The Ultimate "Sticky interior fix" experiment | Page 3 | FerrariChat
Discussion in '348/355' started by treedee3d, Mar 9, 2012.
  1. treedee3d
    treedee3d F1 Rookie
    Apr 1, 2011
    3,721
    Montreal
    Fab
  2. 355 Shwing
    355 Shwing Karting
    Sep 9, 2009
    156
    Gulf Breeze, Fl
    Craig Payette
    I just sprayed it and scrubbed it with a toothbrush, no soaking or waiting. I initially intended to let it sit for a while before scrubbing it, but as soon as I sprayed it, the gunk started coming off with the touch of my finger. NO need to scrub very hard at all. It did take about 3-4 applications.
  3. GerryD
    GerryD Formula 3
    May 5, 2010
    2,436
    North of TO
    Guido
    Just wondering, did you use the multi-purpose or the super strength?
  4. 355 Shwing
    355 Shwing Karting
    Sep 9, 2009
    156
    Gulf Breeze, Fl
    Craig Payette
    The bottle says both super strength and multi-purpose.
  5. cscott
    cscott Formula Junior
    Dec 31, 2002
    478
    New Orleans
    Chris Scott
    Inspired by the two threads, I pulled my parts out and refurbished. Fairly easy but I did not like the finish of plasti-dip. I could not get it right so I used a satin finish.
  6. stevew3765
    stevew3765 Formula Junior
    Oct 27, 2012
    716
    Tulsa, Oklahoma USA
    Steve Wool
    Hi. I was wondering what technique was used to paint the switch casings particularly in between the actual crevice between the bottom of the switch and top of casing without over spraying the switch as it is a glossy black with no problems......thanks in advance...
  7. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    10,629
    CT
    John Kreskovsky
    If you want the best match to the OEM gloss level then I would suggest Krylon Semi-Flat black lacquer. Spray Paints | MSCDirect.com
    Make sure to get the lacquer, not the Rust Tough Enamel.
  8. stevew3765
    Oct 27, 2012
    716
    Tulsa, Oklahoma USA
    Steve Wool
    thank you. But, my question was more about how than what...:>)
  9. johnlaviola
    johnlaviola Rookie
    Sep 30, 2013
    41
    Orange, CT
    With my current project being the interior of my 2000 360 Spider, this thread has become my new home! Thanks for all the forum Q and A, it's been very helpful.
    Some updates/comments/questions:
    After much searching, it appears that treedee's recommended Krylon Outdoor Spaces textured black spray paint is no longer being made. Can anyone else confirm this? I just can't find it! I may have to settle for the Rustoleum/Tremclad.
    I'm using the treedee's recommend SEM 15243 satin black with excellent results on most plastic and metal surfaces.
    I haven't touched my interior door handles, but they're up next. The textured/satin combination finish is what I'm likely to use (that's why I'm trying to find the Krylon textured spray!).
    Does anyone know a source for the "< LOCK" decals on the 360 interior door handles?
    Any advice would be greatly appreciated.
    Thanks,
  10. treedee3d
    treedee3d F1 Rookie
    Apr 1, 2011
    3,721
    Montreal
    Fab
    John, I don't have any info for you in regards to the availability of the paint. However, I must tell you that the reason I did so much research and testing was to achieve the same finish as the ricambi hvac panel cover replacement.
    I just cannot stand looking at 355 interiors where that finish is different than the rest of the center console/dash. I guess it's an anal-ocd obsession with consistency troughout that inspired all the time I spent on it.
    I like the finish, I like the texture and it's very durable so I am happy. But I would not have done all this if it wasn't for that panel because frankly all the other finishes seemed just as good.
    So unless you're trying desperately to match something in your 360's interior, don't go nuts trying to find the exact same paint, they're all pretty much the same.
  11. jellypig
    jellypig Karting
    May 6, 2013
    76
    East Midlands, UK
    Not seen this thread before, good work!
    Quick question - did any of the exterior grade textured paints you trialed have a texture similar to the texture of the targa roof panel?
    I have some dints (caused by the seat screws) that need adressing, but dont want to sand flat.
