Thermostat-gasket sealer-yes or no ? | FerrariChat
Discussion in 'Technical Q&A' started by spiderseeker, Oct 9, 2007.
  1. spiderseeker
    spiderseeker Formula 3
    Jul 22, 2005
    1,718
    Colorado
    Steve
    I'm changing my 308 thermostat as I speak , I was wondering if gasket sealer is recommended for a water tight seal- if so, what type of sealer ?
  2. Darolls
    Darolls F1 Veteran
    7,782
    Sparky
  3. spiderseeker
    Jul 22, 2005
    1,718
    Colorado
    Steve
    Thanks, I guess it's not necessary, the reason that I asked was that the old thermostat DID use some kind of black rubber sealant, permatex type.
  4. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,761
    Cerritos, CA.
    I know it's not proper but, before I made a gasket out of a cardboard from the back of a pad paper and used it on my thermostat housing and lasted me for five years without any sealant and not a single drop of watter. Make sure you torque that bolt for the T-stat housing properly and not to over tightened it.
  5. spiderseeker
    Jul 22, 2005
    1,718
    Colorado
    Steve
    Do you know what the proper torque is in Ft LBS or inch lbs? (I know that it's pretty low)
  6. miketuason
    Feb 24, 2006
    15,761
    Cerritos, CA.
    Unfortunately no, I just went with my 25 years of experience feeling, I do so much of this in the past I can preety much feel it.
    But I wouldn't go over 10lbs
  7. Ken
    Ken F1 World Champ
    Oct 19, 2001
    16,078
    Arlington Heights IL
    Kenneth
    Silicone as a gasket substitute is never a good idea. If you use too much (as many people tend to) little blobs will squeeze into the water passage and eventually break off. One can imagine the problems if it then got caught in a narrow coolant passage. My thermostat uses a cardboard gasket, no sealent. It's never leaked.
    Ken
  8. spiderseeker
    Jul 22, 2005
    1,718
    Colorado
    Steve
    I meant in ADDITION to the paper gasket. Just a thin coat of permatex or something similar was on it before, especially around the bolt holes.
  9. Ken
    Ken F1 World Champ
    Oct 19, 2001
    16,078
    Kenneth
    What does the manual say? All cars are different; when my thermostat died (stuck open) I found I didn't even have a paper gasket! It had nothing, nada, but wasn't leaking. My manual said to use a paper gasket so I did when I replaced it. My point with not using gasket goo is that if it's not needed, you're risking a problem if you're sloppy with it. If your car leaks coolant without it, then use it but not too much.
    Ken
  10. spiderseeker
    Jul 22, 2005
    1,718
    Colorado
    Steve
    I was sent the wrong paper gasket , so I won't be finishing it today. (I know that I could make one but, I want the correct one-willing to wait).
  11. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    You should be able to find a website on line that will show you the correct or quite close to the correct torque. You simply have to look up the size of the bolt and know the thread pitch (by measuring it) and you will get an idea of the torque. I say idea because other factors come into play like what type of plating the bolt has, what strength it is (8.8 etc.), if the threads are lubricated etc. For a small, non-critical bolt like this it's really not important. I'd be more concerned with stuff like head bolts, wheel bolts, suspension bolts. Do you have a torque wrench that will actually be accurate at such a low torque setting for these small fasteners?? If not, there is not much point to all this anyway.
    If you're still not comfortable with that then used the lowest torque you see listed for the fastener. If there's any seepage/leakage then tighten a bit more. Kind of like brass fittings.... if anything, undertighten. If the joint leaks/weeps then snug it up a little more until it stops.
    I would just tighten them gradually in sequence using a small ratchet (1/4 inch) until they feel snug. You can use Loctite if you're worried they will loosen. More importantly the Loctite may reduce or eliminate the chance of corrosion on the threads for when you want to unscrew them again 5 or 10 years down the road.
  12. Ken
    Ken F1 World Champ
    Oct 19, 2001
    16,078
    Kenneth
    Loctite?? Use the wrong type and you'll need a torch to remove the bolts! I would NOT use any Locktite on a thermostat housing! I wouldn't think the bolts coming loose is likely anyway if snugged down even close to what's reccommended.
    Ken
  13. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,567
    The twilight zone
    The Butcher
    I like permatex aviation sealant, particularly on old parts with a bit of pitting. The gasket should seal witout it, but it will seal with it...every time, and I hate doing things twice.
