The Bumper Grommets Thread | Page 2 | FerrariChat
Discussion in '206/246' started by simonc, Dec 21, 2010.
  1. omgjon
    omgjon F1 Rookie
    3,569
    Spicewood, Texas
    Jon Gunderson
    US Model 8X$79=a lot
  2. TKO
    TKO Formula Junior
    Oct 22, 2004
    790
    SoCal
    Tom Kearns
    $79 for a set if I remember correctly.
  3. omgjon
    omgjon F1 Rookie
    3,569
    Spicewood, Texas
    Jon Gunderson
    I called and they wanted $79 each!!
  4. champtc
    champtc Formula Junior
    Apr 18, 2004
    732
    Ask Alberto to make some and lots of people will buy em!
  5. racerboy9
    racerboy9 F1 Rookie
    2,671
    This is a re-post I made about the grommets:
    Don Rudd gave me some he made playing around casting a rubber-like compound while at T Rutands years ago. I didn't think much of it at the time but when I finally put them on the car they were fantastic. Tight fit, proper look and seemed very durable. May have been a polyurethane product or similar. Search Google/Youtube for casting plastic, rubber and maybe urethanes. The casting process seemed pretty easy and there are various compound for different levels of hardness.
    This seems like a job for Verell!
  6. outofpocket
    outofpocket Formula Junior
    Dec 6, 2007
    261
    Midwest
    GD
    #31 outofpocket, Jan 26, 2013
    If the grommets go over the tubes extending from the body my paint guy measured them at 1 1/4 inches. This is a US spec model. Did he measure incorrectly?
  7. omgjon
    omgjon F1 Rookie
    3,569
    Spicewood, Texas
    Jon Gunderson
    #32 omgjon, Jan 31, 2013
  8. Edward 96GTS
    Edward 96GTS F1 World Champ
    11,101
    $ 20 each is peanuts in the scheme of things. i vote to spend the $20 each. what is that total. $160? cheap compared to the labor to remove bumpers and install if done at a later date. sorry, jmho.
    ed
  9. omgjon
    omgjon F1 Rookie
    3,569
    Spicewood, Texas
    Jon Gunderson
    I will say the grommets actually fit much better as they are more pliable and a snugger fit. Let's see what others have to say.
  10. swift53
    swift53 F1 Veteran
    8,490
    E.S.
    Alberto
    Grommets.
    Regards, Alberto
  11. racerboy9
    racerboy9 F1 Rookie
    2,671
    I would toss this project to Verell and see what he has to say. $79 a grommet is far beyond reason to me. $79 a set is not so bad. That bumper grommet seems to me a very easy piece to cast.
  12. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    GOOD NEWS: I'm sure I could make them, would need at least one in very good condition for a mold pattern, as the reproductions would exactly duplicate every detail of the pattern. They would be made of chemical & uv resistant polyurethane.
    To get the cost down as much as possible I would have to make a mold from the original, then make 7 more pieces to make an 8 part mold. I need to know the weight to get a good price estimate, but most likely we'd be talking $120 - $160 for a set of eight. A lot would depend on the yield. Another cost factor would be the yield. Depending on a part's shape, it can be hard to avoid getting a small surface bubble or 2.
    Some pictures of the part by itself would be a big help.
    BAD NEWS: I'm still badly backlogged on promised molds, including the door pocket mold, and have almost a 4 month queue of column switches to be restored, so it would be several months before I could possibly start on one.
    synchro likes this.
  13. HMB-Dino
    HMB-Dino Formula 3
    2,338
    Pebble Beach, CA
    RonG
    This is just an fyi...I have not acquired these (NA for my Euro M-series).
    FERRARI RU-RBG
    DAYTONA/DINO REAR BUMPER GROMMET
    PRICE PAIR 60.00
    ID RU-RBG
    New Items | Perfect Reflection Products
  14. racerboy9
    racerboy9 F1 Rookie
    2,671
    #39 racerboy9, Feb 18, 2013
    synchro likes this.
  15. daytonaman
    daytonaman Formula Junior
    May 1, 2007
    986
    Australia
    howard pigdon
    Racerboy, do you know what colour that green is ?
  16. racerboy9
    racerboy9 F1 Rookie
    2,671
    The color is verde medio metallizzato.
    synchro likes this.
  17. outofpocket
    Dec 6, 2007
    261
    Midwest
    GD
    Where did you find them?
  18. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    They fit the tubes with the correct inner diameter, have the correct surface curve but are hard plastic so do not contour to the body well and are not probably the best product.
  19. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    Any word on the backlog?
    I could provide one of Don's repros that is new but you would be making a "cast of a cast"
  20. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    Is it difficult to make a casting for soft stuff like this or are there difficulties I'm not seeing?
    I may start these up myself if I can ...
  21. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    #47 Verell, Jul 29, 2020
    Casting is not hard, designing & making a mold that will produce multiple ones without bubbles is. The mold is silicone. Once mixed you pull a vacuum on it to eliminate mixing bubbles, then pour the silicone over the pattern & cure it under 40psi pressure overnight. I use modified medical autoclaves
    When casting a part, you also have to cure the filled mold under 40 psi to ensure a void free result.
  22. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    Any updates?
    I lost one
