Tire Lettering/Custom Sidewalls | FerrariChat
Discussion in 'Ferrari Discussion (not model specific)' started by F430-, Jan 16, 2016.
  1. F430-
    F430- Rookie
    Oct 30, 2014
    6
    New Jersey
    Steve
    #1 F430-, Jan 16, 2016
    So, after a long search and heavy thinking, I finally stepped out and did custom sidewalls on my 06 F430. I think it looks awesome, and although the Ferrari gets a whole bunch of stares, I can surely say this put it over the edge...
    Got them from TireGraficx out of Jersey.
  2. DrJan
    DrJan Formula Junior
    Feb 28, 2015
    553
    Grand Cayman
    Dr Jan P
    Looks cool!
    Can you do it on other tyre brands too?
  3. Alden
    Alden F1 Rookie
    3,364
    Central Florida
  4. F430-
    F430- Rookie
    Oct 30, 2014
    6
    New Jersey
    Steve
    Yes, that's it!!!! They look awesome. Also I know they have a lot different styles and brands.
  5. DrJan
    Feb 28, 2015
    553
    Grand Cayman
    Dr Jan P
    Could the adhesive do damage to the compound in the side wall?
  6. F430-
    F430- Rookie
    Oct 30, 2014
    6
    New Jersey
    Steve
    No I don't think so... It's a really thin layer of adhesive and seems to be specifically for bonding rubber.
  7. HotShoe
    HotShoe F1 Veteran
    8,576
    Lake Worth, FL
    Anthony Lauro
    Love your rims!
  8. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    They look good............however.....
    To prep the tire sidewall (for bonding of the rubber letters ) you are required to wipe the sidewall down with acetone till it arrives at a grey hue.
    This can't be good for the tire.
  9. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    the adhesive is not the main issue.....wiping down the tires sidewall with acetone till the tires sidewall turns grey is the issue.
    Surely this is not recommended by any tire manufacturer????
  10. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,674
    Lake Villa IL
    They can look neat on some cars. Had a few fly off at 150+mph on the dyno. Was pretty funny to see random letters stuck on the roof and back window afterwords.
    At least they were still on the front tires :D
  11. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    looks neat but only for a show car that is NOT driven.
    safety first.
  12. V-TWELVE
    V-TWELVE Formula 3
    1,800
    Vancouver, BC
    Don't worry about cleaning your sidewalls. LOL! All you are doing is removing the oil that has sweated out of the tire. About 5 to 7 gallons of oil are used to manufacture a tire. Its not just the brake dust people are always cleaning off the tire but oil from the rubber. Grey is the actual color of the rubber once the oil residue on the surface is removed. Tires look awesome BTW. I don't know why manufactures don't offer this as an option.
  13. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    I hope your right.
    I recall in the 90's when tire manufacturers advised against using petroleum based products such as armorall on tires (which we were all doing at the time) as tire dressing because of possible damage to the rubber.
    Today they have specific products for tire dressing.
    Have you contacted your tire dealer or tire manufacturer to inquire if using acetone on the tires sidewall is considered acceptable?
  14. DrJan
    Feb 28, 2015
    553
    Grand Cayman
    Dr Jan P
    Acetone is a pretty strong solvent. It does not sound right to wash and de- oil the rubber compound.
  15. LBBP
    LBBP Formula Junior
    Ok, I guess I'm the only one that doesn't care for the NASCAR look. Unless I'm being paid to promote their tires I'm not making a billboard out of my tires.
  16. blackforestauto
    blackforestauto Karting
    Jul 6, 2007
    185
    Cleveland, Ohio
    Bob
    No, you're not the only one. It is different though...to each his own. And I think the point about strong solvents and rubber is well taken. Time will tell!
  17. technom3
    technom3 F1 World Champ
    17,964
    Phoenix AZ
    Justin
    I don't think fingernail polish is going to due much harm to a tire that gets heated to several hundred degrees and is subjected to thousands of pounds of pressure.
    I wouldn't soak a tire in it... but cleaning the sidewall of it shouldn't cause significant harm. Everytime your car gets washed the tires get "degreased" and many detailers actually use acid...
    acetone is a non issue more than likely... think of half fast it evaporates as well.
    Use your head
  18. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    uh......your wifes (diluted) finger nail polish remover acetone and commercial grade acetone are two different things LOL.
    the commercial grade acetone can dissolve cured epoxy..... and your not using that to remove nail polish.
  19. DrJan
    Feb 28, 2015
    553
    Grand Cayman
    Dr Jan P
    Maybe he does!
    Gives a nice buzz while you do it too.
  20. dm_n_stuff
    Nope, you're not.
    Not a fan. Tire wall is too small to accommodate a billboard for the brand.
    Not like it's a 70 series bias ply tire, after all.
    D
  21. 308 milano
    308 milano F1 Veteran
    Jan 15, 2007
    5,293
    Montana
    Kim
    Yeah, I think that's quite a reach. I like the look, however I had low-profile tires on my Porsche 993 and it Road like a lumber wagon, biggest mistake I ever made with that car.
  22. willrace
    willrace Three Time F1 World Champ
    34,071
    North Tay-has
    Kurt
    #22 willrace, Jan 17, 2016
  23. LV Eric
    LV Eric Formula Junior
    Apr 1, 2006
    541
    LA & LV
    eric
    I was thinking that, came full circle. Comet cleanser lol wow that was a long time ago:)
  24. LV Eric
    Apr 1, 2006
    541
    LA & LV
    eric
    That's for sure
    I'm thinking about a car just for rims like that
