Testarossa Top Of Engine Refurbish | Page 4 | FerrariChat
Discussion in 'Boxers/TR/M' started by Shamile, Nov 9, 2010.
  1. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    #76 Shamile, Nov 21, 2010
  2. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    #77 Shamile, Nov 21, 2010
  3. Mr.Chairman
    Mr.Chairman F1 Rookie
    Mar 21, 2008
    2,987
    New Jersey
    Robbie
    Your better off waiting until you have enought time to do the complete job.. Its really not that hard and the best part Shamile is that you can do two plugs per day , every other day etc.. and continue to use vehicle. The rest for the top is the entire kit.. Looking good....
    R
  4. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    #79 Shamile, Nov 21, 2010
  5. Spasso
    Spasso F1 World Champ
    Feb 16, 2003
    14,648
    Land of Slugs & Moss
    Han Solo
    You can do the rest of the system after you put it back on the road but it is a good idea to have the "tune" checked before you do the entire kit and then have it retuned after. You will see a difference in the fuel/air mixtures change if nothing else.
    I found that I had better hot and cold starts after the kit was installed.
  6. Spasso
    Feb 16, 2003
    14,648
    Han Solo
    #81 Spasso, Nov 21, 2010
    Talk to Mister Helms about those resistors. He has a background in electrical engineering and can probably tell you exactly what affect those have on the switch.
    I'M NOT AN EXPERT but I would hazard a guess that those alter the "time" of the "Thermo-Time Switch" which probably alters the cold start/air pump activation-cut-off times.
  7. Steve Magnusson
    25,149
    #82 Steve Magnusson, Nov 21, 2010
    What a bizarre modification that sort of works against itself. Can you confirm that they are both 1000 Ohm resistors? If they are:
    1. The 1000 Ohm resistor in the BL (white/blue) wire would greatly slow the heating inside the thermotime switch so it would stay closed longer during starter motor cranking when cold, and fire the cold start injector for a longer time (if there were no other modifications); however,
    2. The 1000 Ohm resistor in the RV (red/green) wire would probably prevent relay U from closing so the cold start injector would never fire during starter motor cranking when cold.
    The way the stock system works (on a US version TR) is, when the TTS is cold, the contacts inside the TTS are closed -- which connects terminal 85 of relay U to ground (via the RV wire). When you start the engine (key in Pos III), +12V appears on terminal 30 and 86 of relay U -- this closes relay U, which connects terminal 30 (which is at +12V as long as the key is in Pos III) to terminal 87 which goes to fire the cold start injectors.
    Since there is now a 1000 Ohm resistor in series with the ~150 Ohm coil of relay U, my guess would be that relay U never actuates (even though the TTS stays closed longer) -- so your cold start injectors never fire. I know that you are in Florida Shamile, so maybe not a big deal for you, but the way to test this is to hook a 12V test light between the orange wire in the j connector and ground that you can see from the Drivers seat when you do a cold start. The way it should work is:
    1) for the first second, or two, of initial dead-cold starter motor cranking, the test light should illuminate (showing that relay U is closed and the cold start injectors are firing),
    2) After a couple seconds (when the TTS opens and relay U opens) the light should go out even if the starter motor is still cranking.
    PS The technical data in the TR WSM on pages D18 and D39 are for the TTS used on the euro K-Jet TR. The US TR uses a different TTS that only has internal heater coil W1 -- there is no W2 heater coil so the resistance values in Tab. 4 do not apply.
    Good hunting!
  8. Rifledriver
    34,119
    Austin TX
    I could understand maybe the one on the TTS if you lived very high and in a very cold climate but on both makes no sense.
    I suspect it was a misguided attempt to fix something.
  9. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    #84 Shamile, Nov 21, 2010
    Dear Ferraristi,
    Thanks Steve/ Rifledriver...they're coming out! Steve...1000 ohms....on the money.
    I think my cold starts weren't working. One time, I was looking for some running issue and pulled the plug on the cold start just after I started the car cold one morning....no change in the engine pitch....
    I wonder......everytime I start the car cold, it only starts on the second crank.....I mean for the last 10 years ...like clockwork. Crank...catches and dies. Second crank...sputter to life. But if the car is warm....VROOM ! right on the first crank.
    Shamile
    Freeze...Miami Vice !
  10. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    #85 Shamile, Nov 21, 2010
  11. Steve Magnusson
    25,149
    #86 Steve Magnusson, Nov 21, 2010
    Definitely a sign that your cold start injectors aren't working IMO -- my TR starts (and stays running) on the first crank, cold or warm, winter or summer (in CO or TX ;)).
    If there been stale fuel in the lines and cold start injectors for 10+ years, they might not wake-up too happy...just a (bad) thought (in case, for example, they stick open or shut after you get the electrics working)...
  12. AdvenDriver
    AdvenDriver Rookie
    Nov 10, 2010
    28
    PA/NJ Line at Rt 80
    Shamile,
    I am gonna read through this whole thread; it's GREAT!
  13. JTR
    JTR Formula 3
    Apr 26, 2005
    1,502
    in a house
    :D I can't believe it! :D
    I can't believe that you actually cleaned the intake valves!
    But now I'll be disapointed if you don't clean the exhaust valves as well!!!
    Nice looking gals too!
