tire pressure's? | FerrariChat
tire pressure's?
Discussion in '360/430' started by bocaf430, Dec 28, 2014.
  1. bocaf430
    bocaf430 Formula 3
    Jun 10, 2014
    1,361
    LI, boca raton
    Question for the guys running Michelin tires in size 235/30/20 & 325/25/20 what tire pressure you running? Front tires are such low profile, I want to make sure I'm running with the best tire pressure's...
  2. spourreza
    spourreza Formula Junior
    Dec 28, 2013
    596
    Mount Olive Twp, NJ
    S.Pourreza
    34 in front. 36 psi in rear but mine are 19s that came with car.
  3. bocaf430
    bocaf430 Formula 3
    Jun 10, 2014
    1,361
    LI, boca raton
  4. Ingenere
    Ingenere F1 Veteran
    Dec 11, 2001
    6,432
    On the Limit
    Dino
    The CS is 31F/29R
  5. sunir
    sunir Formula Junior
    Oct 30, 2014
    758
    MD
    Sunir
    Door jamb sticker ussually has the Ferrari recommended tire pressures.
  6. bocaf430
    bocaf430 Formula 3
    Jun 10, 2014
    1,361
    LI, boca raton
    Yeah.. I was just wondering if the pressures for my 20" wheels/tires should be the same as the STOCK size pressure's...
  7. SCKOMS
    SCKOMS F1 Rookie
    3,900
    Lake County, IL
    Spiro
    Call Michelin and ask them.
  8. bocaf430
    bocaf430 Formula 3
    Jun 10, 2014
    1,361
    LI, boca raton
    ok so I called Michelin, spoke with a person on the phone that said he had to calculate the correct pressures for my car, which I told him was a 2005 F430 spider with the custom 20" wheels and my tire sizes,,235/30-20" & 325/25-20" .. He tells me the fronts should be 35psi and the rears 29 psi, prior to calling them I had sent an e-mail asking for the correct needed psi for my car.. same information... today I get an e-mail back saying the car should be set at stock tire pressures which they said should be 32 psi front and 35 psi rears.... go figure..2 different people and 2 different answers..lol
  9. tazandjan
    39,019
    I would use the 32 and 35 as a starting point and adjust from there as you drive her.
