Tooth found in differential drain | Page 5 | FerrariChat
Discussion in 'Boxers/TR/M' started by c4b4the04, Feb 19, 2020.
  1. EZORED
    EZORED Formula 3
    1,018
    Scottsdale, AZ
    Dennis
    c4b4the04 likes this.
  2. c4b4the04
    c4b4the04 Formula Junior
    384
    Northern Virginia
    Cassidy
    The ‘creep of scope’ has gotten out of hand
    -Frame was dropped off at powder coating last week
    -Top of motor professionally repainted, along with powder coating of intake pieces
    -New clutch, CV shaft boots, valve clearance, cam timing, water pump rebuild, new differential carrier and second gear (while I’m in there)
    -Cleaning and refinishing of every major system and sub system
    Currently my wife thinks the car looks like a plastic model kit that you haven’t assembled yet. The car will be as good as I can physically make it when I’m done, even including a new high pressure AC line to the condenser (came out remarkably easy) run through the frame. I’m at hundreds of hours at this point and it’s kept me sane through the quarantine. Updates to come, I’m looking forward to having her back together. Goal is July 1 for fully done.
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    JL350, Qavion, EZORED and 3 others like this.
  3. c4b4the04
    384
    Northern Virginia
    Cassidy
    Update Mother’s Day edition;
    Newman’s absolutely beautiful differential carrier was test fit this week, waiting on some thicker shims to finish up.
    Suspension painted, new rear rotors, new pads of course, new brass injectors, full gasket set, rebuild water pump, new bearings, professionally painted (I went paint instead of wrinkle) intake and valve cover parts. Tons of detail work, not a restoration but certainly what I would define as a major
    Service. Hoping to finish up transaxle this next week and reinstall in the freshly powder coated frame. New aluminum radiators, new hoses, new AC line to condenser...you get the picture. Lots done and more to go. I’ll do new suspension bushings and rebuild the Konis another time. This is mission critical services now. The costs
    spiraled out of control quickly, at least ones that I hadn’t budgeted for.
    I could not have done what I’ve done without AgoCarNut, Newman, Melvok, Turbo Joe, Rifledriver and a host of you other guys. Thank you. This has been brutal in a one hole garage, simple tools and a quarantine that means it is all on my shoulders to do. No stop-by visitors and I’ve had to work in between massive hour chunks of work. It’ll be worth it when it’s done. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    turbo-joe and Newman like this.
  4. c4b4the04
    384
    Northern Virginia
    Cassidy
    Newman likes this.
  5. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    8,934
    romano schwabel
    nice to hear that I could help you a little ;)
    BigTex likes this.
  6. Veedub00
    Veedub00 F1 Rookie
    Jun 30, 2006
    4,901
    Troy, Michigan
    James
    Hey did I meet your buddy nic in bay city? @c4b4the04
  7. BigTex
    79,218
    Houston, Texas
    Bubba
    You're the Mayor of 12 Cylinder Town....;)
  8. turbo-joe
    Apr 6, 2008
    8,934
    romano schwabel
    12 cylinder twin turbo town please ;)
  9. c4b4the04
    384
    Northern Virginia
    Cassidy
    Indeed you did! Small world, his parents live across the street from my inlaws. Nice looking car, sounded great on the vid clips!
    Cassidy
  10. versamil
    versamil Formula 3
    1,158
    Gaston, Oregon
    Brian Healy
    You said you're in a one car garage, yet in one picture there's a Haas CNC mill in the background, a turret lathe and a manual lathe. You painting
    parts at a buddies place?
    On a side note, how do I contact Newman?
  11. c4b4the04
    384
    Northern Virginia
    Cassidy
    Majority of the (mundane) work is done in my home garage. With gloves, mask and much begging I have a friend with a shop across town. He has been super gracious in helping me with the phases I couldn't possibly do at home. I'm fortunate to have access to those resources. I've been in my little suburb house close to 20 years and wanted a bigger garage the entire time. This isn't the first driveline I've dropped in it, but certainly the most technical.
    As for Newman, he posted in this thread, one of the first pages. Send him a private message, super nice guy.
    EZORED likes this.
  12. c4b4the04
    384
    Northern Virginia
    Cassidy
    Few updates, diff setup complete, trans reassembled and reinstalled in the cradle. Looking good and feeling solid about my work.
    I updated the shifter seal to the later model spring-lip type. The OD of the later seal is 28mm. The ID of the front cover is 29mm. I 3D printed an adapter ring and pressed it in place. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    JL350, Newman, EZORED and 1 other person like this.
  13. turbo-joe
    Apr 6, 2008
    8,934
    romano schwabel
    the pattern looks good :)
    preload right adjusted?
  14. c4b4the04
    384
    Northern Virginia
    Cassidy
    I sure hope so! Lots of hours to get that look. It has good backlash and the best preload I could give it. Rest of my gaskets should be in tomorrow and I can drop the motor back on top.
