News
458 Tire Options Size
Discussion in '458 Italia/488/F8' started by Joff Clarke, Feb 25, 2020.
  1. Joff Clarke
    Joff Clarke Rookie
    15
    Gulf Coast
    John Clarke
    Hello Folks
    Is it possible to run 305/30/20" in place of the 295/35/20" . I really don't like the tall sidewall on the 35 ratio tires. I'm also considered running 315/30/20" but worried they would be too big for the stock wheels
    I plan on also lowering on OEM suspension and having an alignment.at the same time.
    Any assistance would be appreciated.
  2. ridege55
    ridege55 Formula Junior
    752
    Manhattan Beach, CA
    The width does not seem that much wider and should accommodate. However, the circumference is -3.2% smaller. I don't know if that would be an issue.
  3. ridege55
    752
    Manhattan Beach, CA
  4. Joff Clarke
    Joff Clarke Rookie
    15
    Gulf Coast
    John Clarke
    Thanks I'm thinking the 305 difference is perhaps too much and the 315's may be too wide for my stock rims. Grrrr
  5. Need4Spd
    Need4Spd F1 Veteran
    5,702
    Silicon Valley
    You probably know this already because you’re asking. But you need to know that the car has a sensitively tuned stabilization control (called side slip control and a variety of other names). Only Ferrari knows for sure what tire parameters are important and what are not, but the sensitivity seems driven by the overall circumference of the tires and the ratios of the circumference front to rear. If you vary from either or both by too much, you may encounter odd handling characteristics or error messages.
    bluesea likes this.
  6. Joff Clarke
    Joff Clarke Rookie
    15
    Gulf Coast
    John Clarke
    Gotcha has anyone done this before
    The front tires are 235/35/20 and the rears are 27.2” tall For the 305/30 compared to 28” for the 295/35’s
    Any Ferrari techs out there?
  7. Joff Clarke
    Joff Clarke Rookie
    15
    Gulf Coast
    John Clarke
    Btw I just traded my F430 for the 458 wow what a difference
    up4speed and AlfistaPortoghese like this.
  8. ridege55
    752
    Manhattan Beach, CA
    I have a F430 and 458. On my F430 I am running 245/30/20 in front and 325/25/20 in the rear. Offsets are 20x9 and 20x12 with no rubbing and car is also lowered. On my 458 I am running 245/35/20 in front and 295/30/21 in rear. Offsets are 20x8.5 and 21x11 with no rubbing. 458 is also lowered.
    I know that you have stock wheels, but going to 21" in the rear gives you less sidewall and still stay close to stock on circumference.
  9. Il Co-Pilota
    Il Co-Pilota Formula 3
    May 29, 2019
    1,855
    Copenhagen
    A.B
    Stop stop stop! Don't order anything! Forget the width and all the rest of it. It is a 100% no-go. Many tried it when the Speciale was released. The ESC and ABS system does not work with that much of a difference compared to OE front to rear diameter bias. OE rears are 6% larger in diameter than the fronts. What you're trying to do, is get away with 2.7%. It's a big no.
    Smallest diameter that will work, is 325/30R20. However, the much wider rears will make the car push like mad and understeer into next week.
    Exactly what is your goal? Do you track? Cruise the back roads?
    If you track, I'd suggest getting a set of Speciale wheels and fit them with MPSC2 rubber in 265/30R20 front and 325/30R20 rear. A few dedicated track rats ran that setup in my neck of the woods some years back, and it was a well balanced setup which was much less prone to understeer than stock.
    If you're mostly, or always on the road but you're looking for a bit more width for both looks and bite, MPS4S in 245/35R20 and 305/35R20 is a viable option. This size will fill the large wheel wells nicely, and they will fit the OE wheels.
    Your OE rims can in fact accommodate the F12 set of MPSS should you so desire.
    But again. No to the 305/30 and 315/30.
    GSF355 likes this.
  10. Il Co-Pilota
    May 29, 2019
    1,855
    Copenhagen
    A.B
    You have not posted offsets anywhere. You're giving the width and diameter. Offset is how much the wheel centerline is offset from the hub flange inboard or outboard. Stock 458 offset is about -48mm front and -57mm rear.
