Throttle body cleaning | FerrariChat
Discussion in '360/430' started by KILOCHARLIE, Oct 21, 2013.
  1. KILOCHARLIE
    KILOCHARLIE Formula Junior
    Oct 14, 2012
    321
    Cardiff, UK
    KC
    Removed my maf's today and have been cleaning then with maf cleaner. While they are off I want to remove the throttle bodies and clean these also. Do I need to use a specific throttle body cleaner for this or will standard electrical cleaner or similar suffice? Can't see any reason why not but thought I would check.
    Also I want to open and close the throttle body when off the car to clean all inside the joints and on both sides etc. How can I do this properly as I guess since it is a fly by wire operated part there'll be no lever to open and close it manually? Other forums suggest just pushing the flap open and closed manually but I am scared I might force something that might break.
    Finally I want to clean the exterior so it looks good in the engine bay. I've tried degreaser and polish previously but nothing brings it up. Anyone have any suggestions? The metal parts are made from quite poor steel so don't look great to say the least.
  2. 24000rpm
    24000rpm F1 Rookie
    I used a little help from my buddy to open the valve
    Just turn the key to "on" position and let my buddy sit in the driver seat and step on gas pedal.
  3. Trent
    Trent Formula 3
    Dec 10, 2003
    2,013
    Indialantic, FL
    Trent
    +1; but I think at key ON the flap opens and closes anyway with or without the throttle, but have not verified on my 430, just on other fly-by-wire vehicles I operate.
    NEVER FORCE a fly-by-wire Throttle body, they are servo driven and have gears that will strip (in most cases)
  4. KILOCHARLIE
    Oct 14, 2012
    321
    Cardiff, UK
    KC
    Good tip. Will try it later and if not get my ever enthusiastic girlfriend to hold the pedal down! Thanks.
    Any ideas on cleaning the exterior metal up? It looks the cheapest grade on the whole car.
  5. BMWManiac
    BMWManiac Karting
    Apr 22, 2007
    222
    Aberdeen, MD
    Alex
    You can try using brasso and a rag....or buy a can of the Eagle One stuff (the name escapes me right now) that come sin a can...it is the cloth/brasso combination. You just grab some of it and see if it will polish it up a bit.
  6. MKTViper
    MKTViper Karting
    212
    Swan Point MD
    Anyone try painting the throttle body?
    I'm considering using some VHT Grey Wrinkle paint. Obviously will have the battery off when I remove them and tape the hell out of anything I don't want painted.
    Thoughts?
    c928jon likes this.
