Tire tread de-lamination, Track abuse? | FerrariChat
Discussion in 'Technical Q&A' started by RVIDRCI, Nov 13, 2006.
  1. RVIDRCI
    RVIDRCI Formula 3
    Dec 1, 2005
    1,576
    Long Beach / Phoenix
    Luigi
    So I just did 2 consecutive track days @ Willow Springs with my 308 QV. Upon recent inspection of my left rear tire, I see I have developed tread seperation on the inboard 2" or so on about 1/3 of the circumferance. Tires are nearly NEW Dunlop SP5000's, 90-95% tread remaining, maybe 2 years old mfg date wise. I put them through a lot of hard laps, (warming on an easy lap on cold tires) got them very hot and picked up alot of residual track rubber residue etc.
    Strange thing is, I had the same issue last year on a hard canyon run on my old Michelin TRX"s, same left rear position and inboard delamination. I attributed the first occurance to old dry and past their prime tires, but this repeat on new rubber makes me wonder.
    Could this be an alignment issue? The car runs straight and true with no pull drift or vibration etc. Tire pressure? Driving like an animal ( I did drift the rear of the car very hard on a tight left prior to both occurences)?
    Tire pressures at the track were 28 psi front& rear cold, 30-32 psi on canyon street runs.
    Comments?
    -Luigi
  2. PAP 348
    Dec 10, 2005
    100,199
    Mount Isa, Australia
    Pap
    Im not a track expert. Do you think it seperated because these tyres are 2 years old? Can you track 2yr old tyres without this happening? :)
  3. RVIDRCI
    RVIDRCI Formula 3
    Dec 1, 2005
    1,576
    Luigi
    apparently not. or at least it seems so, thus far.
    The tires were just put on the car new, 500 canyon miles maybe before tracking. But the mfg date is about 2 years ago.
    -L
  4. PAP 348
    Dec 10, 2005
    100,199
    Pap
    Seems that way alright. :)
  5. plugzit
    plugzit F1 Veteran
    7,744
    Redondo Beach, CA
    Bruce Bogart
    What you did wasn't "track abuse" and no excuse for tire delamination. That said, why not go for a hotter tire-some Yoko AO48s or such? Probably good for a year or so and great for canyons and track days.
  6. fatbillybob
    Aug 10, 2002
    28,546
    socal
    Luigi,
    Actually this is perhaps a Ferrair/WSIR problem and too much negative camber. I run -3.25 in the rears and cord my passenger inside every two trackdays with slicks. I am not sure what kills them turn 2 or turn 8 but the draging of the passenger inside bead is like draging your toes while skatebording. You wipeout your shoes. I like the extra camber so I just buy more tires.
  7. Schatten
    Schatten F1 World Champ
    Apr 3, 2001
    11,237
    Austin, TX
    Randy
    I'm quite surprised the SP5000's survived two days at Willow Springs, especially if it was the big track. Those are hard tires and typically like to chunk away at the tread, not really delaminate themselves.
    Got pictures of the tires?
  8. enjoythemusic
    enjoythemusic F1 World Champ
    Apr 20, 2002
    10,676
    Worldwide
    Steven
    Never used Dunlops or those dreaded metric tires. Have done more than 15 track days on Mich Pilot PS2 (and at least another 15 on Mich Pilot Cups). My well-tweaked 308 seems to be relatively kind on tires, and i push them big time to the limits at various tracks. Perhaps you have an alignment problem or something is going awry with your suspension geometry to cause this problem.
    Check alignment, check bushings, check shocks.... If all is in excellent condition and you are using stock shocks and springs, perhaps the lackluster performance of stock is causing too much suspension travel??? Sorry, i use very much uprated suspension so do not have severe body rolling as i regularly see with other (stock) 308QVs. Maybe it is time to uprate your suspension and also corner balance your car weight-wise?
    Again, track the living shiznit out of the 308QV and have very even wear and my tires seem to last longer than i expected given the (ab)use they endure.
    PS: i JUST REMEMBERED that with my old stock suspension the left rear shock (passenger rear on USA-type car) took a dump. Maybe the 308 has some type of weight problem or ???? on that corner in stock form?
  9. f355spider
    f355spider F1 World Champ
    18,027
    When was the alignment last checked/set? I would be curious of the toe setting and camber.
  10. BigTex
    79,321
    Houston, Texas
    Bubba
    Higher pressure in the rear ones is indicated on my door plate.....
    That said..street tires are not track tires, and vise versa..
  11. enjoythemusic
    Apr 20, 2002
    10,676
    Worldwide
    Steven
    Agreed, but for wet days the PS2 seem to do quite ok.
    FYI: In 2007 am dumping the Fcar in favor of a proper track car (Formula Continental), so one could argue that street cars should not be a track car. Many street cars simply can not take the stress.
  12. Ricard
    Ricard Formula Junior
    Jan 23, 2004
    867
    Donington Park
    Richard C
    It depends on how hard you drive of course, but remember that racing tyres are designed for the job and a LONG race is 1 hour +. On a track day you can easily run for 2-3 hours if not more.
    On a dry track the large tread blocks on a new(ish) road tyre will move a great deal generating loads of heat in the tyre which it really wasnt designed to cope with. You can EASILY destroy a set of road tyres a day when driving on a circuit. When we ran an Escort Cosworth high speed ride car around Silverstone it would go through 8 road tyres a day easy (supplied free by tyre company). Even the Caterham's or Lotus Exiges can do a pair of rears a day.
    You are using a road car, with road tyres and road suspension in an environment it wasn't designed to live in. Most people dont use their car to its fullest on track days and get away with high wear - but the more you go the quicker you get the closer you get to needing a racing car, which then isnt much fun on the road...ultimately you need two cars for 2 very different jobs.
    As the button says, Comfort or Sport ? ;)