  15. c4b4the04
    384
    Northern Virginia
    Cassidy
    Waiting on a front cover gasket....I had already installed the front cover and the water pump. Pressure tested for four hours without any drips or pressure loss, only to have the front main seal fold on installation. I had to pull the front cover back off. Installed a new front seal but had to reorder the front cover gasket (ordered with rush shipping...the parts guy rushed and it cracked in three places...now waiting on another out of Atlanta).
    Given me plenty of time to update and touch up the engine bay. Going back to European fuel tank vent and removing the Mercedes canister that was installed. Touched up lots of spots, replaced more braided lines (local company called Colliflower sells braided rubber airbrake lines for trucks, lots of selection and good fitment). Repainted all my exhaust components (non cat models) and finished what I could on the cradle. So far it is looking good, but I am getting impatient.
    pshoejberg, ago car nut and JLF like this.
  16. PA32Pilot
    PA32Pilot Formula 3
    1,813
    Glendora, CA
    Jamie Kirk
  17. c4b4the04
    384
    Northern Virginia
    Cassidy
    Motor back on top, belts test fit for cam timing, water pump held 14 psi for 5 hours. Runners back on top, wiring laid out and test fit cover for cable routing. Making headway! Both axles installed with new CV boots. When you turn the prop shaft, the rotors turn. It’s been a long time to get to that point Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    Newman and TestaDDS like this.
  18. ago car nut
    ago car nut F1 Veteran
    5,267
    Madison Ohio
    David A.
    Looking g real good!
  19. c4b4the04
    384
    Northern Virginia
    Cassidy
    Few updates from the week.... I finally got the proper shims to do the cam timing. What a simple process! It is really something that is easy to overthink. The proper .5mm gap simplifies it all and you can get cheaper shims from several supply houses. My time was worth 4 extra shims! New cam o-rings installed and torqued properly.
    New belts, new bearings and rebuilt tensioners. Fresh PPG two stage finish on the cam belt covers, cam covers and intake really look the part. It won't win for originality but it will look great for many years to come.
    I have a Facebook page that has documented my work since the day I found the car. It never dawned on me to share this with you all. Feel free to follow me if you are on FB, if not I think you can still see the pics.
    https://www.facebook.com/bellarossa2019/
    Newman likes this.
  20. ago car nut
    5,267
    Madison Ohio
    David A.
    After this you should have many problem free miles to enjoy!
    Dave
  21. c4b4the04
    384
    Northern Virginia
    Cassidy
    I've had quite a week of work. The driveline is in, the motor runs strong. Deal with the clutch several times. The formula from the WSM did NOT suit the kit from Eurospares. It calculated that I needed more shim, when in reality I needed much less. Throwout is happier, easier to shift and it isn't slipping. At least I didn't have much to pull back off as I hadn't finished the car yet.
    The trans was overfilled, simply as a byproduct of filling the drop gear multiple times and I developed a leak on the driver output shaft seal. Pulled it yesterday only to have it leak AGAIN. The Ferrari parts used to be Left and Right dependent, now it is a single part number, and it is a single lip seal. I am not impressed. Going to find a double lip, maybe a triple lipped seal. I see some people were using a VW/Audi part number, will get some of those so I have a few to select from.
    AC system is coming on and going off rapidly occasionally, so I will start by making sure I added enough referigerant. If I recall, the system held 40 oz of R12, and I read of FChat the system is happy at 32oz of R134. Proper conversion on the valves and oil was done prior to my ownership, and the system was evacuated, got down to 25-28 inches vacuum while open. The new AC pressure line that I had to run through the frame is working great. I'll get it sorted.
    Idle is too high, resting is about 1600-1800. I have a feeling I moved the big brass air valves when I polished them up. Will hook up a slack tube manometer and see what I get for balance. I had a very low mile Cross-Fire Corvette years ago and I got pretty good at balancing those throttle bodies. This looks to be straightforward.
    Otherwise I am pleased. The motor seems strong and I feel confident in the differential. Seems to be a ever so slight vibration around 2000 rpm but goes away quickly and it constant in all lower gears (haven't driven enough to see if it is present at higher speeds). I have a thought it was the clutch kit.
    Newman likes this.
  22. ago car nut
    5,267
    Madison Ohio
    David A.
    Enjoy!
  23. Steve Magnusson
    25,146
    Make sure the idle microswitch is working properly (before tweaking all the various airflow adjustments). The easiest way to check its operation is to just unplug it at warm idle (even if the warm idle RPM is wrong):
    When you unplug it = the warm idle RPM should increase ~500 RPM.
    If the idle RPM doesn't increase when unplugged = bad idle microswitch or mis-adjusted.
  24. c4b4the04
    384
    Northern Virginia
    Cassidy
    This is the three wire throttle position switch on one of the throttle bodies? I know right where that is. Thank you. Will check that out.
    Is there a good tuning guide on here to reference for various adjustments/gas scans/voltages?
  25. bpu699
    bpu699 F1 World Champ
    Dec 9, 2003
    16,253
    wisconsin/chicago
    bo
    The tooth that came off...
    Could that have been tig welded back on?
    I know on heave machinery the “create” missing teeth with mig/tig all the time...
    Once you’re in that deep though... probably unwise...