  11. mdrums
    mdrums Karting
    Jun 11, 2006
    230
    Tampa
    Like Co-Pilota mentioned...this will not work and cause issues.
    the overall tire ratio between front and rear must be with in spec or ABS and other traction systems will not work properly.
    I use to preach this same thing on the Porsche forums and to my track students. There were many that didn’t heed advice and would mount wider tires and wonder why the brakes felt funny and the car didn’t accelerate well..because the car computer thought rears were spinning and applied brakes to rears.
    Il Co-Pilota likes this.
  12. LVP488
    LVP488 F1 Rookie
    Jan 21, 2017
    2,919
    France
  13. Il Co-Pilota
    May 29, 2019
    1,855
    Copenhagen
    A.B
    Precisely.
    And exactly why I suggest the sizes I mentioned above.
    OP, you need to decide what you are aiming for.
    Both setups I suggested will not affect the ESC or ABS in any way.
    The 265/325 setup only varies 0.7% from stock f/r diameter difference. This is well within the tolerances of the systems. This is less than what is normally caused by wear. The f/r width will go from 25% rear bias to 23% rear bias. On a 458 that is tracked, this will feel super nice as the 458 is a bit prone to understeer. With the Speciale wheels, it will not be a dramatic change which will result in a squirrely and unstable car - especially as the Speciale wheels has 10mm less offset, which will give back a bit of the rear end bias.
    The other setup I suggested using the MPS4S will not change the diameter bias at all. F/r width bias will be ever so slightly moved towards the front, but only with like a half percent.
    Unless you track often, the latter is by far the better choice. A better and newer tyre with both more grip as well as added comfort compared to the OE MPSS.
    Can you run the MPSC2 on the road? Yes, absolutely, but unless it's mostly dry and you generally run your car properly hard, you gain nothing by doing so. The MPSC2 has more grip than the MPSS and MPS4S, but only when properly hot. Fact is that on normal roads, most people do not run an MPSC2 hard enough to benefit from it. Most of the time the tyre temps on the road, even with spirited driving, will be such that the MPS4S or MPSS will have better bite. Below 40c the MPSC2 drops off like an anvil dropped from a crane. Don't get me wrong, it is not dangerous below 40c. I've been in a 488 on a humid 12c day and the car could still be enjoyed and driven properly in Sport as tyres could reach around 40-45c. But a set of MPSS or MPS4S had been a much better choice as temps were mostly around 35c.
    My experience is that if you cannot keep the MPSC2 above 50-55c, don't bother. Then the other offerings will give you better performance. I would like to add that the wider rubber also needs to be driven harder to retain heat, so that's also a factor in your choice.
    So consider your options properly in relation to your needs.
    GSF355 likes this.
  14. Skeet3r
    Skeet3r Rookie
    Feb 15, 2020
    6
    France
    Hello I just bought a set of 458 Speciale rims (9jx20 + 11jx20 / ET-44,7 + ET-48,4) on my 458 Italia. What is best among these 3 options?
    1 - Install the original tires on it. front 235/35/20, rear 295/35/20 ?
    2 - Install the 458 speciale tires on it. front 245/35/20, rear 305/30/20 ?
    3 - Or install a size closer to the original on the rear. front 245/35/20, rear 305/35/20 ?
    I do not intend to track and I would like to go on MPS4S. Thank you ! :)
  15. Il Co-Pilota
    May 29, 2019
    1,855
    Copenhagen
    A.B
    I say again. The Speciale tyre size with the 30 rear aspect ratio will NOT work.
    For road use on those slightly wider rims, the MPS4S in 245/35R20 and 305/35R20 is an excellent choice.
    If you like the and feel more "secure" using a Ferrari spec tyre, you can use the Lusso set. Those are the MPS4S 245/35R20 K1 and the 295/35R20 K1.
    But personally I'd go with the 305/35R20 rear option for road use, so as to not change the balance too much. Will handle great as well as give a great level of comfort, and not change the manners in an aggressive fashion.
    Need4Spd and Skeet3r like this.
