    socal
    No Doubt started talking about using JB weld for things on another weld. He had 2 great ideas and without permission of the owner I'm reposting them here. Please add your own uses to the list.
    NoDoubt: Removing a circlip without proper tools: JB Weld coating on coat hanger ends to each side of the circlip, wait until dry, then squeeze.
    NoDoubt: You can do the same trick with JB Weld and an old allen wrench on a stuck/stripped bolt, too. (this works great on those damn aluminium hexbolts in Ferrari steering wheels that always corrode and weld themselves... fatbillybob)
  2. DavidDriver
    DavidDriver F1 Rookie
    May 9, 2006
    4,424
    Grass Valley, CA
    David Driver
    This is such a good setup I can't resist the temtation...
    So, I'll admit, my mouth is probably a prime candidate!
  3. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Man, don't go there. Tastes like chicken.
    Ba dump bump...
  4. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    I fixed a sink spigot with it once, as a temporary repair just to get me through a few weeks until I could get a new spigot. I replaced the spigot 4 years later when it sprung another leak nowhere near the JB Weld repair!
    Birdman
  5. pete04222
    pete04222 Formula Junior
    Nov 1, 2003
    613
    Maine, USA
    Peter Cyr
    I fixed the valve cover on my Jeep with JB Weld. It was to repair the hole I put in it with a prybar.
  6. wax
    wax Five Time F1 World Champ
    Jul 20, 2003
    52,319
    SFPD
    Dirty Harry
  7. NYCFERRARIS
    NYCFERRARIS Formula 3
    Mar 2, 2004
    1,009
    tried to plug air leaks on a OEM ferrari 16 inch star wheel -- useless.
  8. DavidDriver
    May 9, 2006
    4,424
    Grass Valley, CA
    David Driver
    Okay, here's one that's worthy:
    On my Alfa Spider, the throttle-linkage has one of those plastic elbow joints that screws onto a long threaded arm, under the plenum. The plastic joint stripped, and instead of buying a new one, I coated the threaded end of the arm, and stuck it back into the plastic piece and let it sit overnight.
    That was about 4 or 5 years ago and it hasn't let go yet.
  9. DavidDriver
    May 9, 2006
    4,424
    Grass Valley, CA
    David Driver
    I'm also contemplating doing the same thing with the little A/C knob on my console, since it too is stripped and I can't turn the fan on.
    That should be a good test, because it will get a good workout, because it's the little edges that provide the pressue to turn the knob. Unlike the Ferrari, that uses a hex-nut to hold the knob it place, which (also) is much better IMHO.
    But then again, it's a Ferrari. Not an Alfa Romeo!
  10. Mondog1
    Mondog1 F1 Rookie
    4,176
    Philly burbs
    Robert
    Used it to plug a hole in the AC condensor. It worked for a couple days till the new condensor arrived.
  11. milstanselnino
    milstanselnino Formula Junior
    Jan 8, 2004
    573
    MN
    Jon P.
    Wanted to use it to fix a hole in a piston. Contacted the company; they did not advise that use.
  12. plugzit
    plugzit F1 Veteran
    7,744
    Redondo Beach, CA
    Bruce Bogart
    Patching butt crack.
  13. rolindsay
    rolindsay Formula 3
    Jul 14, 2006
    1,022
    Houston, TX
    Rick Lindsay
    Patched a pea-sized broken out area of an MGB head between the thermostat opening and the housing mounting stud. I used the quick setting kind as it cures harder. The repair involved replacing material which was originally threaded. I chased the threads in the head to make sure they were clean and used a new bolt with clean threads as a 'form'. I wraped the bolt with a round of Teflon pipe tape and threaded it into the hole with the tape extending well above the head's upper deck. Once the J-B Weld cured, the bolt unscrewed smoothly leaving threads all the way to the top. I then filed the J-B to the original thermostat opening shape, repainted the head and it worked great. An added benefit is that the repair was compressed by the gasket once the thermostat and housing were installed. No leaks. Good stuff. -rick
  14. bretm
    bretm F1 Rookie
    Feb 1, 2001
    4,577
    Northern NJ
    Bret
    I used a tube and a half of the stuff a couple weeks ago to seal off the water jackets of a 4.0L head I swapped onto my 4.2L Jeep. Twelve (inline 6) half inch triangular holes on the head mating surface, which my block doesn't have being a 4.2L. Had to pack the head with water soluble packing peanuts.
  15. bpu699
    bpu699 F1 World Champ
    Dec 9, 2003
    17,427
    wisconsin/chicago
    bo
    I have to say, you guys have far more luck with JB weld than I ever did. Each and every time I used it, it promptly failed. The JB weld has ZERO adhesive quality. I have sanded/sandblasted/used acetone/alcohol/etc to prep surrounding metal, and it won't hold...
