Testarossa Top Of Engine Refurbish | Page 6 | FerrariChat
Discussion in 'Boxers/TR/M' started by Shamile, Nov 9, 2010.
  1. Philwozza
    Philwozza Formula 3
    Apr 23, 2009
    2,045
    Winchester UK
    Phil Worrall
    Now I know where your "O" rings fit I will ask Ash to post some photos :D
    Ash cant wait to visit Florida again.........
    P
  2. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    #127 Shamile, Jan 16, 2011
  3. Philwozza
    Philwozza Formula 3
    Apr 23, 2009
    2,045
    Winchester UK
    Phil Worrall
    Oh how I love these plumbing photos, especially the ones with ladies mechanicing........
    P
  4. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    #129 Shamile, Jan 16, 2011
  5. Philwozza
    Philwozza Formula 3
    Apr 23, 2009
    2,045
    Winchester UK
    Phil Worrall
    Who is Kerry, Shamile?
    Are you spoken for now???????????
    P
  6. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    #131 Shamile, Jan 16, 2011
  7. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    Dear Ferraristi,
    Bawhahaha....no, our own Fchat black sheep Kerry W.
    Shamile
    Freeze....Miami Vice !
  8. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    #133 Shamile, Jan 16, 2011
  9. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    #134 Shamile, Jan 16, 2011
    Dear Ferraristi,
    I took the throttle bodies apart as it was more thorough cleaning. The gaskets are still available from Ferrari and the nuts are standard stainless steel nylocks with wave washers. The nylocks use the white insert instead of the yellow. I suspect Ferrari was supplied the complete assembly from Bosch.
    Yellow Nylocks.
    Yellow Nylocks are a Ferrari specific nylock. I was trying to search for the source and spoke directly to the manufacturer through one of my industrial fastener suppliers.
    As soon as I asked for the yellow, he said...Ferrari. I asked how he knew and told me that there are certain OEM specified fasteners. Ferrari's color is yellow and has nothing to do with any kind of spec. You cannot buy a yellow nylock insert unless someone is selling you something on the side or a defective batch.
    Shamile
  10. Steve Magnusson
    25,149
    Shamile -- Where did you get the 4-place tube clips from? (Last time I went thru this exercise only the 3-place tube clips were available.)
  11. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    #136 Shamile, Jan 16, 2011
  12. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    Dear Ferraristi,
    Hi Steve,
    I got them right from my local Fpimp.... Ferrari Of Central Florida.
    Shamile
  13. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    #138 Shamile, Jan 16, 2011
    Dear Ferraristi,
    ...still scrubbing...
    Time to clean out the throttle body linkage. Whow..that grease is dry and hard packed!
    I cleaned out the linkage with carb cleaner and my toothbrush. Since I haven't heard of a good replacement for white lithium grease, I put fresh grease with a Qtip and made sure nothing went beyond the edges.
    The linkage is an interesting design. You don't "snap" it on but undo the back end..which is held by a cotter pin. When cleaning out the backing cap, I put a dab of white lithium grease and screwed it back in until tight against the ball. I then backed off the cap until the linkage moved freely with no back-and-forth play.
    Shamile
  14. Steve Magnusson
    25,149
    Thanks for the sourcing information Shamile -- I'm glad to hear that these parts are available again.
  15. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    #140 Shamile, Jan 16, 2011
  16. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    #141 Shamile, Jan 16, 2011
  17. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    #142 Shamile, Jan 16, 2011
    Dear Ferraristi,
    ....back to the fuel injection....umm...yeah..
    I tried cleaning the 1/6 fuel distribution unit to death. It's still binding and the meter plate does not pop up like the 7/12.
    I went ahead and decided to take it appart...nothing to lose right??.. :D
    Now with it open, I could really clean in there. I put some PB Blaster on the pivots and let it soak overnight.
    hmm....still binding....
    Shamile
    Freeze...Miami Vice !
  18. GatorFL
    GatorFL Moderator
    Moderator Owner
    Nov 18, 2005
    16,390
    Wellington, FL
    Duane
    Double butterfaces
  19. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    #144 Shamile, Jan 16, 2011
  20. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    Dear Ferraristi,
    Aww...boo...Cayleigh's a cutie !
    Kimberly makes up in personality...she's really fun...
    Shamile
  21. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    #146 Shamile, Jan 16, 2011
  22. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    #147 Shamile, Jan 16, 2011
    Dear Ferraristi,
    OK, no good on the spring....
    Dave H mentioned on the pivot under the circlips and aluminum cover is a ball bearing and spring.
    OK, I removed the circlip, cover and with my lighted magnet, pulled the ball bearing out. I've put some PB Blaster in the pivot cavity and will leave it overnight.
    I doubt it will do any good but it's worth a try. The other side of the pivot is unaccessible as it's under a module with no screw attachments.
    The only other thing to remove is the distributor itself, swap it with the other side and see if it's binding in the distributor.
    Any suggestions or tips would be helpful. Dave H was rather surprised that a good cleaning didn't free up the meter plate.
    ....ran into Julie (22)
    Shamile
  23. uzz32soarer
    uzz32soarer F1 Rookie
    Sep 9, 2006
    3,088
    Melbourne, Australia
    Robert Hayden
    Hey bloke, I've run into issues where the metering plate has shifted slightly causing it to not really bind, but just not be as 'fluid' to the touch as the other side. I released the plate by the central nut and using feeler gauges I reset it to be exactly in the centre.
    There were the lightest of abrasions where the edge of the plate had been in contact with the wall so a very light polishing by hand with some emery paper sorted that, just don't take any material off. Reset the central position of the plate and then try it.
    It's easy to remove the two distribution units and you can set these upside down on the bench and press the central pin down. If one is different to the other I'd be very suprised as there is sweet f#@k all in the way of moving parts in the head that can bind up.
    Keep up the good work, oh...and by the way, good thing you are spending all this time off the dance floor cleaning that flthy old car, it sure needed it!!! LOL.
  24. uzz32soarer
    Sep 9, 2006
    3,088
    Robert Hayden
    Hmmm...........Julie looks like a very healthy young lady.....nice!
  25. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    Dear Ferraristi,
    Hey Uzz!
    I don't have a problem with the meter plate touching the sidewall. It's very well centered. It just doesn't come all the way back up to the top and bounce a couple of times like the other side.
    It feels like it's binding in the pivot or if the pin that goes inside the distributor itself is the cause.
    If I hold the unit at an angle ( to accentuate the counter-balance weight) the meter plate pops right back up and bounces. As soon as I level it....as it would sit in the car, it won't pop back up and sticks.
    Do you think it's something in the distributor head? Tomorrow, if the pivot is still binding...that's the only place left to go. I can't gain access to the other side of the pivot as it has a module stuck on the outside. I can't see a way of taking it off without breaking the plastic....can it be removed?
    Dirty TR?? The only way you can make my TR dirty is to have strippers all over it...umm wait... you're right...my TR is a very dirty Ferrari...:D
    Shamile