    I never though about loctite on the threads (the purple, not the red) for corrosion control, but it's not a bad idea. I generally use neversieze as long as there is a lock washer, if not there's no lock washer the loctite seems like a good idea anyway.
  14. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    Yes, and use the wrong tire (speed rating) on your Ferrari and you could have an accident. Drop a lit cigarette in the forest and you may start a fire.
    Disclaimer: Okay, do not use the wrong type of Loctite. Objects in the mirror are closer than they appear etc. etc.
    If the bolt threads corrode they may not come out either. My concern was more about preventing corrosion than worrying about the bolts un-doing themselves.
  15. spiderseeker
    Jul 22, 2005
    1,718
    Colorado
    Steve
    I'm going to install the thermostat without any sealer of any kind , then report back if any leaks appear.
    I've cleaned all of the surfaces and set the thermostat in place, the gasket should arrive today. (It's on a Fed-Ex truck with delivery due today)
    Daniel and David at Ricambi are the best ! (they sent the wrong gasket by mistake and Fed-Ex'd(overnight) the correct one) Now that's great customer service !
  16. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    If the surfaces are smooth and flat it should seal fine without anything else.
  17. Ken
    Ken F1 World Champ
    Oct 19, 2001
    16,078
    Kenneth
    I would venture that if corrosion is a problem, you need to change the coolant more often. For cars that expect to have deferred maintenance, you make a good point. I use anti-seize on spark plug threads only. On my car at least, things tend to fall off as it is so I don't need to encourage them! *S*
    Ken
  18. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    No arguement there. I change coolant every two years (and brake fluid every year). But, corrosion could be there from neglect by previous owner(s) too. Also, I would venture to guess that not every owner is as conscientious about coolant change as we are or maybe even aware of the effects. Hell, I bought a $200 digital pH tester to check coolant on my cars. Tells a lot and can be used to check pH for many other things. Much better and much more accurate than those test strips.
  19. Martin308GTB
    Martin308GTB F1 Rookie
    Jan 22, 2003
    4,252
    Black Forest Germany
    Martin N.
    Hello from Germany,
    if one uses the wrong Loctite the studs will come out of the housing together with the nut. Nothing more. The blue Loctite stuff 243 is the most appropriate product for most applications on our cars. Prevents corrosion, secures the nut or bolt and you can undo them with normal tools.
    But for your initial question. I always use a tiny amount / thin smear of a non harding sealant on most paper gaskets. I would call it 'gasket-optimizer'. Never had a leak and never had problems with sealant seeping into the internals.
    Best Regards
    Martin
  20. gabriel
    gabriel Formula 3
    Using it sparingly on the plugs is very good. :)
    I also use it on every bolt that goes into aluminum and any bolt that goes into the exhaust.
    And on my wheel splines. And axle nuts.
    Things like threaded rocker studs get the correct type of thread lock.
    The stuff is great. Sparingly. We use it on aircraft all of the time and most of the material on aircraft is some type of aluminum.
  21. gabriel
    gabriel Formula 3
    +1 Exactly.
  22. spiderseeker
    Jul 22, 2005
    1,718
    Colorado
    Steve
    Finished , no leaks (yet) , no sealant used.
    Still in the add antifreeze, bleed air mode.
  23. Mark 328
    Mark 328 Formula Junior
    Nov 6, 2003
    510
    Orange, Ca
    Mark Foley
    I like the red, spray Permatex. It puts a thin coat that (I hope) would help seal thru some pits and it is real easy to get back off.
    BTW, it is a good idea to open the bleeders while you are pouring the coolant in. If you wait until you are all done, you may trap some air in the system.
    Mark
  24. tazz99
    tazz99 F1 Rookie
    4,418
    Kennesaw, GA
    Seth
    To late to help the original poster, but I recomend using Aviation Permatex on paper/cardboard gaskets. It is pretty thin and you just brush a light coat on both sides of the gasket. It was originally designed to seal the two crank case halfs when assembling opposed aircraft engines so it takes heat pretty good and is oil resistant. I would not use it in high heat applications.
    For anti-sieze compound I use Never Seez Pure Nickel Special, another product used extensively in aviation, on spark plugs, jet engine igniters and boroscope plugs. Just use a LITTLE, on the bottom couple of threads is all that is necessary
  25. jon s
    jon s Formula Junior
    Mar 9, 2005
    509
    pocasset ma
    jon shoukimas MD
    i used the permatex hypolon - it remains very soft and the parts are very easy to remove if needed. jon s
