Tires spinning on wheels, how to fix? | FerrariChat
Discussion in 'Tracking & Driver Education' started by WILLIAM H, Aug 29, 2015.
  1. WILLIAM H
    WILLIAM H Three Time F1 World Champ
    Nov 1, 2003
    35,532
    Victory Circle
    HUBBSTER
    #1 WILLIAM H, Aug 29, 2015
    So I got new Earnhardt Childress Racing 700hp engine in Corvette DP. We had an issue w tires spinning on wheels. I'm guessing too much torque for the glue on the wheels.
    Other than less throttle which is bad LOL how do I fix this ?
    Also got new aerodynamic package coming soon.
  2. Smyrna355Spider
    Smyrna355Spider F1 Rookie
    Feb 9, 2008
    3,763
    In my Garage
    Scott
    I feel the only way we can solve this will be for me to come up, drive the car and take the bubbles to dinner. Let me know what day works best for you. :)
  3. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    I like your support team!
  4. Entropy
    Entropy Formula 3
    Jul 10, 2008
    2,149
    We had this issue on our race car; front tires would rotate due to braking, rear due to acceleration.
    We seem to have concluded
    1) the Pirellis we are using will seal, but are likely a bit slippery on the bead
    2) we tend to use tires that are recently mounted, we were suspecting the mounting tech was using a bit too much butter...
    3) the wheels are too smooth on the bead surface, and
    4) I was probably being too aggressive too early and pressures were not up
    5) seemed to occur more consistently when on stickers; if I was starting a session with even mildly scrubbed tires, we had less of an issue
    So, seems like we've fixed it by
    1) bead blasted the inside bead surface of the wheels to be a bit grippier - this seemed to be the biggest help
    2) I make sure I have the tires up to pressure, especially when running stickers. Not always convenient, but in qualifying we'll start pressures a notch high, do a couple warmup laps, come in and bleed down and it solved the issue. I've also since stopped using hard braking to put heat into tires on stickers. As a test, I went out and hammered the brakes and the tires rotated 90 degrees up front.
  5. WILLIAM H
    Nov 1, 2003
    35,532
    Victory Circle
    HUBBSTER
    Good one LOL :)
  6. WILLIAM H
    Nov 1, 2003
    35,532
    Victory Circle
    HUBBSTER
    Thanks we are using Pirellis & Dunlops now, had Continentals before
    We usually see it after 20 min on track. I'll pass your ideas along to my. Crew Chief
  7. Ney
    Ney F1 Veteran
    7,336
  8. RotarySwingGolf
    RotarySwingGolf Formula Junior
    Dec 24, 2011
    490
    Florida and Idaho
    Are you using lube when you put the tire on the wheel?
  9. WILLIAM H
    Nov 1, 2003
    35,532
    Victory Circle
    HUBBSTER
    Not sure,they have some glue on the tire but it's not holding at Max acceleration
  10. RotarySwingGolf
    Dec 24, 2011
    490
    Florida and Idaho
    It's more about how they go on. Most everyone uses lube and that's the prob. Your tire guy will hate you because they're a pain to put on without lube but it makes a big difference.
  11. fatbillybob
    Aug 10, 2002
    28,538
    socal
    Bead blast wheel
    Mount with cheap hairspray
    I mount my own wheel tires never an issue since but less horsepower
  12. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    I like it :)
    But, I've got to ask, "where & how did you you come up with hairspray?......" ;)
    Dunno about you, but it's not the first (or last!) thing I'd have tried as a lube!
    Cheers,
    Ian
  13. ProCoach
    ProCoach F1 Veteran
    Sep 15, 2004
    5,465
    VIR Raceway
    Peter Krause
    Not a lube. Gets the rubber tacky so it sticks to the scuffed up inside bead area.
  14. fatbillybob
    Aug 10, 2002
    28,538
    socal
    Took me a while to get good at mounting tires on wheels. Just because a tire is on is not enough. Hairspray is slippery gives about 2 mins working time, glues wheel to tire, and makes up for bad casting flash on Hoosier dotR race tires that often leak as well as spin on wheels.
  15. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    OK.
    Learn something every day.....
    OK.
    But again, hairspray wouldn't have popped into my head as the solution!
    Great stuff! Hopefully the OP will be back soon telling us how it worked....
    Cheers,
    Ian
  16. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,052
    Dumpster Fire #31
    SMG
    Honestly bead locks are probably the best option. There are a couple of forces at play, under acceleration and high velocity centrifugal force is radially pulling on the tire bead, coupled with the air pressure and heat the tire the bead will lift off its seat to where the tangential force of the rim via tq and the contact patch friction on the road can cause slip in relation to the tire bead. Under braking it's heat from brakes adding to the expansion of the air and softening of the tire coupled with the tangential force exceeding the frictional force of the bead seat. i.e. the tire grip and surface area of the contact patch have more 'grip' then the tire bead. If one thinks about it, the entire contact patch has to transmit it's force thru the tire bead seat to the wheel hub, so either both share a similar surface area and frictional coefficient or the bead seat should have a greater coefficient of friction since its surface area is more then likely smaller.
    I know long technical explanation, but sometimes that helps is trying to figure out how to solve a problem.
    hairspray works on plastics and rubbers to make them slippery for brief periods due to the chemical compounds in it, a combination of solvents and polymers. Not to different then what happens in the 'bleach pits' at the drag strip. 'course this all falls under tire dope and the recipes are many.
    bottom line, the tires grip to the road is greater then the grip to the rim.
  17. WILLIAM H
    Nov 1, 2003
    35,532
    Victory Circle
    HUBBSTER
    I'll pass the ideas along to Crew Chief
  18. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    Is there a car in the picture?
  19. Rosso328
    Rosso328 F1 Veteran
    7,295
    Central FL
    Paul
    Obvious upside, I'm guessing the support crew may already have hairspray at hand.
  20. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    +1 :D
    Post of the thread.
    I remain somewhat "concerned" that it's what FBB came up with.... ;)
    Cheers,
    Ian
  21. fatbillybob
    Aug 10, 2002
    28,538
    socal
    I got some good uses for nail polish too.
  22. fatbillybob
    Aug 10, 2002
    28,538
    socal
    I got the idea of hair spray after using bead sealer which is for sticking tires to wheels and sealing beads from air leakage. Then found out Im not the 1st to use hairspray. If the crew chief can bare using hairspray use bead sealer. Get it from myers supply. It was made for these purposes and goes on like heavy black rubber cement and is just nasty messy but it works. Hair spray does the same thing with no mess.
  23. Jungle1986
    Jungle1986 Rookie
    Mar 5, 2006
    5
    #23 Jungle1986, Sep 1, 2015
    Yeh - I remember you showed us earlier - must have taken you ages to apply!
    You were using extra gloss to keep them shiny in your driving gloves right? ;)
  24. fatbillybob
    Aug 10, 2002
    28,538
    socal
    Yes and extra hairspray when driving top down in 355 spyder so my hair stays nice. Shiny car and bad hair is "no es bueno"
  25. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    Me too.... Works a treat as 'thread lock' on RC models. (Not on the threads, but rather the heads.) Any 'movement' shows up as a big ol' crack, easy to see its coming apart!......
    Cheers,
    Ian
