Throttle Cable Clips | FerrariChat
Discussion in '456/550/575' started by scowman, May 27, 2023.
  1. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,547
    Scottsdale AZ
    Stu Boogie
    #1 scowman, May 27, 2023
    1995 US 456GT.
    I bought 3 new throttle cable clips. Ferrari part # 14573987.
    These fit on the tops of the cam belt covers holding the throttle cable as it routes around the front of the motor to the other side.
    Problem is the cable does not want to go into the clip. The little finger pointing up from the middle prevents the cable from going down into the clip.
    Is this one of those "ferrari things" where I have to file the finger down until it's just right or something like that?
    I do not want to press too hard as they are made from the usual break-don't-bend Ferrari plastic.
    Lawyerchef likes this.
  2. AVIMAX
    AVIMAX Formula Junior
    Aug 5, 2014
    705
    Toronto
    Ryan
    Clip goes into the belt cover, the pin is then pushed down to “balloon” the bottom part of the clip to make it stay, then you can put the cable in. Sounds simple, but those pins put up a fight!
  3. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,547
    Scottsdale AZ
    Stu Boogie
    Thanks. I know there must be a trick to it.
  4. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,547
    Scottsdale AZ
    Stu Boogie
    That worked. Like you said it didn't want to go in. I had to hammer them.
  5. Lawyerchef
    Lawyerchef Rookie
    12
    Houston, Texas
    Those pins are hard to hammer in. You were right, they put up a fight!
  6. Mirek
    Mirek Formula 3
    1,460
    Los Angeles, CA
    Mirek
    What was the PN ? I need one and FastCars could not locate one so we used a metal tie.
  7. Aerosurfer
    Aerosurfer Formula 3
    1,788
    Indianapolis
    Nick
    Part number 14573987
    Table 8 on all the part diagrams
  8. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,547
    Scottsdale AZ
    Stu Boogie
    See first post:)
    Mirek likes this.
