Thermostats removal with engine in.... | FerrariChat
Discussion in 'Boxers/TR/M' started by plip, Nov 12, 2019.
  1. plip
    plip Formula Junior
    Aug 25, 2003
    292
    Switzerland
    Gianni Olivieri
    Hi
    has any of you got any success in removing the thermostats with the engine in situ ? if so any suggestions/trick to be used ?
    Many tks
  2. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,646
    romano schwabel
    what car?
    BB or TR?
    I think TR because you write thremostats and not thermostat
    it is a little difficult but possible. remove the engine hood, put a piece of wood on the engine with some pillows below that you not damage anything, then a thin mattress on, lay down at work. good luck.
    and don´t forget when finished to bleed the system at the 3 bleeders
  3. plip
    plip Formula Junior
    Aug 25, 2003
    292
    Switzerland
    Gianni Olivieri
    #3 plip, Nov 12, 2019
    Guten Tag Romano
    Yes TR 1987. Am most concerned for the 2 nuts which sits against the firewall.....had the engine out until last week but realized that the bleeder on the thermostat is not working only after started the engine. Nothing is coming out. In fact can run the engine without the plug and nothing happens. Seems like the dealer who did the major last time broke the drain plug and let the broken part inside...then they just shorten am M6 bolt and screw it on top.....so cannot get all the air out....had only checked that before...
  4. raysur
    raysur Formula Junior
    621
    So. Cal.
    Jeff
    You could use a vacuum coolant bleeder. You will never need to "burp" a system again.
  5. turbo-joe
    Apr 6, 2008
    9,646
    romano schwabel
    even with such a vacuum bleeder sometimes there remain air inside. so better to bleed right
    had once the same problem after reinstalling the engine. but I fixed it with the engine inside. removed the thermostatcover and fixed the bleeding screw/made something different and works fine.
  6. plip
    plip Formula Junior
    Aug 25, 2003
    292
    Switzerland
    Gianni Olivieri
    Indeed Jeff, was actually thinking of an airlift tool but will need to fix the mess the 'professionals' did one day or the other...
  7. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    Consider drilling a m6 bolt down its centerline a little oversize from the ezout drill bit... let the drilled bolt act as a drill guide.
  8. ago car nut
    ago car nut F1 Veteran
    5,552
    Madison Ohio
    David A.
    Or left handed drill bit,
  9. turbo-joe
    Apr 6, 2008
    9,646
    romano schwabel
    just had a look at some pictures when I did this with the thermostat-bleeder
    I removed the complete thermostat housing. for this remove as I have written already the engine hood ( I not did this but it would be easier to work then ) and the small black rear grill behind the rear window.
    have a look at my "bed" to work on :)
    and also the bleeder I did
    plip likes this.
  10. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    Included in the kit...
  11. plip
    plip Formula Junior
    Aug 25, 2003
    292
    Switzerland
    Gianni Olivieri
    Tks all for the hints. Broken plug out....air out...now the fan starts and stop as they were supposed to. Need to balance the banks with the vacuum gauges and then is ready for the winter sleep and could tackle the Alfa..... the winter is still quite long over here.