    Care to enlighten me how you guys get it to stick to metal? Especially in area's that are prone to oil/fuel???
  16. bretm
    bretm F1 Rookie
    Feb 1, 2001
    4,577
    Northern NJ
    Bret
    I've had luck with just roughing the surface up with sandpaper and then brake kleening it to make sure there's no oil. Mix the stuff 1 to 1 and let it set a couple days.
    Thought of another one. I JB Welded a washer onto the high speed jet of the carb on my kart so I can adjust it while out on the track.
  17. Ken
    Ken F1 World Champ
    Oct 19, 2001
    16,078
    Arlington Heights IL
    Kenneth
    The area has to be super clean and dry. The biggest drawback to JB Weld is just what you've noticed: it doesn't stick too well. And if it's in contact with oil, gas or heat cycles, it will come loose.
    I used it sucessfully to repair the metal coller on a distributor where the clamp goes. It lasted until the distributor itself went south from worn bushings.
    I've also used it for kids toy repairs.
    Ken
  18. BT
    BT F1 World Champ
    Mar 21, 2005
    15,291
    FL / GA
    Bill Tracy
    I've never had much luck with it either. Tried to repair a crack in a garage door panel and it just stuck to both sides and made a new crack inthe JB Weld. I'm not impressed at all.
    BT
  19. DavidDriver
    May 9, 2006
    4,424
    Grass Valley, CA
    David Driver
    Hmmm..... That screename has SO MUCH to offer...
  20. DavidDriver
    May 9, 2006
    4,424
    Grass Valley, CA
    David Driver
    Notice, I'm using it on plastic.
    And I've heard that it will work to mount a mirror to a windshield. But I don't have that much patience
  21. Ken
    Ken F1 World Champ
    Oct 19, 2001
    16,078
    Kenneth
    10: Leaky door seals
    9: 355 Header cracks
    8: 308 gas filler neck
    7: 400i levelers
    6: Testarossa tranny bell housing
    5: Testarossa tranny
    4: Loose Mondial fuseblock clips
    3: Oil leak at bung
    2: F40 turbo fan blades
    1: Broken cam belts
    Ken
  22. chris marsh
    chris marsh F1 Veteran
    5,741
    Detroit
    Chris Marsh
    Actually I prefer a product called Devcon, they make an epoxy that is 90% steel and they make an epoxy that is 80% aluminum. Unbelievable adhesive proerties.
    I have patched quite large holes in the sides of transmission cases with it.
    Actually, I was contracted by one of the big three automakers to repair some defective trans cases, they expected weld and remachine. Because there was no heat from the epoxy there was no distortion and no need to re-machine. Afterwards they called me to their plant to instruct their machinists on this method of repair.
  23. Verell
    Verell F1 Veteran
    May 5, 2001
    7,020
    Groton, MA
    Verell Boaen
    When I got my 308 I found that someone had put a crescent shaped layer of what I'm pretty sure is JB weld on the coolant tube that runs across the pulley end of the motor. Funny thing, the patch was just in front of the alternator pulley ;^)
    Anyway, I've had the car for 6 years and it's still on there & presumably sealing a hole.
    Chris, I've had great experience with Devcon's steel & Al filled epoxys. Just after the blizzard of '78 I came across an old Wheelhorse 5hp snow blower in the town dump. Figured at worse I'd be hauling it back if it wasn't repairable.
    Anyway, when I pulled it apart, I almost took it back. I had obviously been run w/o oil. The connecting rod had seized on the crank & melted a deep gouge into it before the rod had broken. Something, probably a piece of the rod had destroyed the casting boss that served as a valve guide.
    However, there was a another major storm forecast for the following week & I hate shoveling snow.
    So I figured I'd see what I could do. Cleaned the block with lacquer thinner, drilled a half dozen or so holes into the area where the valve guide boss broke off, made a crude mold after masking tape, gave the valve a coat of grease & cast a new boss out of Devcon Al.
    Then filled the gouge in the crank with Devcon steel & when it cured filed it level with the rest of the crank, polished it with emory & crocus cloth, picked up a new connecting rod from a local lawn tractor shop & put the whole thing back together.
    Not only did it get me thru that storm, the darned thing was still running when I put it up at the top of the driveway with a 'free' sign on it in '03. I never would have believed that hasty repair would have held up for over 20 years!
  24. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,556
    The twilight zone
    The Butcher
    I've found the bigger the blob, the better the job. pushing it into a crack doesn't work, putting on a big blob does. If appearance matters, I grind the snot out of the crack to get a decent amount of surface area for the glue to bond to. Then it works. I did a crack in the water jacket of a boat engine that went into the oil gally.....that was 20-25 years ago and it's still running as far as I know.
