Of course every engine is different, as are the conditions under which they are tested. Direct comparisons of just a couple of engines don't tell us all that much, but with enough samples we could start to get a much better idea of what works and what doesn't. It's your car and you're paying for the tests so you can do with them what you will, but I'm not sure what is gained by withholding the graphs. Just makes it that much more difficult for everyone else trying to find the most expedient path. Don't know why I started looking at this thread again in the first place-- I gave up on it being truly useful early on.
Well when that megasquirt local to you is installed, you might be set. Sent from my SM-G930V using Tapatalk
Getting rid of the metric fittings replacing with AN6 and 8 from 6 to 8 mm id. You can see them side by side Adjustable Areomotive regulator and that wonky return line replaced with a proper one that wont pop off Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Thanks you inspired my chaos LOL Almost there taking a break Looks so sweet naked, these are pretty motors Image Unavailable, Please Login Image Unavailable, Please Login
Let me assure you that we have done this and the jury is home with their families. Stock with a better single can exhaust 284 HP. Add Goth exhaust and all the stuff we described here and its 302 HP. Tim's car should pull a little bit more (304 HP), like Ernie's did due to the taper in their TB's. My TB bore was straight cut and about 0.50 mm narrower. On a Dynapak. And Tim's numbers are only pertinent to Tim's engine. The difference is the main datum. The actual numbers are relative. Still, Timmy-boy, I'd post everything, but that's just me. Of course, those Mustangs are murder on your ego...
I've never cared about peak numbers, but more about the area under the curve. That's where dyno graphs are nice to see. Sent from my SM-G930V using Tapatalk
My stock with test pipes and a single can muffler 294 hp. With TB's, Fabspeed headers, ported intake and plenum with new injectors and custom chips 305. About $1,000.00 per HP. Ferrari did not lesve much on the table. Ported TB's and Beta1 chips is the way to go IMHO.
Nice port matching intake to heads is a wonderful thing. Stooges will see the numbers at a stoogefest so we can recon on them I backpedaled a little this round. Stock headers, ported TB's. Chips, port matched heads to intake cleaned runners. The stock intake manifold in my eyes is 1980's GM quality LOL. I say that as the cranckcase ventilation system left signs of bad flow, eddy's in a few runners. ITB's should fix this right up Image Unavailable, Please Login
Bigger valves. Need bigger valves. And more and longer lift. Til then, a bigger carburetor (figuratively) won't help much, if any. Just my opinion.
I suppose that isn't surprising given the stock management config and proximity of those opposing throttle bodies. Would it be beneficial to do an enlarged but bank-independant plenum arrangement? Perhaps repositioning the throttle bodies to flow and manage velocity to the outer cylinders better?
Complete 355 throttle bodies Cleaned/flowed injectors with new O-rings and tips 348 conversion plates with all hardware. Will require some final port matching. Please PM for price, or see my ad in the classifieds with many other 348 parts Image Unavailable, Please Login Image Unavailable, Please Login
Wow. Were these ever fitted? Also do you have the upper manifolds that go on this? Just wondering what else I would need to make a setup like this work. Obvioulsy the 355 airboxes, possibly adapt the 348 MAF's etc. I understand this would probably benefit from an aftermarket ecu as the 348 computer would probably not run this setup as notbody would be able to tune it (atleast not here in australia)
I don't have the 355 plenums. I was going to use Ducati velocity stack and custom air cleaners. I never fit them to my motor, but I was following the work that Plugzit did in his build thread. http://www.ferrarichat.com/forum/348-355-sponsored-bradan/125988-355-throttle-bodies-348-project.html
touché Have a spare bullet and rear cradle, all I need is H pattern ZF and in it goes No more Mr nice guy, Enzo was a nut massager Image Unavailable, Please Login Image Unavailable, Please Login
