To dip or not to dip, pros and cons | FerrariChat
Discussion in '206/246' started by pshoejberg, Jul 13, 2014.
  1. pshoejberg
    pshoejberg Formula 3
    1,780
    Denmark
    Peter H
    #1 pshoejberg, Jul 13, 2014
    Having just removed all the fiberglass panels from my Dino (What a pita job!) my thoughts are around next step in the process; I'm considering to get the car chemical stripped and "E" primed but I have read a lot of critical comments to that process (see example of process at Paint Stripping, Rust and Underseal Removal for Cars and Industry by Surface Processing Limited ). I'm mostly concerned about any potential left over of acid hidden in small enclosures and what will happen with the lead/tin filler used on these old cars; will that be removed as well?
    Are there anyone on this forum that have any exsperience (Or just an opinion) with this dipping proces and is it worth the money?
    Any comments are much appreciated.
    Best regards
    Peter
  2. mar3kl
    mar3kl Formula Junior
    Nov 17, 2011
    467
    Silicon Valley
    Mark
    Dipping has its pros and cons. I dipped one of my restorations a while back and it worked out beautifully. All the filler melts away, and I didn't see any issues with leading. They neutralize after the dip, so acid shouldn't be a problem. The main problem is finding a place that will do it, because of increasing environmental regulation.
  3. rosso corsa motorsport
    rosso corsa motorsport Formula Junior
    Nov 30, 2008
    268
    you can dip the body but not the chassi, you can never remove acid inside of the chassi tube
    it will come in from all the poor weldings
  4. pshoejberg
    1,780
    Denmark
    Peter H
    I have considered this challenge as well, but many of the tubes are already holed like a sieve due to all the rivets so they will drain naturally, the rest of the tubes could be drilled specifically for drainage purpose (That's also what the dipping companies recommends) I'm more concerned about chemical remains from folded plate joints, but maybe this is not an issue nowadays due to new passivation procedures?
  5. rosso corsa motorsport
    Nov 30, 2008
    268
    you will have a much lighter chassi after he he, that Company dont recomend to dip cars with chassi like on Dinos
  6. rosso corsa motorsport
    Nov 30, 2008
    268
    #6 rosso corsa motorsport, Jul 13, 2014
    i chemically remove all the rust in my shop, better than any blasting, the surface get a protective film afterwards, and i can let this doorskin for 15 years without rust again
  7. pshoejberg
    1,780
    Denmark
    Peter H
    Are there any "dipping" services in Sweden or maybe Germany? One of the cost issues is the long transport route to UK....
  8. rosso corsa motorsport
    Nov 30, 2008
    268
    no there is nobody in sweden doing that, i do it myself on inside and outside of the body but not chassi, that Company in UK dont recomend to do chassi because its impossible to remove all the acid, (and you would need to drill big holes) i see when i do how important it is to remove all acid, if you have any acid left it will eat up the steel
  9. rosso corsa motorsport
    Nov 30, 2008
    268
    if you want to use that Company they charge you about £2000 and you need to do 2 times
  10. pshoejberg
    1,780
    Denmark
    Peter H
    Thanks for the comments!
    Looking at their references I can see they have done at least one Dino. I can't see that they specifically warn about tube based chassis, but they recommend to make holes, this is what they write:
    "Take time to consider the construction of the shell or panels. To ensure the best possible results it is important to ensure that any box sections are free draining and adequately vented. i.e. a hole or two at the bottom and a hole at the top. These areas are often on the underside or inside the shell and can be readily opened up with a drill and if required closed up again later.."
    I have no rust work to perform after the stripping process so only need one stripping dip. That makes it more realistic taking the long and expensive transport into account.
  11. dgt
    dgt Formula 3
    Jan 14, 2011
    1,291
    Northeast, USA & Oz
    Andrew
    Peter,
    I went through this and got alot of advice.
    In the end, hand stripping if there is no rust is best but don't let them do it with a grinder/friction disk.
    I took my L to a specialist grit blaster who use various media of different grades to get all the paint/rust off with no damage. It's around 40 hours of careful work on the chassis/body and I wouldn't recommmend you take it to someone who hasn't done Ferraris. They can't touch the aluminium, must be done by hand.
    Use whatever local specialist you have and the painter recommends.
    Over here they worked together for 20 years to get the best results.
  12. pshoejberg
    1,780
    Denmark
    Peter H
    I have access to a very skilled grit blaster that has done numerous high end cars over the last many years. It's not cheap but I have no concerns at all with letting him blast the car. My only concern is the hidden areas that either the blaster or the painter can reach. Maybe my concern is exaggerated, it might good enough to treat the hidden areas with modern protection wax. That's how we have done it for years with mostly good results.
