The F50 Thread | Page 103 | FerrariChat
The F50 Thread
Discussion in '288GTO/F40/F50/Enzo/LaFerrari' started by amenasce, Dec 28, 2010.
  1. joe sackey
    Sponsor
    May 23, 2006
    57,288
    Southern California
    Joe Sackey
    NürScud and Camelot like this.
  2. Marcel Massini
    Honorary
    Mar 2, 2005
    22,739
    NürScud, Camelot and joe sackey like this.
  3. joe sackey
    Sponsor
    May 23, 2006
    57,288
    Southern California
    Joe Sackey
    456-boy likes this.
  4. futurelegendyyc
    Jul 23, 2019
    25
    Anyone here know if it takes modification to the f50 gearknob to fit on the f40 and if so what modifications are needed .Any help would be appreciated
  5. mikesufka
    mikesufka F1 Veteran
    6,547
    Crosslake, MN
    Mike Sufka
    Quite the garage … great picture.
    MDS
    joe sackey likes this.
  6. joe sackey
    Sponsor
    May 23, 2006
    57,288
    Southern California
    Joe Sackey
  7. Johnny_Bravo
    Johnny_Bravo Formula Junior
    Dec 7, 2012
    420
  8. joe sackey
    Sponsor
    May 23, 2006
    57,288
    Southern California
    Joe Sackey
    If you are using VIN plates as a reference for curb weight, then this is the difference as noted therein:
    Eu/ROW F50s - 3351 lbs/1520kg (as illustrated below).
    USA F50s - 3440 lbs/1560 kg.
    A difference of @ 11 lbs, approximately the weight of a well-fed cat.
  9. iohead
    iohead Karting
    Feb 19, 2013
    142
    The weights on the VIN plates don't mean what I think you think they mean.
    The USA plate lists the Gross Vehicle Weight Rating (GVWR) as 3,440 lb. It means that's the maximum the vehicle is rated to weigh with all fluids, accessories, cargo, and passenger(s). In other words, you must not pack any load (be it humans or objects) into the vehicle such that its resultant total weight exceeds the GVWR value.
    Note that the GAWR rating lists two numbers, both of which add up to the GVWR. The "A" stands for axle. In other words, that's the maximum you can load the front and rear axles. (Of course, the car doesn't literally have to have an axle, as in the F50's case, so interpret is as the maximum permitted weight on the front and rear wheels.)
    The European plate says the same thing in a different format.
    These plates do not list the kerb weight of the vehicle, which is what I believe you guys are interested in. And in that regard, the USA car is indeed heavier. The USA and European F50 manuals say the following for the kerb weight:
    • USA: 1,360 kg / 2,998 lb
    • European: 1,320 kg / 2,910 lb
    That's a more sizeable difference of 40 kg / 88 lb.
    These weights are not necessarily real-life, so the only way to ascertain is to actually weigh both versions of the car oneself, which I really ought to do at some point, but it's a chore.
  10. joe sackey
    Sponsor
    May 23, 2006
    57,288
    Southern California
    Joe Sackey
    The stated GVWR on the VIN plates is a difference of 11 lbs between the Eu and USA cars, so it's interesting that the stated curb weight (without fluids, accessories, cargo, and passengers) increases to a difference of 88 lbs between the Eu and USA cars in the owners manual, why doesn't the difference remain a relative constant given that the considered variables are the same?
  11. iohead
    iohead Karting
    Feb 19, 2013
    142
    As you can imagine, the USA car is heavier because of the various homologation-related things they had to add. Those things go wherever they need to go: for example, if the doors need extra reinforcements, that's where that additional weight goes. Once all is said and done, the additional weight is distributed within the car based on necessity and not optimality of location.
    Since the suspension and the desired front/rear weight distribution is the same between the two versions, the GAWR values must be recalculated for the USA version taking into account that some weight has been added. You will see that the USA and European GAWR numbers lead to the same front/rear fully laden weight distribution. GVWR then just follows from the GAWR numbers.
  12. Johnny_Bravo
    Dec 7, 2012
    420
    So much does the car weigh on itself, with a full gass tank, all fluids, etc, but without any passengers ?
  13. joe sackey
    Sponsor
    May 23, 2006
    57,288
    Southern California
    Joe Sackey
    @ 12 years ago, Bill S weighed my client's USA F50 with a full tank of gas and it weighed in at 3,137 lbs, he calculated that the car's weight on an empty tank was 2,963 lbs assuming a 27.7 gallon tank and 6.28 lbs per gallon.
    Of interest, the USA F50 is 120 lbs lighter than a USA Enzo and 222 lbs heavier than a 288 GTO.
    Johnny_Bravo, BJK, NürScud and 2 others like this.
  14. Terra
    Terra F1 Rookie
    3,677
    Just a correction on the maths: 3440lbs - 3351lbs = 89lbs (not 11 lbs)
    This is also confirmed when doing the metric weight calculation: 1560kg - 1520kg = 40kg (88lbs)
  15. joe sackey
    Sponsor
    May 23, 2006
    57,288
    Southern California
    Joe Sackey
    Thank you for that, I don't know how I got that wrong, anyway, we can accept that there is @ 88/89 lbs between the USA and Eu F50s.
  16. joe sackey
    Sponsor
    May 23, 2006
    57,288
    Southern California
    Joe Sackey
  17. futurelegendyyc
    Jul 23, 2019
    25
    Saw an argento f50 with R6II BEC white front plates near Lake como yesterday. Does anyone know if this a true argento ??
  18. amenasce
    33,014
    Joe Mansion
    NürScud, tomc and TexasF355F1 like this.
  19. Marcel Massini
    Honorary
    Mar 2, 2005
    22,739
    What's the guy doing with his Bimmer?
    Marcel Massini
  20. RotKopf
    RotKopf Karting
    Jul 27, 2004
    208
    Preparing to make a Vettel move...
  21. joe sackey
    Sponsor
    May 23, 2006
    57,288
    Southern California
    Joe Sackey
    NürScud, YellowF50, 456-boy and 2 others like this.
  22. LamboLover
    LamboLover F1 Rookie
    Jul 16, 2006
    2,534
    Texas
    Rick
    NürScud likes this.
  23. amenasce
    33,014
    Joe Mansion
  24. amenasce
    33,014
    Joe Mansion