  12. treedee3d
    treedee3d F1 Rookie
    Apr 1, 2011
    3,721
    Montreal
    Fab
    Can't say....I haven't seen a targa top up close
  13. jellypig
    jellypig Karting
    May 6, 2013
    76
    East Midlands, UK
    #63 jellypig, May 6, 2014
    Texture and "dint" in the photo below.
    (5p coin is approx 18mm (0.7") diameter) Dint caused by previous custodians allowing the roof to "rattle about" when stored in the car against screws in the back of the seat.
  14. amattox1
    amattox1 Rookie
    Nov 30, 2013
    44
    Bay Area CA
    AMattox
    Great post!!! I cant wait to start the process you have lined out on my 348 this weekend.
  15. treedee3d
    treedee3d F1 Rookie
    Apr 1, 2011
    3,721
    Montreal
    Fab
    Try using Grease Lightning cleaner instead of the Easy Off, I haven't tested it but several fchatters have said it works better.
  16. ClydeM
    ClydeM F1 World Champ
    10,462
    Wayne, NJ
    Clyde E. McMurdy
    I haven't used easy off, but I did just do my driver side window switches using Greased Lightening, a tooth brush, and Plasti-dip primer & plasti-dip black. Looks perfect and has the same surface feel as the originals.
  17. treedee3d
    treedee3d F1 Rookie
    Apr 1, 2011
    3,721
    Montreal
    Fab
    I found the plasti dip to be less resistant to heat and it did scratch easily and may be prone to peeling. Plus it does not match the hvac panel so I'm not a fan of plasti dip when it comes to a finish for sticky parts but many others have used it and they're happy.
    I'm also concerned with the durability of it. my recipe makes for a hard finish that does not damage easily.
  18. ClydeM
    10,462
    Wayne, NJ
    Clyde E. McMurdy
    You used the plasti-dip primer first? With just plain black plasti-dip, I found the same as you did mentioned above.
  19. treedee3d
    treedee3d F1 Rookie
    Apr 1, 2011
    3,721
    Montreal
    Fab
    no primer...wasn't available in spray format so I didn't bother
  20. roadracer311
    roadracer311 Formula 3
    May 6, 2009
    2,398
    San Francisco
    Paul
    #70 roadracer311, May 10, 2014
    Primer makes all the difference with Plasti Dip. My interior door handles have held up to about 3 years of use. I love that it maintains the original feel and texture. At the time it was only available by the quart, so I bought an HVLP gun to shoot it. Now you can order it in spray cans.
    I shot my Ricambi heater-control overlay panel with plasti-dip primer and clear plasti-dip, in order to make the entire interior consistent and feel original. The clear Plasti-dip is more fragile though. Impacts from sharp objects will create light spots.
  21. Terry
    Terry Formula Junior
    Nov 3, 2003
    250
    Cheshire, UK
    Terry
    #71 Terry, May 10, 2014
    I found Plast-dip primer used first makes a big difference to the adherence of the top coat. I also find mixing from the can with Plast-dip thinner applied with a gun gives the best finish.
    You can also use Plast-dip clear over the HVAC panel to give the same feel as the other panels. I obtained a brand new HVAC OEM panel that fits onto the unit and that was the same finish as the aftermarket ones available. A coat of clear Plasti-dip provided the right finish.
  22. Klas
    Klas Formula Junior
    Mar 17, 2014
    327
    Gothenburg, Sweden
    Klas Nilsson
    I have the same problem as everyone else seems to have with their 355:s. Anyhow, I tried a shortcut to get rid of the sticky surface. I sprayed black matte shrink paint over a sticky surface (after disassembling of course), as that paint gives some kind of a light rough structure. Worked very well and I did not spend anytime on removing the sticky ****. Did of course not this on the buttons as I don't want to loose the symbols. There I did it the hard way instead.
  23. Badabing!
    Badabing! Formula Junior
    Mar 30, 2014
    731
    NYC
    Is plasti dip primer clear? I assume it must be or how else would you spray your HVAC overlay without obscuring the markings?
  24. jimmym
    jimmym Formula 3
    Sep 30, 2008
    1,967
    Northeast U.S.
    Jim
    You guys do some nice work. Paint work looks very nice.
  25. amattox1
    amattox1 Rookie
    Nov 30, 2013
    44
    Bay Area CA
    AMattox
    #75 amattox1, Jun 1, 2014
