Throttle Bodies Show Increased Lag with Age | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by EastMemphis, Aug 14, 2020.
  1. EastMemphis
    EastMemphis Formula 3
    May 25, 2019
    1,738
    Memphis, TN
    #26 EastMemphis, Aug 21, 2020
    I rebuilt one of my TB's today with parts from a donor 0 280 750 474 unit.
    The clips can easily be removed if they are pried from the curved side. Two small screwdrivers opposed pops them right off. Keep your finger on them or you'll be searching the other side of the room for the clip. Take care when removing the plastic face. Pull straight up to keep the motor contacts from being bent.
    Everything appears to be identical, at least in fit. The pickups for the pots on the new one look like they've been cheapened out a bit. Probably an engineering change. The motor housing is spring locked into the body and could probably be removed but I saw no difference between the two and the old one was in good shape. The magnets can come out and they're held in by a spring clip that is a bit tricky to get back in but can be done with just a flat blade screwdriver.
    The inside of both units was clean and without any sort of lubricant. No grease or oil of any kind is inside the case. The motor itself appears to ride on a bronze bearing that's probably self lubricating. Not a lot of spinning going on in this motor so a simple bronze bearing is fine. I saw no evidence of degraded gears. An accumulation of carbon residue was found at the bottom of the motor housing cavity. I shook it out and wiped it down to remove the fine carbon dust.
    The pots are mounted in the plastic face. I could see no easy way to remove the part from the face. Five tiny wires carefully soldered connect the pots to the face. The consequence is that the new plastic face should be used if the pots are going to be included in the rebuilt. That means the wrong part number will appear on the outside of the TB. If that's a bother, then perhaps a way can be devised to remove and reinstall the pots.
    The pots on the old unit had obvious wear. The tracks were shiny and a visible groove existed where the pickup wires travelled.
    The pickups for the pots are tiny flexible wires on a spring arm. They rub against the pot which appears to be coated with something. The old unit showed no sign of degradation so I opted to leave the old pickup and gears in place. The pot pickups are mounted on the throttle valve pivot. In order to change the gear or the pickups, the throttle plate would have to be removed and the pivot would have to be pressed out of the housing. I decided to leave that to a future rebuild. I'm sure these parts can be removed, just not today.
    The central gear just pops out. The motor armature is held in place by two torx 25 screws. Before you remove the magnets, mark them. Switching their polarity will cause the motor to either not run at all, or run in reverse. I put the magnets in upside down in one of the rebuilt units, even though I MARKED THEM. Not only mark them, but pay attention to their orientation when reinstalling.
    Here's what they look like broken down:
    360 unit (Bosch 0 280 750 038)
    Porsche unit (Bosch 0 280 750 474)
    I installed all the old parts into the new donor body first to see if they actually fit. The reinstall process was painless, except for the magnets. They are held in place by a spring clip that has to be pressed into place. I found a screwdriver worked just fine for this task. It was just a little tricky to find the right leverage point.
    The 038 went together the same way as the 474. No surprises. Word of caution: Care must be taken when installing the armature into the motor housing. It goes in with a spring fit. If the motor contacts aren't lined up just right when the screws are tightened, the motor will bind. I found that pushing the armature down manually and then screwing it tight worked.
    Once they were both together, I put them on the tester and check the results.
    038-2-Right
    Before: MDC 61, milliamps 2350, lag 320 milliseconds
    After: MDC 32, milliamps 2635, lag 269 milliseconds
    474-5
    Before: MDC 27, milliamps 3040, lag 240 milliseconds
    After: MDC 39, milliamps 2562, lag 321 milliseconds
    I can see from the results that some losses still are present in the old rebuilt unit. As seen from the new unit rebuilt from old parts, the MDC is higher but not as high as the old unit before rebuild. The components I did not change, mainly the pot pickup, plate pivot and gear are most likely responsible.
    The performance of the rebuilt unit is much improved though. It went from an MDC 61 to 32. That's better than the two working units in my car. The amps are higher from the new brushes and the lag has been reduced considerably.
    I'm going to leave the matched old units in the car until I've run the 150 miles. I want to see if matching the two units solves the issue. If it does, that will be a very nice data point. If I make it to 150 miles or get a trouble code, I'll swap out to the rebuilt units and see how they fair.