  14. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    #89 Shamile, Nov 28, 2010
    Dear Ferraristi,
    Oh....man, 2 birthdays....two double pint sz. Long Islands later....
    1. Brittany's 22nd Birthday! Gency (20) on right
    2.Megan (24) Megan (23rd!) on right
    3. Brittany (22nd! ) Katie (21) Kay (21) Coco (22)
    ....back to my normal... :D
    4. Oh...yeah...this is what I was working on...
    While I was waiting for more connectors and the board's advice on what to do with the resistors...cleaning cleaning and more cleaning valves...
    I removed the resistors and put the connectors back to normal. What the "hack" was compensating for....we'll find out when the car goes back together. Of course, it'll be fixed properly!
    Shamile
  15. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    #90 Shamile, Nov 28, 2010
  16. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    #91 Shamile, Nov 28, 2010
    Dear Ferraristi,
    1. Katie (21)
    2. Ohhh looky! More connectors from Dave Helms.
    To clarify....
    Dave sent me the improved connectors with my hoses because he felt it important to do it while I was in there. Sooo....since I was in there, I asked to buy the rest of the connectors for the top of the engine. Dave then explained to me that he really doesn't sell them by sub package but the whole complete kit....the only way he can make something on it. I didn't know this at the time but Dave helped me out with the rest. For the future, I can only buy the COMPLETE engine bay kit and that' the way it's sold.
    I thought I should put this out there as I thought you could just buy what was needed. Dave will be coming up with a price soon which includes all the tools and brushes. He felt it was necessary to add the tool cost as all the loaners never came back. I was surprised to find out he's lending me his actual shop tools...not loaners. Well, priority on the connectors and get his tools back to him! Thanks Dave! :)
    3. Cold start 7/12 done
    4. Differential pressure switch done
    BTW, can someone tell me if there is a specific direction to the spade connector (red / purple) ?
    Shamile
    Freeze....Miami Vice !
  17. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    #92 Shamile, Nov 28, 2010
    Dear Ferraristi,
    1. Cold start 1/6 done including TPS
    2. Ooooh gold!
    3. Oh oh.....umm Dave, need your help here!! As soon as I pulled the spades out of the O2 sensor plugs...crumble! The spades are functional but...!!
    4. Oh....you got to be kidding! The last 2 plugs on the top of engine job are the O2 sensor plugs. Well....the original sealant worked it's way into the molded plug because of the heat from the muffler. Oh man!! ....what was a 20 minute job turned into 4 hours...just to get all the sealant out of both plugs. 3M wax and tar remover dissolved the sealant without hurting the plastic plug itself.
    Shamile
  18. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    #93 Shamile, Nov 28, 2010
  19. Mr.Chairman
    Mar 21, 2008
    2,987
    New Jersey
    Robbie
    #94 Mr.Chairman, Nov 28, 2010
    Greetings.. Shamile... all is looking good... bythe time your done you'll be about 50% done thru the connectors.. Mine as well finish the job and get her all done.. She is looking good.. I never replaced those blade connectors (from green wires) for the 02 sensors.. only the female terminals in the two terminal plug.... Did you get those from Dave? I hope you did not make an error or did they just crumple from the heat..? Got my car back on the road today.. rear brakes, DONE.. and done right..!! Those plugs were a job to remove that baked on sealant.. I used a very shart exacto knife and scored the sealant, then with some needle nose pliers started pealing away while slicing some more as I went.. Took some time but it is well worth it.. Don't mix up those green wires going to the o2 sensor.. She will run like sh*t..
    R
  20. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    Dear Ferraristi,
    Hi Robbie,
    I'll do the rest on a next project. A Ferrari is really like an onion....so easy to keep peeling back layer after layer. I really need to stay focused on the job at hand.
    Yes, the sealant worked it's way into the female plugs and even with the removal tool, it wouldn't come out. I had to do exactly as you mentioned....use a sharp hobby knife and slice away ever so gently. Then I had to soak with the 3M remover and pick with the pick tools...more remover...pick tools...then soaked Qtips. It took all day yesterday!
    YES...about the green spades. I marked as I pulled everything and I noticed that the black green wire was to the white and vice versa. I don't know how much of a difference it would have made as those are only the heater wires. BUT....back to the way it should be....
    Shamile
  21. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    #96 Shamile, Nov 28, 2010
    Dear Ferraristi,
    With all the terminals done except for the broken O2 heater wires...on the the coolant castings...
    1. Simple green and my trusty toothbrush.... :D
    2. Cut the old hose away every so gently. You DO NOT want to put any score on the castings or tubes. I slice, use a flat blade to pry up and slice with a NEW utility blade gently until I can place my finger underneath. I then pull away and slice...all the while slicing AWAY from any fingers.....yeah...been there...done that.. :(
    3. Old hoses removed
    4. I use 3M scotch brite to clean the area where the hose clamps down.
    Shamile
  22. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    #97 Shamile, Nov 28, 2010
  23. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    Dear Ferraristi,
    ...as soon as I learn how to pull the engine, I'll do the exhaust valves... :D
    Shamile
  24. Steve Magnusson
    25,149
    No, there's no specific polarity needed for the spade connector with the R (red) and ZN (purple/black) wires that attaches to the electrovalve for activating/deactivating the air injection system's cut-off valves.
  25. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    Dear Ferraristi,
    Thanks Steve :)
    Shamile