  13. rosso corsa motorsport
    Nov 30, 2008
    268
    I restore cars professionally to perfection for customers, media blasting of any kind is not good, metal stress and hard, and get dented, some rust will always remain, I have used acid for many years for removing rust, and it removes 100% SPL has only made ONE car with chassis but it was maybe before they saw that it was difficult to clean the inside of the chassis, I talked to Adrian at SPL a few months ago they said it was not so good to deal with a tube chassis because of the difficulty of access inside the pipes, they wanted all the pipes drilled at both ends with 6 or 8mm so they could flush out, if you want to make your car its the best method to completely remove all rust, but you have to drill many holes at each end of each tube. I can assure you that you have rust, even if it looks good, behind door skins front edge to the frame is always rust, front wing against the doors have a double panel That always rusts out to the wing
    there's a company in Norway which makes similar treatment for about 20,000 Norwegian, but they have no after treatment with primer. I think they said that the tin is dissolved, but there are those who believe that tin is not good to use on the body so you can use That plastic body filler shiiit instead
  14. rbsloan11
    rbsloan11 Karting
    Apr 25, 2007
    119
    Carmel
    Rob
    #14 rbsloan11, Jul 13, 2014
    I researched this quite a bit while restoring my Alfa Romeo SS. I have a Dino but didn't do the work so cannot comment. The process works very well for for open frame/body designs, and those that do not have any aluminum. The Alfa SS body (unlike the SZ) is all steel except the front hood lid and large inner aluminum supports within the front steel box sections that the suspension attaches to. These structures are not visible unless these box sections are opened, and I was told the aluminum would essentially dissolve during the process, making the attachment points very weak. My opinion was ultimately to leave sleeping dogs lie, and leave any non-structural surface corrosion on the inside of the car alone - likely this dry film will protect against further corrosion, and to use a mild abrasive agent such as walnut shells/corn husks on the exterior of the car.
  15. pshoejberg
    1,780
    Denmark
    Peter H
    #15 pshoejberg, Aug 2, 2014
    Hi all,
    Based on all the excellent input I have received from this forum and a little further investigation on the web I have decided to go the conventional route and get the chassis blasted and painted manually. I spoke to the blaster and body workshop yesterday and agreed upon a procedure ahead; I have to remove all underbody treatment and other stuff that will be difficult to remove with the blasters abrasive material and clean the entire car from any sticky stuff that can pollute the blasters medium. The door skins will be removed to gain proper access to the inside of the doors for blasting, any potential body work and zinc treatment. After blasting, the chassis will be thoroughly inspected and the needed extend of bodywork will be determined. I started removing the old underbody protection this morning and was amazed to see the amount of unprotected steel there is in these cars, no wonder they tended to rust away. So far I have not found any disturbing amount of corrosion, but the truth will appear after blasting. Have a nice weekend.
    Peter
    My homemade turning tool is the second best tool I have (after the lift)!:
  16. pshoejberg
    1,780
    Denmark
    Peter H
    #16 pshoejberg, Aug 2, 2014
    Made one funny observation....One of the previous owners disliked the recessed nose badge. He cut out the recess and gas welded in a flat plate....Nice work done, but kind a chocking to me. I suspect this to have happened in the early eighties were the car was owned by a gentleman in France. I have seen pictures from this period* and the car was styled with no bumpers to give it a more rough look I guess. Now I have started a nose job on my car:
    * I found this web side that is managed be one of the previous owners: http://246gt.com/pages/main.html Click on "voitures collection" + italian cars and I believe my car #0504 shows up in true eighties style...
  17. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    Have you considered soda or dry ice blasting?
  18. pshoejberg
    1,780
    Denmark
    Peter H
    Yes indeed, but my blaster has talked me from it. He has multiple years (+20) of experience blasting high end cars with semi soft medium and low angle impact and guaranty no damage. The roof and other big flat areas with be cleaned manually to avoid any tension getting into the metal.
  19. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    Looks like a lot of work, I have just also had to scrape all the sealing gunge out before my chassis goes off for soda blasting on Friday. Ferrari's reliance on rivets and gunge makes getting the cars apart again tricky in places!
  20. pshoejberg
    1,780
    Denmark
    Peter H
    It's a terrible job.....I use a gas torch to soften the under sealing and then scrape it off with a chisel. I have kept all the rivet remains in the tubes to minimize the amount of sand etc. getting into the holes. Finally I will soak the car in a petroleum product and steam clean all surfaces and enclosures.
  21. daviekj
    daviekj Formula Junior
    483
    #21 daviekj, Aug 4, 2014
    Reading this thread reminds me of the messy job of stripping the underside. It can be done with several iterations of paint stripper (Nitromors in this case), plastic scrapers, panel wipe, Scotch pads and a Dremel with diamond ball tips to get into the corners and folds of each weld. I also used Jenolite to help etch away and shallow rust in difficult areas, prior to another round of the Dremel. This approach needs lots of patience, but very rewarding to see a clean surface for painting.
    Kevin
  22. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,593
    Toronto / SoCal
    Rob C.
    We used industrial strength paint stripper to remove an incredibly thick layer of tar like undercoating. While the job was very unpleasant and messy, it was more time consuming than anything else. You can see some pics of the work here:
    Dino 246 Restoration Blog: Product Spotlight: Goudey Paint Stripper
    I too was amazed how much exposed metal there was when the fiberglass was removed but was also amazed how rust free most of it was. Of course we gave all this metal as much rust preventative treatment as we could in an effort to slow down future rust creatures.
  23. pshoejberg
    1,780
    Denmark
    Peter H
    #23 pshoejberg, Feb 6, 2015