  2. EastMemphis
    May 25, 2019
    1,738
    Memphis, TN
    Put another 30 glorious top down miles on the car today. Waited until dusk to avoid the heat. At the end, I even had to turn on the headlights. At first, I put on the mirror heat, thought that was the headlights. Then I remembered. This is only the second time in a nearly a year I've turned on the headlights.
    70 miles down, another 80 to go before I'm satisfied the problem is behind me.
  3. Cribbj
    Cribbj Formula 3
    First, kudos to John (EastMemphis) for delving into this! Not many people are capable (or interested enough) to explore the systems at this level.
    Secondly as most of us are aware there are (at least) two kinds of owners. Those who only want to fix the car when something is broke, and those who want to wring every last bit of performance out of the car. I'd like to think most FChat people are the 2nd variety, but the pro's on here have to cater to both.
    So to respond to Tom's question, yes, I and probably many others here would be willing to pony up the cash to replace the TB's if it could be proven they're causing a stumble, hesitation or the performance is lacking. Would the first variety of owner replace them? Probably not, and he/she probably would be unaware the problem even existed!
    MK1044 and EastMemphis like this.
  4. EastMemphis
    May 25, 2019
    1,738
    Memphis, TN
    And as my research has proven, the rebuilding of an old TB to restore that performance comes WITHOUT a Ferrari tax.
    MK1044 likes this.
  5. Cribbj
    Cribbj Formula 3
    I've always been wary of DBW systems (I was a EE in the past.....) and wondered what the effects of aging would have on them.
    Wonder what will happen when DBW brake systems start aging......????
    I am soooo happy the gas pedal in my 550 Maranello is directly connected to the butterflies in my throttles, and the brake pedal is directly actuating the master cylinder!
  6. EastMemphis
    May 25, 2019
    1,738
    Memphis, TN
    I can officially classify the throttle body problem as solved. Just past 150 mile mark since the changeout.
    I guess this sort of proves that throttle bodies can be tested, matched and replaced with used units instead of spending $3500 for a pair of new ones. My next stage in this process is to replace my qualified used units with two rebuilt throttle bodies using parts from new donor units. That will be an interesting test.
    I've had my car just about a year and 1200 miles. In that short time, I've had numerous maintenance issues but luckily, I've been able to address them myself. Right at this very moment, the car is 100%. Of course that just means I missed something.
  7. Some Guy in the sky
    Some Guy in the sky Formula Junior
    Sep 19, 2018
    347
    I'm interested to see if throttle response improves with the rebuilt units.
    EastMemphis likes this.
  8. 24000rpm
    24000rpm F1 Rookie
    eastmemphis, as a layman, I am not benefited from your discovery! So tell us, how much do I have to pay for a testing service at your place?
  9. EastMemphis
    May 25, 2019
    1,738
    Memphis, TN
    Please PM me for details. Thanks.
  10. Some Guy in the sky
    Sep 19, 2018
    347
    Have you been able to test out the rebuilt Throttle Bodies at all?
  11. EastMemphis
    May 25, 2019
    1,738
    Memphis, TN
    I rebuild one of the old TB's, the worst one, and the results were pretty good.
  12. Some Guy in the sky
    Sep 19, 2018
    347
    I'm going to replace the gas pedal potentiometer this weekend. I will post back if it makes any difference or not. Currently it seems that the pedal is not very sensitive on start up but becomes more responsive as the distance driven increases. At the same time if the car is under about 3200 rpm the pedal needs to move further than I would expect to get the rpms to blip.
  13. EastMemphis
    May 25, 2019
    1,738
    Memphis, TN
    #38 EastMemphis, Sep 22, 2020
    You can easily test the accelerator potentiometer (AP) with a scanner (such as an Autel AP200) that reads voltage from AP pots 1 & 2. Sit in the car with engine off and key on, slowly press the pedal to the floor and watch the volts. The high pot should be twice the low pot in reading. So if the high pot (#1?) is 4v, the low pot (#2) should be around 2v. The variance is something like 200mV (+/-100mV) so there's room for error. The range is something like 1v-4.8v. You should see a pretty much linear rise with no flat spots or lost voltages from the low voltage to the high voltage as the pedal is pressed to the floor. If you don't see a problem with the volts being out of whack, then it's not your AP. It's something else.
