Testarossa radiator cap, 0.9 or 1.1 bar? | FerrariChat
Discussion in 'Boxers/TR/M' started by bpu699, Jul 5, 2020.
  1. bpu699
    bpu699 F1 World Champ
    Dec 9, 2003
    16,210
    wisconsin/chicago
    bo
  2. Steve Magnusson
    25,038
    I'm still using the stock 0.9 bar cap (101499) on my TR without issue. My guess would be that F went to the 1.1 bar cap (137644) on 308QV as a way to address customer complaints about excessive overflow discharge (when the real problem was the 308QV cooling system just being somewhat marginal). Interestingly, the 328 original design documents still call for the 0.9 bar cap. If someone's got a copy of that Service Bulletin for updating the 308QV cap to 1.1 bar, please post -- would like to see their state "reason" and which models it applies to.
  3. bpu699
    Dec 9, 2003
    16,210
    wisconsin/chicago
    bo
    thanks... would going to a 1.1 damage anything? Specifically water pump seal?
  4. Steve Magnusson
    25,038
    Probably not, but I have no information. I noticed on the RA website that the 1.1 cap is substituted for the 0.9 cap, and the same on the eurosparesUK website (137644 replaces 101499), but they offer a 101499/C at 0.9 bar that looks like the stock 0.9 cap. Are you having a specific problem?
    bpu699 likes this.
  5. bpu699
    Dec 9, 2003
    16,210
    wisconsin/chicago
    bo
    No, still need to figure out the fan issue, don’t have time yet... all else good. Was just looking to replace cap for cosmetic reasons, and noted they’re almost all 16 psi now...
  6. tommydogs
    tommydogs Karting
    Nov 9, 2016
    137
    Los Angeles, CA
    Tommy Robinson
    For what it's worth, I replaced my original 0.9 with a 1.1 cap several years ago and haven't had any problems. I do take my TR up to redline from time to time. I found, as Steve noted, the replacement parts on the "big" Ferrari parts sites all list the current replacement part as the 1.1 cap.
  7. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    Less than 3psi difference should not damage anything. If it leaks with an extra 3psi, the seal is already a problem.
    How hot does your car run?
    Based on water:
    1.9 bar boils at 245deg F
    2.1 bar boils at 251deg F
    Likely either cap would work fine for preventing boil over or more importantly, hot spot cavitation/steam pockets.
    Just an opinion.... I’d stay with the 0.9bar cap unless running in hot ‘iffy’ conditions, or if availability is problematic. No biggie either way.
    bpu699 likes this.
  8. Jeff Pintler
    Jeff Pintler Formula Junior
    Jul 20, 2005
    537
    Richland
    Jeff Pintler
    No problems with using 1.1 on mine for years. FWIW
    Jeff Pintler
    89 348tb, 86TR, 99 360 3-pedal
    turbo-joe likes this.
