Testarossa timing belts (Major) on a QuickJack ? | Page 2 | FerrariChat
Discussion in 'Boxers/TR/M' started by teveo, Feb 20, 2020.
  1. ago car nut
    ago car nut F1 Veteran
    5,535
    Madison Ohio
    David A.
    Make an engine cradle out of square tubing with casters. Remove rear wheels, lower car down to cradle, un-bolt lift body. This you wont have to lift body so high.
  2. teveo
    teveo Formula Junior
    Oct 1, 2005
    403
    Norway
    Trond Vidar
    Thats a good idea, need to study some engine out pix and make a plan. Have welding equipment in a back room with concrete floor and can weld up a cradle.
    Wood ain't bad either, have made a few cradles before with 4x4 wood and angle iron, it is a breeze to work with and soft on the metal.
    I checked the plenum height, it looks like I need to get 90 cm (with the wheels on), forgot to check lower frame height when car was on top of QuickJack but top of bumper was at 84 cm but I am sure I can get that to 95 cm. Looking at pix on the internet it seems like top of bumper measure ain't far off that rear frame, maybe need another 5 cm.
  3. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    This worked well for me. Easy to fab. Seems plenty strong. Steel will save about 10cm of height.
    The adjustable jacks (home depot) built into the frame really help with the fine adjustments. Getting the shock absorber threads through the upper frame without any thread damage requires some finesse.
  4. teveo
    Oct 1, 2005
    403
    Norway
    Trond Vidar
    This is looking good, a rolling table with fixtures and wood is nice to work with and I can reuse it on rear engine Porsche with a little modularity.
  5. Rifledriver
    37,301
  6. teveo
    Oct 1, 2005
    403
    Norway
    Trond Vidar
    Thats a nice trolley but I cant get to that height, would definitely be better to work on the engine at that height though. I am gonna try find the article about using the 4 post lift again, found a good article the other day but with 25 tabs open in the browser it is not always easy to bookmark everything. :(
  7. Rifledriver
    37,301
    They make low ones.
  8. tbakowsky
    Sep 18, 2002
    20,068
    The Cold North
    Tom
    If I may..why not pull it out from the top? Pull it up on the 4 post, yank the exhaust and manifolds, remove shift rod, drain fluids, undo everything underneath, roll it off the 4 post, remove engine lid and lift the mill out? You will have to puttz with the axles, but no biggie. You will also be left with a car you can roll any place you want to put it.
    turbo-joe likes this.
  9. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,616
    romano schwabel
    so I always do - out to the top
  10. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    Hard to pull the lid safely when working alone.
  11. turbo-joe
    Apr 6, 2008
    9,616
    romano schwabel
    I always work alone, you only need the right tools and equipment
    Rifledriver likes this.
  12. Rifledriver
    37,301
    I pull F40 and BB 512 lids alone.
  13. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    #38 vincenzo, Feb 25, 2020
    Sure... an overhead crane would be sweet. Presumably a typical diy individual does not have that. Lifting it by one pair of hands is asking for trouble. Might be able to use the four post lift as a crane(?)
    Is it possible by hand? Likely.
    Is it easy to damage? You betcha.
  14. Rifledriver
    37,301
    If he is well enough equipped to pull the engine he is well enough equipped to pull the hood.
  15. teveo
    Oct 1, 2005
    403
    Norway
    Trond Vidar
    Oh no .. I'lll be happy to lower the engine under the car thank you :eek::)
    • 4 "Rhino ramps" or similar, drive car onto ramps get some 4-6 inches additional height from ground.
    • Push in the QuickJack on top of 2 layers of 2x8 floor boards bolted to garage wooden floor
    • ratchet straps to hold down QuickJacks to those boards.
    • adjustable wooden trolley to receive engine package with or without wheels.
    Prototype this weekend if I find my tools.
  16. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    If you have an adequate overhead crane (lots of lift and capacity)... it is a very reasonable option worth considering.
    Something like this, depending on capacity and reach would be ‘iffy’.
  17. turbo-joe
    Apr 6, 2008
    9,616
    romano schwabel
    vincenzo, you also need a tool like this or equal:
    you have to lift the engine on one side more than the other and this is with only the crane you show here not possible
  18. teveo
    Oct 1, 2005
    403
    Norway
    Trond Vidar
    Yes, I do have one of those, it will be splendid for lowering the engine down on the trolley. Thanks, that was the missing link.
  19. teveo
    Oct 1, 2005
    403
    Norway
    Trond Vidar
    Hm, looks like I could consider using the overhead crane as the trolley/platform, just a solid wooden deck onto the base!
    Sorry "turbo-joe" I cant use that kind of lift, don't have roof fixtures, can't put anchors in the roof.
  20. Rifledriver
    37,301
    The draw back to that is your platform needs for the bottom to be higher that the legs of the hoist. You had mentioned a height issue. That will compound it.
    You could just put 2 x 12 planks across the legs I suppose.
  21. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
  22. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
  23. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    Too much work for an old guy.
    Try this - 140usd on Amazon.
    You can stand to the side and watch for interference as you lift/drop. Much safer.
  24. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    #49 vincenzo, Feb 25, 2020
    After awhile... you REALLY come to appreciate a two post lift.
    Don’t forget to use the Harbor Freight 20% off coupons!
    On holidays they drop it by 25%.
  25. turbo-joe
    Apr 6, 2008
    9,616
    romano schwabel
    this what I show is not for to put on the roof. it is to put on your crane and then when lifting the engine to lift it at one side higher then at the other side.
    this what vincenzo shows in post 47 is working equal. this part in post 48 has to be mounted on the roof.and you can not get the engine on one side higher than the other side during lifting out.