    Some Guy in the sky likes this.
  14. f355spider
    f355spider F1 World Champ
    17,937
    If the response from the pedal was out of range wouldn't the Motronic throw a code, or only if way out of range? I have replaced the pedal on my high miles BMW once, as it was throwing a code saying the pedal and throttle body were not responding correctly.
  15. Mor
    Mor Karting
    Oct 14, 2017
    95
    I had the same in my porsche 997.2. It was throttle body fault. When changed (at 56 kkm) till now (134500km) everything great.
    Wysłane z iPhone za pomocą FerrariChat
  16. f355spider
    17,937
    Throttle bodies can get gummed up with blow by or something too. On my BMW I was getting a check engine light for throttle body issues...took off the intake, it was all gummed up. Removed and cleaned, reinstalled, all good again.
  17. Mor
    Mor Karting
    Oct 14, 2017
    95
    I always try first to clean TB, but the porsches one could only be changed. I failed with the cleaning.
  18. EastMemphis
    May 25, 2019
    1,738
    Memphis, TN
    For a car like a Porsche, changing the TB is a no brainer. They're less than $200. For the 360, the cost jumps to a whopping $1750 (at Ricambia) each and two are needed, so trying to fix a TB makes sense in the 360. Turns out the difference between a Porsche and a Ferrari TB is that the vent that attaches to the side of the TB. The Porsche has the vent someplace else.
    The components from a Porsche TB can be used to rebuild a Ferrari TB though. They are exactly the same.
    Mor likes this.
  19. ksanjana
    ksanjana Karting
    Oct 28, 2014
    112
    Houston, TX
    Is there a way to check & see if the throttle bodies are about to go out? Car seems to be driving in limp mode & it fives out P1149 & P1189 codes. Ive replace the accelerator potentiometer by the accelerator paddle. Any suggestions?
  20. EastMemphis
    May 25, 2019
    1,738
    Memphis, TN
    I think the car has tested them for you and they failed. It's virtually impossible to tell which TB has caused this with any standard tool. It could be one or both that's causing the problem. The typical answer is to shell out the $3k+ for two new units.
    You can try to rebuild them by replacing the motor, pots and gears and hope that works. It's 1/10th the cost to do that and if you destroy your existing TB's in the process, you've really lost nothing.
  21. 26street
    26street Formula Junior
    Jan 30, 2021
    343
    Westchester New York
    Mark k
    Wow that’s a lot of work next if you can use a low current AMP probe with a lab scope
    there’s videos online showing how to set it up
    By doing it this way you can map voltage and amperage over time and see how the TB
    motors are working and wear of the brushes plus you can calculate response between both TB’s and the Excelerator pedal position
    This method is the best way for checking the electrical fuel pumps, actuators and other electronics
    I use this method all the time on intermittent problems and more
    Like you said if you where to bring the car to the dealer on a independent repair shop they would just replace the whole unit with out testing the whole electrical Circuit and will only check the wiring or other items if the part they replace didn’t work
    I have had guys come to me after shops and dealers have replace thousands of dollars on parts even wiring harness just to find a simple connection problems
    which will show up by testing with a lab scope
    But it takes time and that’s money which most shops will just keep throwing parts at the car to make more of “if you replace 75% of the parts that can be the problem you might just fix it” or test and fix it right with confidence that’s my way
  22. EastMemphis
    May 25, 2019
    1,738
    Memphis, TN
    I made the decision today to do the unthinkable. I replaced the temporary hose clamps on my throttle bodies with the permanent ear clamps. Now my engine looks right again. Probably get a code on the next drive...
    My "silencer" is some sort of no name item. I haven't found any manufacturer marks and have never seen a unit like this. It sort of looks like a Capristo but the two cans are separate from each other. It's obnoxiously loud. I'm going to pull it this summer and replace with a Ferrari sport exhaust with Tubi headers.
  23. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,380
    The Cold North
    Tom
    You need to realign the clamp on the drivers side. It's not inline with the rest. Yes I am slightly OCD.
